Flat screen and circuit sharing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-27-2014, 04:59 AM - Thread Starter
axxel6307's Avatar
Hope this is the right category to post in.
I am wondering if it's safe to use extension cords with flat screen tvs?
Also, would it be ok for a tv to plug into an outlet that was also running a window air conditioner, or even on the same circuit for that matter? It's a standard two plug receptacle, with one plug having the air conditioner in it, and the other the flat screen. I know window ac units most likely cause voltage drops when the compressor kicks on and off, but I am far from an expert on this.
What do you think?
axxel6307 is offline
post #2 of 4 Old 07-27-2014, 09:49 AM
Otto Pylot's Avatar
Quoted: 1667 Post(s)
Liked: 1042
I would not plug in a tv on the same circuit as an air conditioner. We've seen issues with tv's plugged into the same circuit as refrigerators and when the compressor comes on, there's interference.
Otto Pylot is online now
post #3 of 4 Old 07-27-2014, 09:56 AM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
And when a high inductance thing like a motor or compressor turns OFF watch out for spIkes.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 4 Old 07-27-2014, 12:31 PM
bac522's Avatar
Quoted: 195 Post(s)
Liked: 109
Extension cord is fine. If you have to plug it into the same circuit as the A/C use a surge protector on the TV.
bac522 is offline
Reply HDTV Technical
