ATSC "multiple string structure" - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jowijo
post #1 of 19 Old 07-24-2014, 12:00 PM - Thread Starter
jowijo's Avatar
Question ATSC "multiple string structure"
I doubt this is the best place to ask a question like this, but I figured I'd give it a go anyway.
I am attempting to write a script for an EPG generator, and have come up on a bit of a snag. I would like to encode Program Title, and other text imformation/ WIthout this, the EPG is useless. Combing through the ATSC books I have, it appears that this is acheived using the "multiple string structure". Throwing this into Google give me no information on how one goes about encoding this information. My muxer Opencaster, has no documentation on this either.
Anyone here knowledgeable about what this is and how it works? Most importantly, I need to know how it is formatted and structured in a XML format.
If not, know anywhere/anyone that could possibly help me with this? Thanks.
jowijo is offline
post #2 of 19 Old 07-24-2014, 09:11 PM
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
It's in the specification. The ATSC website seems broken right now, so I've put it on my site.
http://www.w6rz.net/A65_2013.pdf
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
post #3 of 19 Old 07-26-2014, 08:12 PM - Thread Starter
jowijo's Avatar
Exclamation Thank you, but....
Ron
Appreciate it, I have a copy of a similar document in my home folder. The issue with the multiple_string_structure seems to be the layout--or it could be lack of support from Opencaster iself.. Here is the section where it should be (It's in bold):
Code:
eit = event_information_section(
    table_id = 0xCB,
    service_id = atsc1_service_id,
    transport_stream_id = atsc_transport_stream_id,
        source_id = 0x1,
        event_loop = [
        event_loop_item(
        event_id = 1,
        start_hours = 0x00, # use hex like decimals
        duration_seconds = 0x00,
                title_length = 0x3,
                title_text = multiple_string_structure (?),
        event_descriptor_loop = [],
        segment_last_section_number = 1,
        version_number = 1,
        section_number = 0,
        last_section_number = 0, # pay attention here, we have another section after this!
jowijo is offline
post #4 of 19 Old 07-26-2014, 11:28 PM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
Doesn't page 79 of the linked .PDF document say what the multiple string structure should be (I don't really understand it but it looks like it's something like that)?
Joe Bloggs is offline
post #5 of 19 Old 07-27-2014, 12:37 AM - Thread Starter
jowijo's Avatar
It's not so much the structure I'm worried about, it's the context. Is it a section of its own? Is it within the "title_text" object? How it is laid out in relation to my configuration is what I don't seem to get here. Kind of frustrating.
jowijo is offline
post #6 of 19 Old 07-27-2014, 06:25 AM
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
Here's an EIT section from a local station. The cursor is on the first byte of the multiple_string_structure.
Ron
post #7 of 19 Old 07-27-2014, 12:58 PM - Thread Starter
jowijo's Avatar
Unhappy
Ron
Did a local capture and looked on a hex editor--while it shows the string, and what looks like a language descriptor, it still does not actually show how it is entered into the muxer itself. TSreader's XML export gets me this. Not much help either.
Code:
  <EVENT>
     <START-UTC-DATE>2014-07-28</START-UTC-DATE>
     <START-UTC-TIME>01:00:03</START-UTC-TIME>
     <START-LOCAL-DATE>2014-07-27</START-LOCAL-DATE>
     <START-LOCAL-TIME>18:00:03</START-LOCAL-TIME>
     <DURATION>00:30:00</DURATION>
     <NAME>CBS Evening News</NAME>
     <DESCRIPTION>Veteran news anchor Jeff Glor and the CBS News Team reports on important events and headlining developments from all across the nation and around the world, covering social, political, environmental and economical issues and more.</DESCRIPTION>
     <ID>266</ID>
     <FREE-CA-MODE>0</FREE-CA-MODE>
     <RUNNING-STATUS>0</RUNNING-STATUS>
  <DESCRIPTOR>
   <TAG>0x81</TAG>
   <LENGTH>10</LENGTH>
   <DATA>0x08 0x38 0x05 0xff 0x0f 0x00 0xbf 0x65 0x6e 0x67</DATA>
   </DESCRIPTOR>
  </EVENT>
What I am still trying to understand, is how that information there, (name and description), are encoded on my end. The PDF and another I have explaining the huffman coding don't bother with showing a sample implementation.
jowijo is offline
post #8 of 19 Old 07-27-2014, 07:11 PM
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
I tried to evaluate OpenCaster, but with all the micro-steps required to make a Transport Stream, I found it super annoying.
