Hughes HTL-HD! - Page 34 - AVS Forum | Home Theater Discussions And Reviews
post #991 of 1251 Old 04-13-2004, 03:27 PM
dumdum's Avatar
Does anyone get a slight bounce or jumping when using DVI if so how do you stop it? It is very annoying when trying to watch a program and the pitcher keeps bouncing up and down. (I am using the HTL DVI to Samsung HDTV)
dumdum is offline
post #992 of 1251 Old 04-13-2004, 07:31 PM
Chilli_Dog's Avatar
Can anyone tell me if there is a difference in picture quality using the DVI connection on the HTL connected to the Wega III compared against the component connection option from the HTL?
I did a very quick comparison this evening between component and DVI with my HTL-HD and Wega III. In most cases, the difference was negligible. DVI looked slightly better on a couple of channels, and about equal with component on the rest. Just my opinion, though. The only way you're really going to know is to do the comparison yourself.
Got any friends with an extra set of component cables that you can borrow?
Chilli_Dog is offline
post #993 of 1251 Old 04-13-2004, 07:33 PM
Chilli_Dog's Avatar
Does anyone get a slight bounce or jumping when using DVI?
I'm using DVI with my GWIII. So far, I have not noticed any bouncing or jumping at all...
post #994 of 1251 Old 04-14-2004, 06:03 AM
chrisdow's Avatar
Originally posted by ChrisW6ATV
DVI but no RGB/VGA? What a shame.
I know you posted this a while ago but I was planning on ordering the new D*Tivo Hughes box BUT noticed that in this Hughes Box(HD-HTL) the DVI out would not be capable of DVI-D (as opposed to DVI-I), & therefore I can't get a cable to convert DVI to MY RGB/VGA display. I assume the new box will have the same DVI output.
Have you found anything that can work?? BTW, using component on my display only can display 480p. Thanks...:mad:
chrisdow is offline
post #995 of 1251 Old 04-14-2004, 06:33 AM
corinthbandit's Avatar
Thanks for the feedback. Sounds like I don't need to worry about component cables right now.
corinthbandit is offline
post #996 of 1251 Old 04-14-2004, 07:44 AM
dan57's Avatar
I am getting frustrated with this box locking up. It sometimes even resets itself when the power is OFF. Huh? It's annoying, because when this happens, I have to hide all the unwanted channels again. This seems to happen every week or two. Anyone else having this problem, or is this a defective box? Do you think the supposed firmware update will remedy this?
dan57 is offline
post #997 of 1251 Old 04-14-2004, 08:01 AM
Bmann_30's Avatar
If the box is locking up on you take it back. My first one was garbage! My second one is great and never had all the lock-ups and audio droup outs like I had on the first one. My first one was the same 1.07 firmware so I believe there are some lemon boxes that are identical but just for whatever reason messed up.
Bmann_30 is offline
post #998 of 1251 Old 04-14-2004, 08:07 AM
UHD Addict
aaronwt's Avatar
Quoted: 5358 Post(s)
Liked: 3218
I'm glad they sent me the Samusng 360. It has worked perfectly for 5 weeks now.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #999 of 1251 Old 04-14-2004, 08:11 AM
Gary16's Avatar
Quoted: 43 Post(s)
My Hughes HTL-HD has been in service for several months and has only locked up twice (and not at all in well over a month). This still has the original 1.06 with no updates. My Samsung 360 is suffering from intermittent dropouts and some "745" messages but operationally is preferable to the Hughes. PQ-wise I think they're pretty much comparable and both excellent on HD signals.
Gary16 is offline
post #1000 of 1251 Old 04-14-2004, 08:17 AM
eye_candy's Avatar
I'm going to be getting this HD box soon.
Overall how happy are you with the unit?
How is the PQ with D* and OTA HD?
Do you always get 5.1 DDigital with HD program?
sony CRT.... haven't seen a better pic yet!
eye_candy is offline
post #1001 of 1251 Old 04-14-2004, 08:34 AM
UHD Addict
aaronwt's Avatar
Liked: 3218
HD programs are in DD. It could be 2.0 or 5.1
post #1002 of 1251 Old 04-14-2004, 10:45 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Well, I got the HTL replacement from D* yesterday and immediately disconnected the crappy Samsung 360 they sent me to replace the first HTL. It is the same build date (12/03) as the first one and same firmware revision (1.07). So far, I haven't heard a single audio drop-out. Also, I could just be imagining it, but the overall sound on this unit (I use the optical out) sounds better to me than the first HTL they sent. I think that one must have just had a damaged audio subsystem or something. PQ is excellent. So far, so good.
