Audio hum from FIOS box - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By hammerdwn
  • 1 Post By AntAltMike
Old 07-29-2014, 08:25 PM - Thread Starter
meli's Avatar
Quoted: 174 Post(s)
Liked: 38
I installed a new amplifier in my home theater rig and immediately noticed a hum that wasn't present with the old amplifier. I traced the problem to the coax cable from the FIOS cable box. The hum was present if the cable box, modem, and the amplifier were all plugged into the same surge protector. The hum was present if the cable box's AC was unplugged. The hum went away if I unplugged the coax cable, regardless if the AC was plugged in or not.
I eliminated the hum by passing the coax cable thru the surge protector. My question is, should I leave it at that? Would you say that "fixed" the problem? Or is that merely a kludge? Should I dig deeper and see if I can find a wiring mistake? Maybe the FIOS installer did something incorrect? Or should I consider the problem solved? Electrical problems are not my forte.
meli is offline
Old 07-30-2014, 03:34 AM
Super Moderator
DrDon's Avatar
Quoted: 875 Post(s)
Liked: 1734
Please keep topic titles specific. See my edit.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Old 07-30-2014, 08:18 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Originally Posted by meli View Post
...I eliminated the hum by passing the coax cable thru the surge protector. My question is, should I leave it at that? Would you say that "fixed" the problem? Or is that merely a kludge? Should I dig deeper and see if I can find a wiring mistake? Maybe the FIOS installer did something incorrect? Or should I consider the problem solved? Electrical problems are not my forte.
As long as you still get all your channels and good internet performance then that should be fine. But it would be advisable to connect a ground outside where the FIOS coax line enters your home to your electrical panel ground/earth ground. If in doubt, call FIOS provider to do it for you.
meli likes this.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
Old 07-30-2014, 08:30 AM
Ratman's Avatar
Quoted: 1287 Post(s)
Liked: 1028
I thought that FiOS was "fiber" to the home/premises. The coax doesn't "begin" until "after" the ONT which is located inside the home.
Ratman is offline
Old 07-30-2014, 08:44 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Google FIOS Ground comes up with alot of stories...
Old 07-30-2014, 10:53 AM
AntAltMike's Avatar
Quoted: 130 Post(s)
Liked: 62
Actually, it is a Kludge that works. What you have installed is functioning as a ground interrupter. Both sides of the circuit are still grounded, but there is not also a "loop" picking up interference.
Grounds are required by electrical codes to reduce shock and fire hazards. Grounds that satisfy those codes sometimes are troublesome because of their concurrent inclusion in technical ground paths, which are grounds that enable low voltage circuits to work or to work well. Your problem is solved and can be considered so.
meli likes this.
AntAltMike is offline
