What are the gotcha's for buying a DishTV receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-25-2014, 09:50 AM - Thread Starter
llaves's Avatar
My condo complex is finally upgrading to HD, which means I'll have to buy (no leasing) a receiver. There are lots of 722's on ebay for less than 1/2 of what Dish wants for one. Will I have trouble getting a receiver from ebay activated? Is this like the cellphone biz where there's a blacklist of receivers that won't activate? How do I tell if the receiver is blacklisted?
The salesperson told me that I can't use a hopper/joey on this system - that there's an incompatibility with the dish? Then something about the "node", which I can also buy on ebay. Even crazier - she claimed a hopper and a joey would count as two drops against our system count, which seems odd since the Joey is not a receiver. Make sense to anyone?
llaves is offline
post #2 of 4 Old 06-25-2014, 03:39 PM
bac522's Avatar
Quoted: 193 Post(s)
Liked: 108
I know when I needed to replace a DirecTV receiver a few years ago (when I used them) I bought a used one off of ebay, apparently the receiver was blacklisted...I never even thought of checking into that thinking my D* card would be okay with an receiver. After that I had to ask the seller for information about the receiver than clear it with DirecTV support as to whether the receiver was okay to buy or not...it was actually a pain trying to get a clean one on Ebay at a reasonable price, although eventually I did.
I don't know if Dish is any different but you might want to ask this question of Dish forum https://support.dish.com/
bac522 is offline
post #3 of 4 Old 06-25-2014, 09:28 PM
acesat's Avatar
I tried running a hopper without a node before and it worked but IIRC it only had 2 tuners and even trying to tap a joey off it wouldn't work so it would be like an expensive 612. The node with 2 cables going to the dish is necessary.
You live in a condo complex... describe the buildings. Are they like 3-4 units in a row? Do you own or rent, and if you own do you also own the exterior and roof above you? Why can't you lease a receiver? Was the salesperson familiar with your condo complex and did you talk to several salespeople?
acesat is offline
post #4 of 4 Old 06-26-2014, 07:02 AM - Thread Starter
llaves's Avatar
I'm free to get my own private Dish account, but the bulk account is a huge savings - $22/month for the same programming that costs me $78/month on the private account that I currently have. Subscribers on bulk accounts must provide their own receivers. As to the Hopper/Joey issue, the shared dishes don't support them and we've decided not to upgrade the dishes.
llaves is offline
Reply HDTV Technical
