Sony HD100 Qaulity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-15-2001, 01:13 PM - Thread Starter
kevin44's Avatar
I am about to buy an HD Satellite for my Mits 46 HD ready and I love Sony Sats, but I have read a lot of bad posts on this product. Has anyone had a good experience with it? Can anyone tell me if the picture quality on all channels is a lot better when you connect an HD sat with to a Mits TV? I was told that everything looks better because it bypasses the internal line doubler in the TV.
kevin44 is offline
post #2 of 4 Old 05-15-2001, 02:02 PM
artshotwell's Avatar
I have the hd100 and am fairly happy with it. I have the problem where the picture blanks out at the top and bottom of the hour if I have a HD channel as my jump channel. Easy to work around, when I remember. Picture quality seems very good. I use it with component outputs to my Sony xbr400. Art
Art Shotwell
Anacortes, Wash.
artshotwell is offline
post #3 of 4 Old 05-15-2001, 02:25 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
My strong advise would be NOT to buy now but wait a few months until the firewire-based units start to appear
Did I miss something? Have any new Firewire STB's been announced? The forthcoming Zenith won't have Firewire and I'm not aware of any new STB's that will have Firewire. Why do you believe Firewire units are only a few months away?
Geof
[This message has been edited by Geof (edited 05-15-2001).]
Geof
Geof is offline
post #4 of 4 Old 05-15-2001, 07:32 PM
Peter Diaz's Avatar
I have the Sony sathd100 also. And I have a Mits Platinum plus 55" Hdtv rptv. I am very pleased with watching hidef on my Mits. It's like watching from a window. You won't go wrong with the Sony & Mits tv.
PeterDz
PeterDz
Peter Diaz is offline
Closed Thread HDTV Technical
