LP Techshield and attic antennas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-11-2016, 06:43 AM - Thread Starter
Liked: 0
I am about to move into a home that is being built. It has a material on the roof called LP Techshield it is a metallic coating on the roof that helps a ton with heat.
I however have read this can negatively effect reception with my antenaa. Do any of you have any experience with this stuff and how worried should I be?
Clemsonalum07 is offline
post #2 of 5 Old 06-11-2016, 07:14 AM
Super Moderator
DrDon's Avatar
Quoted: 871 Post(s)
Liked: 1730
It will depend on how close to the transmitters you are. See the sticky note: NOTE: Put YOUR LOCATION in the TITLE of ALL antenna threads & TVFOOL info in 1st post
Meanwhile, here is an existing thread, albeit old, on the subject: In Attic Antenna and Radiant Shield Roofing(TechShield)?
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #3 of 5 Old 06-11-2016, 06:08 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Move your antenna to the outside, on top of your roof if you have problems with your attic antenna. We have a metal roof and have had no reception issues at all with our antenna mounted on the roof.
Otto Pylot is offline
post #4 of 5 Old 06-14-2016, 11:12 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If the aluminized coating is not grounded, would one be able to connect a wire to it, and use it as a giant antenna?
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #5 of 5 Old 06-14-2016, 02:34 PM
ADTech's Avatar
Quoted: 121 Post(s)
Liked: 65
No.
Tech support for Antennas Direct
ADTech is offline
Reply HDTV Technical
