What MoCA frequency bands do DirecTV and Dish use: E, F, or G? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-19-2017, 08:23 AM - Thread Starter
JHBrandt's Avatar
Quoted: 1797 Post(s)
Liked: 861
This is a seemingly simple question, but it's apparently also a massive secret! My guess would be that Dish uses band F while DirecTV uses E or G, but I can't seem to find out for sure! Does anyone know?
A Google search for "DirecTV MoCA frequency band" returns many pages but little more than very basic info. Yes, I know that MoCA added new, lower frequency bands for satellite TV use, since the original MoCA frequency bands conflicted with traditional satellite LNB frequencies. Yes, I know that poses a problem for the few of us who used to diplex satellite and OTA or cable signals. But MoCA added three different bands in the 500-850 MHz range, and it seems some limited diplexing may still be possible, depending on which band is used:
  • MoCA band E goes from 500-600 MHz
  • MoCA band F goes from 675-850 MHz
  • MoCA band G goes from 500-800 MHz
Obviously bands E and G are completely incompatible with OTA UHF frequencies, so the only OTA diplexing possible would be with VHF. But band F would allow UHF up to roughly 575 MHz (roughly OTA channel 30 or cable channel 80). So I'd like to know which systems use which bands, just to know what's theoretically possible.
JHBrandt is online now
post #2 of 6 Old 06-19-2017, 12:44 PM
holl_ands's Avatar
Quoted: 574 Post(s)
Liked: 253
Fol. "MoCA 2.0" and "MoCA 2.0 and 2.5, Aug2016" Specs define fol. Bands:
http://www.mocalliance.org/MoCA2/spe...cs-150406d.pdf
http://www.mocalliance.org/MoCA2/spe...cs-160808d.pdf
Band D (1125 MHz-1525 for CATV),
Extended Band D (1125 MHz-1675 for CATV),
Band E (400-700 MHz for DirecTV),
Band F (650-850 MHz for Dishnet),
There IS NO "Band G" defined in MoCA 2.0.
In searching I found that DirecTV uses Band E [overlaps OTA UHF Band]:
http://www.gizmolovers.com/2011/09/0...ere-one-at-all
And Dishnet uses Band F [of course....gotta be DIFFERENT, overlaps upper part of UHF Band [which is going away soon], so be careful choosing DVR's UHF "TV OUT" and may or may not be compatible with OTA Antenna via "SUPER HOME NODE" depending on OTA Freqs and occupied MoCA Freqs]:
https://forum.dish.com/viewtopic.php?f=18&t=18130
http://www.sadoun.com/Sat/Products/D..._Diagram_4.pdf [Incompatible with MOST CATV systems]
https://www.summitsource.com/Eagle-A...Kit-P8272.aspx
BTW: Just to keep things INTERESTING, they CHANGED the Band Designations from what they were in MoCa 1.0, where each sequential letter designates ever higher group of Frequencies, with the HIGHEST Freqs being "Old Band G" and "Old Band H":
http://www.mocalliance.org/MoCA1/spe...cteristics.pdf [Used in Very Early Devices.]
holl_ands is offline
post #3 of 6 Old 06-19-2017, 02:02 PM - Thread Starter
JHBrandt's Avatar
Liked: 861
Yes, I got "Band G" from the same MoCA 1.1 spec you linked above. It confused me because the frequency chart lists a "Band G" that overlaps bands E and F (and tunes in 50 MHz increments vs. 25 MHz increments for all the others), but there's nothing else in the spec about it! And naturally they had to reshuffle everything for MoCA 2.0. Thanks for the clarification.
Thanks! That's kind of what I suspected. Since Dish has those 2-tuner receivers with (analog, I think) UHF modulators for the second tuner, they probably wanted to reserve a chunk of UHF bandwidth so those would still work.
Anyway, upshot is, diplexing OTA could theoretically still work with Dish systems, especially after repacking; assuming of course someone is making (or going to make) new diplexers with the correct frequency cutoffs. (And here I thought repacking was a bad idea!) But diplexing OTA with DirecTV is hopeless, except perhaps for VHF.
Here's an off-the-wall thought: could you diplex the handful of VHF OTA channels with DirecTV using simple UVSJ's (assuming the DC pass-thru is on the UHF side) by putting the satellite signals on the UHF side and the OTA signals on the VHF side? Or is their performance too poor up in the 2GHz range for this to work?
post #4 of 6 Old 06-20-2017, 11:01 AM
holl_ands's Avatar
Quoted: 574 Post(s)
Liked: 253
ADTech measured Freq Response up thru 1000 MHz for A-D, Holland, Pico-Macom, and Radio-Shack VHF/UHF Diplexers (aka UVSJ) and didn't see ANY high freq anomalies. So it's worth a TRY to see if that hold true up on higher freqs...only thing that would limit it would be stray capacitance. DC PASS is on UHF Port ONLY for A-D and R-S....whereas for Holland and Pico-Macom it's ONLY on VHF port [inherent in a simple LPF Filter on that Port].
Yes, "TV OUT" on Dishnet DVR is Analog NTSC so that REALLY Old TV's [via RF R/C] could independently pull up one of the recorded programs...or take control of the DVR's SAT Feed. Alternative would be to buy/lease another Receiver or DVR.
post #5 of 6 Old 06-20-2017, 09:24 PM - Thread Starter
JHBrandt's Avatar
Liked: 861
I ordered a couple of the RS UVSJ's from eBay. They claim to work up to 1100 MHz. That's nowhere near 2150 MHz but they still sounded like the best bet, and they were only $7 each.
I do have a DirecTV installation I can try it out on (not my own, but my in-laws' guest bedroom). It'll probably be August before I'm up there to give it a try though.
Of course, given their location in Stroud, OK - about halfway between OKC (2 VHF channels) and Tulsa (3 VHF channels) - and that the .1 OKC subchannels are on DirecTV anyway, it's hardly worth the effort. But I've gotta satisfy my curiosity now....
post #6 of 6 Old 08-19-2017, 08:51 PM - Thread Starter
JHBrandt's Avatar
Liked: 861
Finally got the chance to try this. It actually does work, although it's probably not worth the effort unless there's a must-have subchannel on VHF in your area that DirecTV doesn't have. The DirecTV box works fine as far as I could tell, and I got two VHF channels from OKC and three weak ones from Tulsa.
I used the old Pico-Macom UVSJs. Those block power on the UHF side, so they are not recommended unless you are diplexing a non-power-carrying branch of your DirecTV "tree;" but that was the case in my in-laws' guest bedroom and I wanted the option of adding an antenna preamp to try to improve those Tulsa channels.
No time to do that tonight, though. Heading north to try to catch a glimpse of the total eclipse Monday.
Edit: I did get to watch the eclipse. BTW, if I were going to do this "right," I wouldn't bother with diplexing at all. I'd put the DirecTV box in the attic, along with a Next Generation RF system (so the remote control could still work) and an ATSC RF modulator. Then the whole DirecTV "experience" would merely be one extra channel along with all my OTA channels. Only problem is the modulator would make that solution rather expensive.
This was mostly a theoretical exercise: can I make diplexing work at all, even after DirecTV seemingly went out of their way to design a system that wouldn't allow it? (Dish's "Hopper" should still allow some UHF diplexing, especially after spectrum repacking, but not DirecTV's "Genie" system.) Turns out I can, FWIW.
Reply HDTV Technical
