True DVI-DL to HMDI 1.4 4K converter - AVS Forum | Home Theater Discussions And Reviews
Old 08-04-2014, 08:50 AM - Thread Starter
Liked: 0
Hi All,
We've been stumped by an issue which some of you might have been aware of, which is to convert a DVI-DL running 3840x2160@30Hz to HDMI 1.4 (at same resolution/refresh).
Although DVI and HDMI are cross compatible you can only stream 2.2Gb/s or 165Mhz pixel clock across the two platforms.
We have found a working solution which actively converts DVI-DL to HDMI 1.4 and we've tested it to work at the above mentioned resolution, however the manufacturer wants a minimum order of 20 units and we only need 8 units.
Has anyone else here got the same conversion needs? They cost no more than £250 per unit depending on how much interest we get.
PM me if anyone is interested.
Cheers
Henri LK is offline
