Comcast DTA-HD Audio - AVS Forum
post #1 of 10 Old 10-17-2014, 05:48 AM - Thread Starter
hmunster2's Avatar
Quoted: 46 Post(s)
Hope someone might be able to answer this. Watched last night's NFL game on CBS but was unable to get Dolby Digital 5.1 surround through my system. I have the HDMI from the DTA going into my Yamaha AVR. It was displaying Dolby Pro-logic. Is this converter box not capable of sending the DD 5.1 signal? I find it hard to believe that at this time, it was designed for just Pro-Logic-these boxes have just become available in my area and have been out in other parts of the country for less than a year.
hmunster2 is offline
post #2 of 10 Old 10-17-2014, 10:36 AM
cmotomn's Avatar
Unfortunately the HD-DTA's do not pass 5.1 audio as previously discussed here;
Minneapolis, MN - Comcast
cmotomn is offline
post #3 of 10 Old 10-17-2014, 11:27 AM - Thread Starter
hmunster2's Avatar
Quoted: 46 Post(s)
Where was it discussed? Thanks for the information.
post #4 of 10 Old 10-17-2014, 11:43 AM
Ratman's Avatar
Quoted: 211 Post(s)
Liked: 304
Post 2843 in the link provided above made mention.
Have you contacted Comcast and asked?
Do other channels provide DD5.1 or was it only this particular program?
Ratman is offline
post #5 of 10 Old 10-17-2014, 12:15 PM - Thread Starter
hmunster2's Avatar
Quoted: 46 Post(s)
Rat, haven't tried other channels, but when I had a full service box it passed 5.1. Talk to Comcast, seriously, they have no clue about anything-3 different people just to activate the box and the installer, after wanting to mount it out of sight, told me I can't because this box does;t have the IR extension-no kidding, it has RF capability-he had no clue.
So much for Comcast-they even told me that no such thing as the HD-DTA exists and after I found somebody who confirmed its existence, told me that it would only get about 20 channels, no more.
I am going to cut the cord if I can find a way to get broadcast tv in real time-can't get it by antenna in my area.
anyway thanks again.
post #6 of 10 Old 10-17-2014, 01:44 PM
Ratman's Avatar
Quoted: 211 Post(s)
Liked: 304
Herm... try other channels to confirm. Seriously.
The IR is a different problem. No kidding.
I know Comcast techs can be useless (not limited to Comcast either).
Perhaps if you provide the make/model of the HD-DTA, someone may be able to confirm the limitation(s) if they are a cableco employee or by reading the manual online for you. Maybe the DTA has a setting to enable DD5.1 (bitstream) over HDMI. It may be defaulted to PCM Stereo only.
Ratman is offline
post #7 of 10 Old 10-17-2014, 02:30 PM
holl_ands's Avatar
Quoted: 38 Post(s)
Liked: 64
DTA's are very simplistic boxes intended to be EXTREMELY simple for a neophyte user to install and go...minimal if an setup options. So don't expect them to have a Dolby Digital 5.1 Decoder with PCM & Bitstream setup options.
I looked at several HD-DTA spec sheets I've collected, the ONLY one that even MENTIONS this subject is Pace DC60Xu (used on some COMCAST systems) that explicitly says it ONLY does 2-Channel Stereo in (HDMI standard) AC3 (Dolby Digital) format....so it's ONLY PCM Stereo:
http://www.pace.com/Documents/Produc...STB/DC60XU.pdf
holl_ands is offline
post #8 of 10 Old 10-17-2014, 02:45 PM
Ratman's Avatar
Quoted: 211 Post(s)
Liked: 304
And there ya go...
So the OP can rent a "standard" cable box or go to a 3rd party solution that may require a cablecard, IF... DD5.1 is a requirement.
Ratman is offline
post #9 of 10 Old 10-18-2014, 07:30 PM - Thread Starter
hmunster2's Avatar
Quoted: 46 Post(s)
Comcast blows
The bottom line is Comcast blows. I don't care how simplistic the box is, at least it should pass a Dolby digital 5.1 signal for a receiver to decode. I hate dealing with Comcast-we pay through the nose for their crappy service. I hope the new alternatives like HBO and Sonys new channel really take off.
post #10 of 10 Old 10-18-2014, 09:20 PM
HDMI Guy's Avatar
Quoted: 49 Post(s)
You could try a Samsung Smart Media Player (GX-SM530CF ). It would require a cable card but will pass Dolby Digital 5.1 over HDMI. I don't know what Comcast charges for a cable card but they are usually much less than a cable box.
HDMI Guy is offline
Reply HDTV Technical
User Tag List
