need device coax input to hdmi output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-14-2014, 10:00 AM - Thread Starter
2panther's Avatar
I've cut the cord with cable and have been using an Apple TV for movies and netflix. I used to have Tivo and canceled. The location of where the Tivo was and where the TV is now makes running an antenna like a mohu leaf to the TV directly impossible. To get OTA channels I've hooked my Tivo back up without service and using that to take the coax signal and output the video to my TV via HDMI in the wall.
There has got to be a better and more clean solution to this (that won't kill me financially)
Do I have any other options?
Thank you!
2panther is offline
post #2 of 10 Old 05-14-2014, 10:45 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 623
You mean a digital (ATSC) TV tuner ?
http://lmgtfy.com/?q=hdtv+tuner+box biggrin.gif
Or this might work,
http://www.crutchfield.com/S-CxvdA7ZC8VG/p_659CM7001/Channel-Master-CM-7001.html
OTOH maybe someone else has another good solution
tubetwister is offline
post #3 of 10 Old 05-14-2014, 02:55 PM
bac522's Avatar
Quoted: 195 Post(s)
Liked: 109
What exactly are you trying to do?
Why can't you plug the coax directly into the TV, if it supports HDMI than I'm guessing that it's new enough to have an ATSC turner (OTA) built into it already, no need to use the Tivo, just need to rescan the channels once you have the coax plugged directly into the TV.
bac522 is offline
post #4 of 10 Old 05-14-2014, 03:05 PM
Liked: 623
Why can't you plug the coax directly into the TV, if it supports HDMI than I'm guessing that it's new enough to have a ATSC turner (OTA) built into it already, no need to use the Tivo, just need to rescan the channels one you have the coax plugged directly into the TV.
I was thinking the same thing .................. sort of but I didn't pursue that line of thought ? ......................anyway you said it best !
post #5 of 10 Old 05-14-2014, 03:13 PM
Otto Pylot's Avatar
Quoted: 1669 Post(s)
Liked: 1043
Late to the party here but yeah, just connect the coax to the Ant/Cable coax input on the tv, set the tv to antenna (not cable) and scan for local stations. We're assuming that the coax is connected to an antenna and not his canceled cable (which shouldn't be providing any signal now).
Otto Pylot is offline
post #6 of 10 Old 05-15-2014, 09:54 AM - Thread Starter
2panther's Avatar
I mentioned in my initial post that due to the location of the TV and coax drop that I'm unable to connect the mohu leaf directly to the TV. Hopefully this picture helps illustrate what I mean. The wall is an outside wall, there are three HDMI cables run in the wall, it was drywalled over and then the builtin was put in place. Too late to run coax and the wife doesn't want to see any cables.
built_in.jpg 291k .jpg file
2panther is offline
post #7 of 10 Old 05-15-2014, 10:51 AM
jjeff's Avatar
Quoted: 778 Post(s)
Liked: 278
Then something like tubetwister linked in post #2 would work, or real cheap would be the iView 3500 (<$50) which is a tuner and can also record when you attach a USB HDD.
Oh if you want to spend a bit more then maybe something like the CM DVR+ would work. It is razor thin, dual tuner and again with a USB HDD can record.
Is it the size of the Tivo that you dont like?
jjeff is offline
post #8 of 10 Old 05-15-2014, 11:02 AM
Otto Pylot's Avatar
Liked: 1043
The picture makes it crystal clear. I think jjeff's idea is a good one and probably your only viable option.
post #9 of 10 Old 05-15-2014, 11:21 AM - Thread Starter
2panther's Avatar
It is the size, using the TiVo without TiVo service is a headache and i dont want to pay a monthly service either.I will check out those suggestions out.
2panther is offline
post #10 of 10 Old 05-15-2014, 01:00 PM
Liked: 623
Reply HDTV Technical
