Dish Network 811 News (Old topic - PVR 921, 811 & 5000 News) - Page 38 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1111 of 1126 Old 01-09-2004, 03:24 PM
Joe Q's Avatar
Originally posted by ismeltitudeltit
Can someone explain how the 811 is different than the 6k + 8vsb + 8psk?
It's newer and can not do RGB output.
Joe Q is offline
post #1112 of 1126 Old 01-09-2004, 05:54 PM
Chriscpm's Avatar
Quoted: 33 Post(s)
I just installed my 811 and the DVI is a disappointment. I have my 6000 on the 15-pin (graphics) input and the 811 on the DVI. The graphics input is clearly better. The DVI has visible motion and just isn't as good. The difference is about what I expected, just in the opposite direction.
Also, I though I saw mention of a problem with the 720p output. My 720p works fine.
My whole plan for the 811 was the DVI output. The 6000 sells used for more than the 811, so I though it was a safe bet, but now I don't know what to do. If Dish plans on patching this, I should stick with my plan.
Chris
Chriscpm is offline
post #1113 of 1126 Old 01-09-2004, 06:30 PM
Jetlag's Avatar
Here is my Dishnetwork CES experience to add to what Don posted:
921
Jetlag is offline
post #1114 of 1126 Old 01-09-2004, 07:06 PM
Don Landis's Avatar
Quoted: 1222 Post(s)
Liked: 327
Considering the confusion here- I will post any new information on satguys site.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is offline
post #1115 of 1126 Old 01-09-2004, 08:37 PM
visko's Avatar
Thanks for the post ....it confirms what I have been reading stick with the 6000 and 8VSB module.
Your post address a technical observation which is good for all of us to read.
visko is offline
post #1116 of 1126 Old 01-10-2004, 11:14 AM
Chriscpm's Avatar
Quoted: 33 Post(s)
Well, all is not lost. The 811 is buggy, but I have had some luck tweaking it.
First, I tried switching over to 1080i to see if that was any better (even though I have a 720p projector). It was really weird - the 811 produced 1980 x 540 on the DVI. Hmmm ... Back between 720p and 1080i a few times and the same deal.
Then I tried the component connection. It gave me the correct 1980 x 1080i and 720p signals. Hmmm. The back to the DVI and now I get proper 1980 x 1080 and 720p signals. Now going back to the original comparison between the DVI 720p on the 811 and the 720p on the 6000 through the RGB and they look pretty close - I think something was wrong on the original 720p signal, even though my projector reported the right number of pixels.
The good news (for me at least) is that the 811 does kick out DVI and component at the same time. I wasn't sure this exact combinations has been reported yet. For me it will let me pull a long component run to my bedroom (instead of a lowly composite signal).
Also, the component output of the 811 is not as good as the DVI of th 811. I have it set up now to switch between:
A-component from the 811,
B-RGB from the 6000, and
C-DVI from the 811.
I can switch between them with the inputs on my projector with only a 1 second or so delay. I'm waiting for some decent programming.
Now the joke of the day - what would dishnet put a label on the rg59 cable included in the 811 package that says it is only to be used between the receiver and a TV? First, it did work to extend my antenna signal. Second, the 811 doesn't have an output for this cable! ... If only George Carlin were on this forum ...
Chris
Chriscpm is offline
post #1117 of 1126 Old 01-10-2004, 11:29 AM
gpflepsen's Avatar
Quoted: 24 Post(s)
I'm guessing the RG59 can be used to hook the ANT out on most TV's to the 8VSB ANT IN on the 811. This way folks can utilize the better OTA analog tuner in the TV instead of the crappy OTA analog tuner in the 811.
But in actuality it's just a convenience and an included cable in a standard cable pack. If it's extra, put it up for sale on EBay. :)
gpflepsen is offline
post #1118 of 1126 Old 01-10-2004, 11:11 PM
Chriscpm's Avatar
Quoted: 33 Post(s)
The AFC game gave me a good chance to look at the 811. The motion problems were obvious with the names and numbers on the uniforms. Suprisingly, there are there for both the DVI and the component outputs. I'm really dissapointed and will try to return this box.
Chris
Chriscpm is offline
post #1119 of 1126 Old 01-11-2004, 08:29 AM
Rob Tomlin's Avatar
What is the current best offer by Dish for existing customers for the 811?
Rob Tomlin is offline
post #1120 of 1126 Old 01-11-2004, 09:43 AM
Chriscpm's Avatar
Quoted: 33 Post(s)
Mine was $399 shipped.
Chris
Chriscpm is offline
post #1121 of 1126 Old 01-11-2004, 09:50 AM
gpflepsen's Avatar
Quoted: 24 Post(s)
I still believe the 149/199 deal is available, but the product might not be.
post #1122 of 1126 Old 01-11-2004, 10:32 AM
Rob Tomlin's Avatar
Apparently I have missed out on this discussion.
What exactly is the "149/199" deal?
post #1123 of 1126 Old 01-11-2004, 10:38 AM
gpttigers's Avatar
Maybe it is your setup or the box itself. I had zero problems with the picture last night via DVI.
gpttigers is offline
post #1124 of 1126 Old 01-11-2004, 10:39 AM
gpflepsen's Avatar
Quoted: 24 Post(s)
post #1125 of 1126 Old 01-11-2004, 12:14 PM
LesMoss's Avatar
I had no "motion problems" last night via component. I have noticed motion problems on all HD channels when you have not chaged the channel in a long time (>8hrs) Simply changing to another channel and changing back clears the problem for me.
The reason I see this problem at all is that I never turn my 811 off to avoid the dreaded "check switch" problem.
LesMoss is offline
post #1126 of 1126 Old 01-11-2004, 02:23 PM
Chriscpm's Avatar
Quoted: 33 Post(s)
What type of display are you running. I'm running a 119 inch 16x9 projector, which will show more than even a big rear projection. I'm not sure if there is anything more I can do with the (box?) setup. Any suggestions?
Chris
Chriscpm is offline
Closed Thread HDTV Technical
