Sun City Center, FL - Need Antenna Advice - AVS | Home Theater Discussions And Reviews
post #1 of 6 Unread Yesterday, 06:02 PM - Thread Starter
Quoted: 51 Post(s)
Liked: 3
Hello AVS Community,
I received great feedback and advice from the community here on my first OTA & Antenna experience last month. Based off everyone's recommendations I went with the CM-4221HD.
Now, I am back to obtain some advice for my parents who live in FL. They are looking to cut the cord as well. I am not sure what antenna would compliment their location and where it should be facing.
Below are the details of my parents location:
TVfool report: http://www.tvfool.com/?option=com_wr...f1f0463fff4422
Attitc: My parents have an attic in the garage. I have never been up there so I am not sure how big it is.
TV: Mitsubishi 73" 1080p 120Hz DLP HDTV
Towers: I am not sure if I have cellular towers near by.
If you need more information please let me know.
Thanks in advance for your help.
Curlyp is online now
post #2 of 6 Unread Yesterday, 06:57 PM
Calaveras's Avatar
Quoted: 375 Post(s)
Liked: 123
This should be about as easy as it can get. All their stations are really strong. A small antenna such as the ANT751 or HBU11 in the attic should get everything in the 32 to 40 degree range pointed at 36 degrees. Do not use a preamp. A distribution amp might be okay if the signal is split 4 or more ways. Don't bother for 2 ways.
Calaveras is online now
post #3 of 6 Unread Today, 05:46 AM - Thread Starter
Quoted: 51 Post(s)
Liked: 3
Thanks for the information Calaveras! If for some reason the attic above the garage is too small, where would you recommend installing the antenna? Or do you recommend a different type?
post #4 of 6 Unread Today, 07:41 AM
Calaveras's Avatar
Quoted: 375 Post(s)
Liked: 123
You're not going to get anything much smaller that's going to cover both VHF and UHF. How about mounting it on the roof?
post #5 of 6 Unread Today, 08:30 AM
Digital Rules's Avatar
Quoted: 69 Post(s)
Either of the suggested antennas should fit in most any tight spot. The HBU 11 is a great bang for the buck. I wouldn't suggest anything smaller since you have some VHF stations in the mix.
Digital Rules is online now
post #6 of 6 Unread Today, 09:43 AM - Thread Starter
Quoted: 51 Post(s)
Liked: 3
Thank you both.
I will contact my father and ask him to give me some estimates of the attic size. I am going down to visit next month, so I will setup everything then.
I'll keep you all posted on the results.
Reply HDTV Technical
