Flint, MI: Are My Signals Too Strong for the CM-7777 - AVS Forum
Old 11-01-2014, 09:13 PM - Thread Starter
MicroTheater's Avatar
#1.) Firstly;
I Own BOTH The CM-7777 (and) the CM-7778
I Only Own the CM-7777 Because I used to live in the Sticks (i.e. Country)
But Now; that I'm in the City are these Signals too Strong for the CM-7777-???
If These Signals are to strong to have a CM-7777 on a Tower at 55-feet.
#2.) Secondly;
I may just Save the 7777 To help boost a pair of non-amplified rabbit ears in a bedroom.
Since I am so close to everything I'm Thinking the CM-7777 Will help the rabbit ears Cut though the walls
of the house better?
and put the 7778 on my 55' foot tower. Would this be the better route to go???
Because I have a Home Theather PC
My Screen Name is a Cross between Microsoft and Theather
A Clever one there LOL
MicroTheater is offline
Old 11-01-2014, 11:09 PM
holl_ands's Avatar
Quoted: 63 Post(s)
Liked: 68
Not much info to go on....how many Tuners are you trying to drive from that Antenna? And you need to enter your location into www.tvfool.com and THEN copy/paste the Results URL (Webaddress at TOP of Browser) into a post on this thread so we can see your signal levels....
holl_ands is online now
Old 11-02-2014, 07:40 AM
Calaveras's Avatar
Quoted: 208 Post(s)
Liked: 106
I think we just went through all this with you a short time ago. You might want to review that here:
CM-7777 / 7778: "New & Improved"?
The list of stations you posted is basically useless. You still need to post a LINK to your TV Fool report.
A higher gain preamp is not going to do you any good with rabbit ears. Gain is not the determining factor in how much improvement a preamp might provide.
Calaveras is offline
Old 11-02-2014, 08:10 AM - Thread Starter
What kind of zero loss combiner antenna joiner Is that Calaveras???
Old 11-02-2014, 09:55 AM
Calaveras's Avatar
Quoted: 208 Post(s)
Liked: 106
What are you talking about? Where did I say anything about that?
Old 11-02-2014, 10:04 AM - Thread Starter
My DTV PAGE
I read it on your DTV Page.
I just wondered what kind or brand of antenna coupler it was???
Old 11-02-2014, 10:55 AM
Calaveras's Avatar
Quoted: 208 Post(s)
Liked: 106
Homemade nearly zero loss combiner for either UHF or VHF that uses a 1/4 wave matching section of 50 ohm coax to match two identical antennas stacked. It is not for combining a UHF and VHF antenna.
