Moved to Long Valley, NJ--can I get anything here? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-29-2014, 11:25 PM - Thread Starter
supergriff's Avatar
Here is my tv fool result.... I have removed my current antenna setup from the old location and am taking it to the new house. This is what I have.. 2 antennas on one 5ft mast, a 91xg and a ya-1713, with a cm7777 amp. My tv fool looks worse than my old place, I wanted to live on a hill, wife overruled me on that one. I hope I can get FOX with my setup. http://www.tvfool.com/?option=com_wr...e1c694c0b662c8
supergriff is offline
post #2 of 7 Old 06-30-2014, 08:35 AM
Calaveras's Avatar
Quoted: 1101 Post(s)
Liked: 258
I have a TV Fool report and terrain situation that looks very similar to yours.
http://www.tvfool.com/?option=com_wr...cc49e65f5d3c18
My locals are the ones at 272 degrees. I receive them all nearly all the time. In order for it to work your antenna needs to be as high as possible to limit the angle to the last ridge and you can't be looking through any vegetation right in front of the antenna. If you can do that then you have a chance. Run TV Fool with your antenna at different heights and see how much signals improve as you go up. If you could go high enough to make it a 1 edge path instead of a 2 edge path you'd be in business. The terrain plots make it look like you're not that far below the last ridge line.
Calaveras is offline
post #3 of 7 Old 06-30-2014, 07:13 PM - Thread Starter
supergriff's Avatar
Why is it that the only stations that are LOS are the ones no one wants to watch?? Did a temp hook up, 15 ft high. No Fox. Did quite well, CBS. NBC, WPIX, ABC. No WOR or Fox. House is a one story ranch. I guess I would need a tower. I miss Aereo.
post #4 of 7 Old 07-01-2014, 05:15 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
I miss Aereo.
It's a shame because you're the exact reason for Aereo...I still don't get the broadcaster motives here?!?!?! All they did was remove eyeballs from their streams and thus potential ad revenue! But then I'm going OT here.
bac522 is offline
post #5 of 7 Old 07-01-2014, 03:28 PM - Thread Starter
supergriff's Avatar
Other thing unusual, cannot get 5-1, which should be easier than 4-1. Yet 4-1 comes in well, and 5-1 does not come in at all. Could it be the higher frequency of the station??
post #6 of 7 Old 07-04-2014, 07:01 AM
Super Moderator
DrDon's Avatar
Quoted: 871 Post(s)
Liked: 1730
Please follow the instructions in the sticky notes. A location is required in the title of all antenna threads.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #7 of 7 Old 07-04-2014, 07:09 PM
hphase's Avatar
Unless the thread title was edited after posting, the title says it all. The question here is, is supergriff "in the valley" or "on the mountain"?
If he/she is in the valley, you can pretty much forget any NY or Philly reception. If you're on the mountain, your options improve, depending on where you are exactly. Higher is better. I'm "on the mountain" and I can get NY, Philly, Allentown, and Wilkes-Barre/Scranton OTA. Note: W-B/Scranton channels actually drown out some NYC stations.
hphase is offline
Reply HDTV Technical
