Outdoor antenna works in every room except one... - AVS Forum
post #1 of 4 Old 11-30-2014, 12:12 PM - Thread Starter
sotwell's Avatar
I mounted an external ota on the roof and it is connected to my outside cable distribution box. In my den and bedroom I am using a Homework box and have a great signal in each room. One of these boxes has an AC adaptor plugged into the wall with a splitter which was provided earlier by the cable company.
My issue is my dedicated theater. I have the same homeworx box set up but the reception sucks. I can register the same channels but the reception constantly cuts out when it is fine in other rooms. Any idea why? Is there some type of amplifier I can add?
sotwell is offline
post #2 of 4 Old 11-30-2014, 12:20 PM
Ratman's Avatar
Quoted: 235 Post(s)
Liked: 315
Bad connector?
Compromised coax cable?
Need more detailed info in order to provide suggestions.
Ratman is offline
post #3 of 4 Old 11-30-2014, 12:27 PM - Thread Starter
sotwell's Avatar
I do not thin there is a problem with the box or cable. I have tried taking the homeworx box from my den (which works well) and tried it in the theater and still got the same bad reception. If all things are equal, why would one room's reception be bad when I have good reception in 3 other rooms?
sotwell is offline
post #4 of 4 Old 11-30-2014, 01:32 PM
ProjectSHO89's Avatar
Quoted: 73 Post(s)
Liked: 73
Then you have some sort of a cabling or splitter problem.
Use a temporary cable run to bypass ALL of the interior cabling and see if it works.
ProjectSHO89 is online now
Reply HDTV Technical
