Power supply for winegard AP-8275? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-13-2001, 12:28 PM - Thread Starter
dagman's Avatar
In my quest to perfect my terrestrial HDTV reception, I picked up a monster antenna and a pre-amp from a dead Dot Com (unfortunately, it was my dead dot com http://www.avsforum.com/ubb/frown.gif ).
The pre-amp is a winegard AP-8275 . . . but I don't have the power supply for it. Can someone tell me the specs of the power supply so I can replace it? I think all I need to know is the DC voltage that it injects. I wonder if I can use the power supply from my CM Spartan preamp.
I think the antenna is a D9000 . . . it is a beast. My neighbors are gonna love this one:
http://www.starkelectronic.com/d8000.gif
[This message has been edited by dagman (edited 05-13-2001).]
dagman is offline
post #2 of 5 Old 05-13-2001, 10:19 PM - Thread Starter
dagman's Avatar
Anyone? . . . . Beuller? . . . . Beuller? . . .
Surely someone must have a winegard preamp.
dagman is offline
post #3 of 5 Old 05-13-2001, 11:36 PM
Glenn_L's Avatar
How about this?
http://www.winegard.com/products/acc..._supplies.html
PS-9370 POWER SUPPLY (117 VAC IN/18 VAC OUT)
Replacement power supply for 117 VAC operation. Red indicator light indicates unit on. Polyfuse protected. Use with Winegard amplified antennas and preamplifiers only.
-Glenn
A-Tech Fabrication
Glenn_L is offline
post #4 of 5 Old 05-14-2001, 12:00 AM - Thread Starter
dagman's Avatar
Originally posted by Glenn_L:
How about this?
Thanks . . . that might be it but I'm not sure . . . that is described here as for the MS2000 http://www.consumerdirectonline.com/ps-9370.htm
and the MS2000 is one of their omni directional antennas: http://www.consumerdirectonline.com/ms2000.htm
I'll try emailing Winegard customer service.
dagman is offline
post #5 of 5 Old 05-15-2001, 06:11 PM - Thread Starter
dagman's Avatar
Well Winegard never responded to my email, so I just ordered that PS-9370 POWER SUPPLY because I think you are right.
After all, it did say "Replacement power supply for 117 VAC operation. [snip] Use with Winegard amplified antennas **and preamplifiers** only.
dagman is offline
Closed Thread HDTV Technical
