no tv tuner , antenna options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-19-2014, 04:29 PM - Thread Starter
Liked: 0
I bought an antenna , its in the mail , i have this TV NUVISION LUCIDIUM 47" DMC from 2008 ( the company quit business ). Just learned i have no tuner , no antenna input .
What options do i have to connect my antenna to this tv , please.
thank you
bsuciu2014 is offline
post #2 of 9 Old 07-19-2014, 04:57 PM
Ratman's Avatar
Quoted: 1277 Post(s)
Liked: 1026
Buy an external tuner?
Depending on where you live (North America, Japan, UK, France, Antarctica, etc.), the type of tuner will differ.
Ratman is offline
post #3 of 9 Old 07-19-2014, 05:01 PM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
I assume you're in the US in which case you'll need an ATSC digital tuner with HDMI and/or component output similar to this box http://www.mcmelectronics.com/produc...M7001-/30-2116
bac522 is online now
post #4 of 9 Old 07-19-2014, 05:15 PM - Thread Starter
Liked: 0
thank you , I'm in US , is this one a good value / quality ? thank you
post #5 of 9 Old 07-19-2014, 05:55 PM
Phane's Avatar
You can get an iView 3500STBII for $32.50. If you don't need optical out for audio, then the iView is probably a better value. They both have HDMI and component outputs.
Phane is offline
post #6 of 9 Old 07-21-2014, 09:09 AM
Mbajner's Avatar
Quoted: 39 Post(s)
Bought the Mediasonic Homeworx150 box
Works very well and has true HD reception not like those other STB,s that are just SD
Mbajner is offline
post #7 of 9 Old 07-21-2014, 08:35 PM
Phane's Avatar
The iView 3500STB is (essentially) a clone of the Homeworx 150. I'm pretty sure all the STB's mentioned in this thread output HD. At the very least, I know the iView can.
Phane is offline
post #8 of 9 Old 07-22-2014, 07:08 AM
Mbajner's Avatar
Quoted: 39 Post(s)
While the iView maybe a clone of the mediasonic homeworx150, I heard better things about the mediasonic unit and that is why I bought that one.
Also for the price (less than $40) for tone unit, it sure beats out the others costing well over $100
Either way a true HD reception unit is the way to go instead of those cheap RCA or Colby brand STB,s
Mbajner is offline
post #9 of 9 Old 07-22-2014, 03:55 PM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
Most of the early Digital tuners were only meant to give people with older analog TV's a way to receive HDTV on the SD Tube.
Glad you found one that works for you...the Channelmaster I listed was for reference only, plus CM tends to make decent stuff, personally I would have gone (and suggested) for the lower cost one too if I had know about it !
Reply HDTV Technical
