Cox Communications - CableCARD + HD HomeRun Prime (3 or 6 tuner) - AVS Forum
Old 06-21-2014, 05:46 PM - Thread Starter
Cynagen's Avatar
Special considerations must be taken when you get this setup, you NEED a switched digital tuner in order to receive all channels correctly, however, do NOT expect windows media center to play those channels correctly at all. The channels requiring the SDV typically cause WMC to completely crash and I would recommend another option for your viewing needs.
Cynagen is offline
Old 06-22-2014, 05:59 AM
Super Moderator
DrDon's Avatar
Quoted: 117 Post(s)
Liked: 296
Moved to proper forum.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Old 06-22-2014, 08:34 AM
Andy_Steb's Avatar
Quoted: 26 Post(s)
Liked: 153
You need a tuning adapter.
You should of received a tuning adapter(at no charge) from Cox when you got the cable card.
I have been using a cable card tuner with Cox for years with no problems. I started with a Ceton and now am using a Homerun.
Andy_Steb is offline
Old 06-22-2014, 08:38 AM
Foxbat121's Avatar
Quoted: 251 Post(s)
Liked: 250
As pointed out above, you simply need a TA (if you have the old 6-tuner version, you need two TAs). This is case with majority of other cable providers (except FiOS and Comcast).
Foxbat121 is offline
Old 06-22-2014, 09:09 AM
mdavej's Avatar
Quoted: 553 Post(s)
Liked: 429
That's definitely not normal. WMC works fine with SDV. You must be having some kind of driver issue or hardware failure.
mdavej is offline
Old 06-22-2014, 06:19 PM - Thread Starter
Cynagen's Avatar
Thank you sir.
I started with the Homerun, I've heard nothing but good about these, and it was well worth the wait to get one, I love this thing. And I had problems receiving certain channels in my area at all, namely all HBOs in the 200s aside from 200 & 201, the rest just did not show, and same with Starz, I only got 260, nothing else. In the high end, I was missing 1261 as well, and a number of other HD versions of channels. After adding in the TA, I went from scanning ~270 programs, to ~380 programs, there was a TON I was missing and didn't realize it. I didn't get the TA in the first place because I ordered my CC over the phone, and just the CC, it was all self install (which wasn't all that smooth, but persistence paid off). Had a tech come out and drop a TA on me, it's an extra equipment fee, but it's $4.50 total, compared to the $12 for the stupid DVR in the other room, and I have 20tb of DVR capable storage in here.
After tearing it down and redoing all the wiring to kind of spread my entertainment setup out (it ended up becoming a giant jumble of wires and equipment in one small cubby, bad bad bad) I repaired the TA to the CC and now all is well. Windows Media Center doesn't like the slightest hiccup in the data stream else it throws a fit on me, but I feel like that's to be expected with Microsoft.
Cynagen is offline
cox communications , hd homerun prime , switched digital video
