A couple questions about splitters - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ProjectSHO89
post #1 of 3 Old 06-14-2016, 03:35 PM - Thread Starter
lmacmil's Avatar
Quoted: 76 Post(s)
Liked: 47
Planning to split my antenna signal between 2 TVs. Several questions:
1) What kind of upper Mhz range should I look for? All stations are UHF.
2) Does it matter where the splitter is relative to the antenna or the TVs?
3) Do I need a splitter that contains a preamp? I am only 8 miles from the towers but have lots of trees in the signal path. Total run will be less than 100 feet, probably closer to 75.
lmacmil is offline
post #2 of 3 Old 06-14-2016, 04:22 PM
ProjectSHO89's Avatar
Quoted: 288 Post(s)
Liked: 131
1. 700 MHz or higher. 5-1000 MHz is a common CATV splitter and works fine.
2. Probably not.
3. Probably not.
egnlsn likes this.
ProjectSHO89 is offline
post #3 of 3 Old 06-14-2016, 06:44 PM - Thread Starter
lmacmil's Avatar
Quoted: 76 Post(s)
Liked: 47
2. Probably not.
3. Probably not.
Thank you!
lmacmil is offline
Reply HDTV Technical