Ron
post #9 of 19 Old 07-27-2014, 08:33 PM - Thread Starter
jowijo's Avatar
Ron
The ATSC implementation isn't documented well at all. Any alternative software out there that can do what I need?
jowijo is offline
post #10 of 19 Old 08-08-2014, 12:07 PM - Thread Starter
jowijo's Avatar
Okay, I think I have the multiple_string_structure part figured out, here is that particular table:
Code:
    table_id = 0x12,
        source_id = 0x1,
            event_loop = [
                event_loop_item(
                    event_id = 0x1,
                    title_length = 0x0B,
                    start_time = 1091399416,
                    length_in_seconds = 3600,
                    title_text = multiple_string_structure(
                            number_strings = 0x1,
                            string_loop = [
                                string_loop_item(
                                    ISO639_language_code = "eng",
                                    number_segments = 0x1,
                                    segment_loop = [
                                        segment_loop_item(
                                            compression_type = 0x0,
                                            mode = 0x0,
                                            number_bytes = 0x0B,
                                            compressed_string = "54 65 73 74 20 50 72 67 72 61 6D",
                    ETM_location = 0x0,
        version_number = 1,
        section_number = 0,
TSReader, and TS Monitor show nothing though...oddly enough, no errors appear either. A hex editor will show that the table is indeed in there, and I am following Opencaster's implementation and ATSC specifications; I'm sure I have something wrong though. Before I can validate the contents of the table though, I need to figure out why the players don't see it.
jowijo is offline
post #11 of 19 Old 08-10-2014, 12:02 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
Why? Just curious as to what is your need is that you want to try and do something like this the hard way as opposed to off the shelf tho very expensive PSIP software? I install and config PSIP generators and multiplexes all the time, it's not something one just does for fun as Ron knows.
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #12 of 19 Old 08-10-2014, 03:05 PM - Thread Starter
jowijo's Avatar
Exclamation
I forgot to update this thread...I got it working.
This is something I'm doing for curiosity. I don't run a licensed TV station, and my income is barely enough to keep me sheltered, fed, and clothed; so the idea of paying for some hardware I'd likely never use is kind of dumb.
Anyway, I am now writing a web-based front-end to automatically generate these tables. I'll likely keep it to myself unless someone shows interest in using it.
jowijo is offline
post #13 of 19 Old 08-10-2014, 03:14 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
I forgot to update this thread...I got it working. This is something I'm doing for curiosity. .
Oh to have time to do such things..
Bob
post #14 of 19 Old 08-10-2014, 03:16 PM - Thread Starter
jowijo's Avatar
I'm fortunate enough that I have a part-time job that pays well, and live in a 1BD apartment in a nice small town for dirt cheap.
I actually find this kind of thing fun. (Probably because I don't have to do it), and I like figuring out how things work.
jowijo is offline
post #15 of 19 Old 08-10-2014, 03:47 PM
Trip in VA's Avatar
Quoted: 538 Post(s)
Liked: 145
Send a message via AIM to Trip in VA
I suspect there are people who might be interested in such a thing. (Like me, as a curiosity.)
I bet it could be turned into a nifty product or, at least, an open-source type thing that people could use. Especially if it did the TVCT and other tables.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #16 of 19 Old 08-10-2014, 03:49 PM - Thread Starter
jowijo's Avatar
- Trip
I havenm't added TVCT editing, but it will be once the EIT/ETT portion is done. (90%).
jowijo is offline
post #17 of 19 Old 08-10-2014, 04:37 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
I actually find this kind of thing fun. (Probably because I don't have to do it).
Yea, doing it for yourself as a hobby where it doesn't cause viewer reception issues is a bit different. The having to do it everyday tends to detract from the fun somewhat. Such is life..
Bob
post #18 of 19 Old 08-10-2014, 04:40 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
- Trip
Hmmm.. an open source PSIP generator that was ATSC compliant..that did not cost multiple thousands..and worked..would attract some interest (research DTV Innovations tho..) The issue is a "cheap" ATSC modulator..as a few others here have found. While cheap 64/256QAM modulators are another story..especially ones with IP inputs.
Bob
post #19 of 19 Old 11-06-2014, 12:54 PM - Thread Starter
jowijo's Avatar
Post Solved...
I figured I'd update this thread, as a few months ago, I figured out the MSS issue, and several others. Sadly, I never uploaded any of my PSIP-Generator CMS to github, and it was wiped out along with other web code.
Good news, all my experimenting with OpenCaster proved fruitful. You can now broadcast TVCT, EIT, ETT, complete with rating descriptors, usingOpenCaster. All the files needed, with semi-helpful comments, are on my github.
Here's to hoping someone finds use for them.
scowl likes this.
Last edited by jowijo; 11-06-2014 at 12:56 PM. Reason: Forgot to mention rating descriptor loops were added too.
jowijo is offline
Reply HDTV Technical
atsc , eet , epg
