Pioneer 3510HD Cable Box -- DVI out? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #61 of 67 Old 10-03-2003, 01:13 PM
Manatus's Avatar
Originally posted by dlalande
Just thought I would add to the mix. I can't get anyone from TWC or Pioneer to speak intelligently to this problem. I tried the pioneerbroadband.com website, but the contact pages have no Voyager Support phone numbers or emails. TWC couldn't even tell me if the DVI port was disabled or just incompatible.
Member --- Display --- Cable Co. --- Result
dlalande --- Samsung HLN507 --- TWC Los Angeles (Orange County) --- Error message *
Notes:
* Set equipped with DVI+HDCP
Error Message = a three-language black-&-white message indicating that the STB should be hooked up to high-definition television.
Take a look at a thread specifically devoted to the Pioneer 3510HD-Samsung DLP DVI incompatibility: http://www.avsforum.com/avs-vb/showt...hreadid=289334
Forsan et haec olim meminisse juvabit. -- Popeye
Passport 2.6.002
Samsung 500 GB SATA2 HD501LJ
Apricorn EZ-BUS-DTS-EKIT
Manatus is offline
post #62 of 67 Old 10-06-2003, 01:02 PM
dlalande's Avatar
Thanks... I looked in the rear projection threads before and didn't see it.
dlalande is offline
post #63 of 67 Old 10-24-2003, 07:35 AM
24amac's Avatar
i have a plasma tv with dvi and i fell into the same trap.....the error message that i need to hook it up to a hdtv.....my tv handles all hdtv formats
i just wanted to let anyone in columbus that the twcol 3510 box must not have dvi enabled as well....it really sucks
24amac is offline
post #64 of 67 Old 11-12-2003, 06:15 PM
UD#1's Avatar
I also have the same issue with DVI on the 3510HD. Error message its looking for HDTV when connecting to my 50PHD6UY. Time Warner in Dayton issued a DVI cable with the box. Per Post 61, has Pioneer fixed this problem yet. Only a problem with some HDTVs.
UD#1 is offline
post #65 of 67 Old 11-13-2003, 05:10 AM
gerhard911's Avatar
UD#1
You might want to check out the following thread:
Error message when connecting TWC's Pioneer 3510 STB and Samsung HLN via DVI.
There have been some recent posts.
UC#1 :p
gerhard911 is offline
post #66 of 67 Old 11-13-2003, 11:18 AM
sccofer's Avatar
anyone know how to get into "diagnostic" mode on this box? I can't figure it out.
sccofer is offline
post #67 of 67 Old 12-05-2003, 08:17 PM
ignatius's Avatar
I just ordered a Z2 projector (it has DHCP) and picked up my TWC 3510HD box today. My projector is supposed to arrive on Monday and so I will try DVI. I'm in Kansas City. Apparently many in KC have it working.
ignatius is offline
Closed Thread HDTV Technical
