Mohu Leaf - Amplified or Not - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-20-2014, 08:15 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 9
So I have a mohu leaf 50, which is the amplified version. When I have the amplifier plugged in, I get 100% signal strength. After doing some searching online, I've read that using an amplifier can result in an overdriven signal and actually hurt PQ if it's not needed, so I unplugged the amplifier to see what the signal strength is unamplified. Right now, I'm getting 60-75% depending on channel. So, what do people think - use the amplifier or not?
Duke02 is offline
post #2 of 3 Old 07-20-2014, 11:36 AM
ProjectSHO89's Avatar
Quoted: 211 Post(s)
Liked: 110
If you unplug the power to the amplifier without physically removing the amp from the circuit, you will only get the strongest signals.
Use whatever configuration works best.
ProjectSHO89 is offline
post #3 of 3 Old 07-22-2014, 03:59 PM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
You would notice PQ being affected if the tuner was being over-driven similar to a signal not being strong enough. My guess is you're probably seeing no difference between the PQ at 100% and at 60-75%...where you'll have the problem is losing channels that were weak before and now no longer work. If you want to channels too, then turn the Amp back on.
bac522 is offline
Reply HDTV Technical
