ABC Network changing their sat feed configuartion? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-17-2014, 08:48 PM - Thread Starter
mrvideo's Avatar
Quoted: 592 Post(s)
Liked: 334
Question ABC Network changing their sat feed configuartion?
The last time I tuned into the ABC network feed on G3C/15 was two weeks ago when I captured NY Med. I forgot last week.
Tonight when I tuned in again to capture NY Med, I discovered a few changes. There are now five streams, three real and two virtual. The two virtual are PIDS 0x68 and 0x69 that are pointing to the stream at 0x65.
What is worse is that the three real streams have gone from about ~22.5 Mbps to ~17.35 Mbps with ~22.3 Mbps in null packets (up a whole bunch).
Does anyone know if ABC is going to add a couple of new real streams to their mux? And if so, what?
"You're Sherlock Holmes, wear the damn hat!" - Watson to Sherlock
Sherlock - The Abominable Bride - 1/01/16
Mr. Video
My Geek Images
mrvideo is offline
post #2 of 3 Old 07-19-2014, 11:04 PM
Harry Kerry's Avatar
Forgive my ignorance if they already are, but what about their dopey Living Well HD channel that the O&O's carry in their OTA mux?
Harry Kerry is offline
post #3 of 3 Old 07-19-2014, 11:48 PM - Thread Starter
mrvideo's Avatar
Quoted: 592 Post(s)
Liked: 334
It is ceasing operation. I don't remember the exact date.
It is not carried on this particular transponder. Up until recently, the only use has been to feed the network programming.
Mr. Video
My Geek Images
mrvideo is offline
Reply HDTV Technical