Brandon A. DuHamel
Founder & Editor-in-Chief
TheaterByte
GoldenBoy is offline
post #1003 of 1251 Old 04-14-2004, 03:55 PM
Ray H's Avatar
A thought or two about the anxiously awaited 1.10 firmware update. DirecTV might not be able to slip this update into the data stream for a couple of weeks. Accoring to SatBizNews, and fleshed out on DBS Forums today, DirecTV began the shutdown of the P3 (HU card) video activation packets yesterday. It's to go in phases to allow remaining HU card subscribers to "get the message" to install their new cards without the shock of a total loss of programming in one fell swoop. (also prolongs the agony for the pirates...) DirecTV may wait until the card swap is finalized April 27 before radiating 1.10 in the ether.
Here is the shutdown schedule, as it was reported on DBS Forums: (Note that PPVs, HD, and porn were allegedly taken out of the HU realm yesterday - can anyone still running a P3 card confirm this?)
4/13 Music Choice 800-821, 823-838,840-850
4/13 Para Todos 406-450, 452-499
4/13 Fox Sports Regional Networks 620-654
4/13 Adult PPV 594, 596-598
4/13 HD 73-100
4/13 PPVs 100-199
4/14 Premiums East 501,202,507,513,520,522,528,537,544
4/14 Core 1 (news religion...) 366-377, 337-358
4/16 Regional Sports Networks 2 601-612
4/16 core2 (266-271, 282-287...) 266-271, 282-287, 291-295, 300-315
4/20 Seasonal Sports 700-799
4/20 Core 3 230-244, 297-298,276-279,207-212
4/21 Preimum Specialty 545-550, 523, 527-533,538-542
4/21 Core 4 248-265, 321-329, 333
4/22 Final1 822, 839, 595, 521, 514, 508, 505, 504, 503
4/23 Final2 402, 404, 335, 331, 317, 299, 296, 290, 280, 273, 224, 229, 203,204
4/27 Final3 360, 362, 245, 247, 202, 206
4/27 Locals/Distant Networks various
Nachos 'n Suds - Breakfast of Champions!
Ray H is offline
post #1004 of 1251 Old 04-14-2004, 05:28 PM
AztecRol's Avatar
I am VERY happy with this rec!! I have had no problems to speak of.
The PQ is VERY GOOD on DTV. The OTA tuner is very strong, stronger
than the Sam 160 I had before. The picture on it looks good too. I am
using the component out of the Hughes to RPTV. I have been using
Vari 1 out of the Hughes to my TV. Once in a while, I will switch one of
the 1080i brodcasts to 720P. You will have to experiment with yours
to figure out what you like.
NOT all the HD is in DD. HBO is really good about it. Some of the Prime
Time OTA stuff is too. I would say that I get about 50% of my HD
programming in DD.
Let us know when you get your rec and how you like it!!
AztecRol is offline
post #1005 of 1251 Old 04-14-2004, 08:08 PM
Ledzep77's Avatar
I was changing the primary network trying to pull stations from other areas in. Somehow now for some reason I can't lock onto some signals that are very close to me. Is there a way to reset the OTA tunner to start from scratch? I tried a scan without the antenna connected but it didn't solve the problem.
Ledzep77 is offline
post #1006 of 1251 Old 04-15-2004, 08:35 AM
Ray H's Avatar
If I understand your post correctly, I don't think a scan sans antenna could be successful. (duhhh...) Try scanning again with your antenna connected. If you then want to add known other channels that the scan missed, there is a menu option to manually add individual channels to the list. Keep in mind that some stations do not run their digital xmitter full time. Maximizing the number of active channels in your receiver's list is most likely in the prime time viewing hours.
Ray H is offline
post #1007 of 1251 Old 04-15-2004, 08:35 AM
eye_candy's Avatar
I just bought it last night.
I'm having D* installed a week from this Saturday. So i'll let you know how the Hughes is.
I checked the production date on the back and it says JANUARY 2004. Do you think it will have the newest software? How can you tell?
post #1008 of 1251 Old 04-15-2004, 08:59 AM
leesweet's Avatar
I think we're talking about several things on the 'scanning for OTA'. If this box is the same as my Sony 300 (and it should be), it does NOT scan for OTA digital. It gets that info (channel list) from your zip code and the selection you picked after that (where it gives you a list of cities) for that zip's area. The cable and analog channels *do* do a classic scan of the channels to see what's out there.
To reset the OTA channels, I think the method is to put 00000 in for both zips.
Or is the HTL that completely different from the Sony? (I have a hard time with that one...)
-Lee (See my profile for equipment.)
leesweet is offline
post #1009 of 1251 Old 04-15-2004, 08:59 AM
Ray H's Avatar
Your user manual details the various menu options, so thumb through it. It'll include the map to verify which firmware revision is currently on your new receiver. With a build date of January, you won't have a version earlier than 1.07. (1.07 started shipping with November build dates.) A few Sony HD300 and Hughes HTL-HD owners have already indicated their receivers arrived with revision 1.10 installed. The rest of us should be receiving firmware revision 1.10 by way of a data stream download sometime by the end of spring. Receiving data stream firmware updates is NOT contingent on having a land-based phone line connected, but connection to a properly oriented dish is definitely necessary. The receiver MUST be plugged in, but may be left "on" or "off'*. Like phone line PPV billing updates, data stream firmware updates typically take place during the wee hours when interruptions to viewing are least likely.
