COMPONENT TO RGB CONVERTER - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-27-2001, 12:05 PM - Thread Starter
SMITHMURRA's Avatar
Help...Am looking for the name of the Company that sells a low end coupler which allows a progressive scan component in and outputs to RGB...
thanks
Paul Murray
Paul Murray
SMITHMURRA is offline
post #2 of 3 Old 03-27-2001, 12:11 PM
Marissadad's Avatar
Bettercables.com, click on the "Buy Online" link and go to "VGA and VGA Breakout" section.
"I want my HDTV Set!"
You measure your TV in INCHES? How cute! 9.16 Ft Diagonally, Yeah, Baby!
Marissadad is offline
post #3 of 3 Old 03-27-2001, 04:10 PM
obie_fl's Avatar
Liked: 33
The cable from Better Cables will not convert from component to RGB. To quote directly from their description:
"(NOTE THAT THIS CABLE DOES NOT CONVERT A VGA OR RGB SIGNAL TO A COMPONENT VIDEO SIGANAL!)"
What you need is an encoder I use the one from Key Digital and I believe Audio Authority just came out with one. Make sure you get the Component to RGB unit as both companies also make RGB to Component encoders.
Tom
obie_fl is offline
Closed Thread HDTV Technical
