Help choosing a gaming TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-28-2014, 02:55 AM - Thread Starter
Liked: 0
Hello, I've been told to come to these forums for help by others about choosing a new TV to use with my PS4. I definitely dont know a lot about TV's so I would love help from you guys.
I've had the same 32" Sony Bravia since 2007 which it's highest resolution is 1080i and I've always thought that the difference between that and 1080p was close to nothing until recently I played on a 50" LG 1080p TV and the difference was huge IMO. I'm looking to upgrade and I'm interested in this because of how much I'm willing to spend:
http://www.argos.co.uk/m/static/Prod...rm/hitachi.htm
Is it only 1080p I need to worry about or it's there anything else I should know that would be better for my PS4? I heard input lag is important too but I'm not sure how to check what this TV's specs are. And does this TV look good overall?
Also, what is considered a good response time and motion rate for a gaming TV?
Thanks for anything you can tell me!
Furyan42 is offline
post #2 of 4 Old 07-28-2014, 04:58 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
Wrong forum, see Sticky Topic.
bac522 is online now
post #3 of 4 Old 07-28-2014, 06:25 AM
Super Moderator
DrDon's Avatar
Quoted: 869 Post(s)
Liked: 1727
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4 of 4 Old 07-28-2014, 06:45 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
As Don stated, this is the wrong forum for your request. There is a dedicated thread in the LCD section on input lag for gaming:
Input lag wars!, post your input lag results of your LCD display here for reference
There are also dedicated owners' threads for each TV. They could probably answer your questions, also.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread HDTV Technical
