Problem with Dish 6000 after 778 upgrade - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #61 of 70 Old 07-27-2003, 03:05 AM
Kermee's Avatar
I doubt, but could be wrong, the stuttering problem was due to over compression.
Over-compression means sending a stream that is at a lower-bitrate. How a lower-bitrate would create a stuttering problem solely on a 6000 receiver versus other units would not make sense. The only fault of an over compressed stream is decreased PQ and shouldn't induce stuttering.
My bet is the MPEG-2 stream wasn't compliant (e.g. They changed the MPEG-2 resolution on some of the channels) or was out of spec for the 6000's MPEG-2 decoder chipset which other receivers are able to handle fine.
But like all the previous replies, this is only a guess.
Cheers, Kermee
Kermee is offline
post #62 of 70 Old 07-28-2003, 06:46 AM
Foxbat's Avatar
Just got off the phone with a Dish CSR, evidently my replacement 6000 is backordered... I helpfully offered to accept a 921 instead, it would be a cross I could bear, take one for the company, etc., but no, I'll just have to wait.
I wonder if a bunch of 6000 owners flooded the repair depot with requests due to "the Stutters"?
--Roland
Foxbat is offline
post #63 of 70 Old 07-28-2003, 06:55 AM - Thread Starter
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
It would serve Dish right for having to replace a bunch of perfectly (kind of) 6K's just because they wouldn't admit for a long time they had a problem.
rad is offline
post #64 of 70 Old 07-28-2003, 07:51 AM
clapple's Avatar
Foxbat,
6000 back ordered? I thought it was no longer in production?
Red
clapple is offline
post #65 of 70 Old 07-28-2003, 07:59 AM
CycloneGT's Avatar
Quoted: 67 Post(s)
Liked: 44
The ones that they send out are likely refurbished and not brand new.
CycloneGT is offline
post #66 of 70 Old 07-28-2003, 10:09 AM
Sean_S's Avatar
I agree with you. It may be related to bandwidth-sparing issues, but not "over-compression". The higher the compression, the lower the bit rate and the less decoding. A slight incompatibility between the stream and the 6000's decoder, for whatever reason, seems very logical.
Sean
Sean_S is offline
post #67 of 70 Old 07-29-2003, 07:25 PM
Foxbat's Avatar
My replacement is up and running, and yes, it was marked as "remanufactured." The only visible difference I could see between my box and the "new" one is the lack of the Accessory jack on the replacement. I had to swap my 8PSK and 8VSB modules over to the replacement, no big whoop, and of course, I had to put all the local channels in, but it was pretty painless, all told.
Oh, and the stuttering channels are all gone;)
--Roland
Foxbat is offline
post #68 of 70 Old 07-31-2003, 08:12 PM
Foxbat's Avatar
Hate to resurrect the specter, but I'm seeing occasional "stutters" on Comedy Central tonight during "The Daily Show".
--Roland
Foxbat is offline
post #69 of 70 Old 08-01-2003, 05:59 AM
Russ Ingram's Avatar
The stuttering is gone, but I am back to a EPG that displays info not available for most of the future times. This issue seems to come and go.
It is a real irritant to me.
Russ
Russ Ingram is offline
post #70 of 70 Old 08-01-2003, 11:13 AM
RodneyK's Avatar
I get real tired of that, too.
RodneyK is offline
Closed Thread HDTV Technical
