Dish Network Gray bars? Please help - AVS Forum | Home Theater Discussions And Reviews
Old 09-04-2001, 06:30 AM - Thread Starter
weatherby's Avatar
For some reason when I turned on my Dish 6000 last night there were gray bars on the sides instead of black. Also on the banner at the top when you view the channel Etc. it had the word "Gray Bar" over on the left hand side. It is on all channels and on the high def stuf rather then be wide screen it had the gray bars. I spent a half hour with tech support at Dish but he couldnt tell me how to get rid of it. Can anyone tell me how to get rid of the gray bars? Thanks.
Ed Weatherby
weatherby is offline
Old 09-04-2001, 06:52 AM
baimo's Avatar
Yikes! That was not a great CSR from dish.
Press the star button on the remote. It cycles through the diffeternt viewing modes such as STRETCH, PARTIAL ZOOM, ZOOM, NORMAL AND GRAY BAR.
baimo
baimo is offline
Old 09-04-2001, 09:32 AM - Thread Starter
weatherby's Avatar
Thanks very much. I will try it as soon as I get home. Knew it must be something simple. Too bad the csr didn't know this. Again thanks!
