The Sony HD300 Is Here - First Impressions - Page 24 - AVS Forum | Home Theater Discussions And Reviews
Old 08-14-2004, 06:34 PM
sonofjay's Avatar
Sun spots are mostly only a fall and spring time issue if they affect you at all. If he had been getting signal fine before I would would suspect something else, multi-switch, lnb or cabling.
sonofjay is offline
Old 08-20-2005, 07:32 AM
thepicman's Avatar
Originally Posted by wmccain
I am happy to report that a TiVo can use serial control to change channels on an HD300. Connect the serial port of the TiVo to the "Data Port" of the Sony HD300 and configure the TiVo for the "APG" version of the DirecTV serial control protocol (the old "MPG" serial control does not work).
Curious as to whether your Tivo can turn on the HD300. My SVR2000 will change channels, but will not turn on the STB. Perhaps it is because I am using the alternate command channels for the HD300? I have it set to 51 as I also have another Sony STB and the remote was changin channels on both.
-TPM
thepicman is offline
Old 10-02-2005, 11:23 AM
pjf
pjf's Avatar
Does anyone know if this receiver can switch between watching HD via HDMI to SD with Component on Composite.
P
pjf is offline
Old 10-02-2005, 07:58 PM
Chris Loker's Avatar
The box will simultaniously output HD and SD. So you can watch SD via composite or S-video at the same time as your HDMI or Component HD. You can't output HDMI and Component at the same time (there is a switch on the back that toggles between these 2 types of output).
Chris Loker is offline
Old 10-02-2005, 08:48 PM
mjones73's Avatar
Can't output HDMI at all, this box has a DVI output.. :)
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
Old 10-02-2005, 09:15 PM
console's Avatar
Quoted: 163 Post(s)
Liked: 34
and, for whatever reason, a DVI > HDMI cable will not work with this receiver.
console is offline
Old 10-03-2005, 06:03 AM
pjf
pjf's Avatar
Thanks for the quick reply.
I have this unit and I am happy with it. I am using a DVI to HDMI cable to my RP LCOS TV and it works fine.
SD does not look all that great via DVI so I am hoping that with S video it will soften the picture up and not show all the flaws of SD on a HD set
P
pjf is offline
