Want to use component to HDMI and bypass HDCP? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-06-2014, 12:20 PM - Thread Starter
boneless6220's Avatar
If I use component cables from the source to bypass the HDCP in HDMI, can I passthrough the signal through a recorder to a display device with an HDMI cable? Or will the HDCP kick in again?
source -> component cables -> recorder -> HDMI -> display device
boneless6220 is offline
post #2 of 6 Old 08-06-2014, 01:31 PM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
Highly unlikely your recorder would add HDCP to a signal that didn't already have it, you should be OK.
jjeff is offline
post #3 of 6 Old 08-06-2014, 02:36 PM - Thread Starter
post #4 of 6 Old 08-06-2014, 02:44 PM
Glimmie's Avatar
Quoted: 760 Post(s)
Liked: 625
What type of recorder are we talking about? Because no consumer HDTV recorder and few professional recorders can record full bandwidth HD. So there's a good chance the HDMI output from such a recorder will be re-compressed and not very well either.
And there is also an option for devices to downrez HD component outputs on HDCP sources but I don't think any content producer ever employed that. Plus, cable and satellite aren't allowed to downrez component outputs per the FCC, only Bluray can.
Glimmie is offline
post #5 of 6 Old 08-06-2014, 06:07 PM - Thread Starter
I was going to record on a capture card with a PC. 1080i is not mandatory, 720p should be fine for me. I'm debating whether to use a active splitter so I can record through the PC with a monitor while being able to watch on my tv at the same time. Not a deal breaker though.
post #6 of 6 Old 08-07-2014, 11:51 AM
Super Moderator
DrDon's Avatar
Quoted: 1180 Post(s)
Liked: 2292
You probably ought to tell us what your source is and your objective is. There may be a better way to accomplish your goals.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Reply HDTV Technical