*DirecTV receivers are always powered up when plugged into an active electrical outlet. Turning the receiver "off" at the receiver or the remote merely kills the video and audio outputs and extinguishes the pilot LED or channel/mode display. In the case of the HTL-HD, "off" mode also illuminatates a red "standby" logo.
Ray H is offline
post #1010 of 1251 Old 04-15-2004, 09:20 AM
Ray H's Avatar
Interesting. My Hughes HTL-HD did an initial OTA scan the first time it was powered up. It picked up all the analog and digital stations I was aware of (and several I wasn't aware of) at my location. I never did input my zip code since my dish was previously properly oriented. Until your post above, I was under the impression the only reason to input a zip code was to obtain the dish aiming parameters. Since some have posted that the LG, Sony, and Hughes user manuals are identical except for front cover product name, I'm curious where you came by your information.
Ray H is offline
post #1011 of 1251 Old 04-15-2004, 09:22 AM
HDDJ's Avatar
Originally posted by HD_JUNKIE
Well, maybe not so soon since D* canot seem to get off their backsides and release that darn firmware!!!!!!!!!!!!!
Come now! What do you think D* is doing? Just sitting around & purposely torturing us? We are but a small minoroty of their clients. By the way, I am interested to know who this "D* approval Engineer" is & where they are located.
HDDJ is offline
post #1012 of 1251 Old 04-15-2004, 09:29 AM
badrich94's Avatar
Is there no way to download this firmware and uload ourselves via the RS232 connection in the back?
- Richard
badrich94 is offline
post #1013 of 1251 Old 04-15-2004, 09:31 AM
HDDJ's Avatar
Last I heard D* had V1.11 in their test lab. How much longer we have to wait is anyone's guess.
If enough consumers called D* and demanded a partial month credit for audio loss then I think that would help motivate them to release the new firmware. Heck, even if V1.11 has a problem or two outstanding, at least they can address the bulk of the issues people are complaining about...
Where do you get this info? Not very accurate but who knows which source is correct.
HDDJ is offline
post #1014 of 1251 Old 04-15-2004, 09:46 AM
HDDJ's Avatar
Your local channels are actually determined by your Billing address. If you are authorized for local channels & D* has the correct address you are authorized for the locals.
HDDJ is offline
post #1015 of 1251 Old 04-15-2004, 10:16 AM
sonofjay's Avatar
They are talking about OTA locals which has nothing to do with the billing address that DirectV has and *not* DirecTv locals
sonofjay is offline
post #1016 of 1251 Old 04-15-2004, 10:23 AM
sonofjay's Avatar
The Zipcode(s) you enter during the channel setup are used to pull channels that D* have believe you can get OTA locally. It is also used to populate the APG with program information. If you did not put in a zipcode then most likely all your OTA channels in the APG say "Regular Scheduled Program" instead of the actually program name.
sonofjay is offline
post #1017 of 1251 Old 04-15-2004, 10:34 AM
Ray H's Avatar
Yes, that's exactly what all my OTA stations, digital and analog, say. So, if I input my zip code and force another scan, are you saying that my area stations will then be indicated with the program names in the Guide? By the way, what's the purpose of a "secondary" zip code?
Ray H is offline
post #1018 of 1251 Old 04-15-2004, 10:40 AM
Buckett's Avatar
Hi.
I will be purchasing a HTL-HD next week. I also have a Hughes DirecTivo HDVR2 that I will be using on the same TV. If anyone else has these same 2 units, could you please tell me if you have any remote control interference (controlling one unit affects the other).
I assumed that there would be no problems, but I wanted to make sure before I plunked down the money.
Any help or input will be greatly appreciated.
Thanx.
Buckett is offline
post #1019 of 1251 Old 04-15-2004, 10:49 AM
h_a_h_3's Avatar
*IF* your local stations have correct information from Tribune Media - you can check at zap2it.com - then yes you will have OTA program guide info after entering your zip code. My digital OTA info isn't all there, and I am waiting for TM to respond to my feedback email or change the guide info appropriately.
The secondary zip code is for people who can receive stations from two market areas, common example being midway between Washington DC and Baltimore. Each individual zip code is apparently assigned no more than one affiliate per network using maps, they don't send someone with an antenna and receiver to each zip to check what stations you can actually receive.
h_a_h_3 is offline
post #1020 of 1251 Old 04-15-2004, 11:04 AM
leesweet's Avatar
Exactly. It's *not* a 'scan'. The list is pulled from the sat using zap2it data, and you get all the info that way from the zip(s) you put in. Many people here are between Wash and Balt and/or have good enough OTA antennas to get both markets. For instance, I put my 20152 zip in, and get a list of over 6 (I never counted) possible markets (from WV to VA to DC). I pick DC. For Balt, only one shows up. I have a lot of stations I can't get, but they are all there with guide info on the sub channels and the analogs and the D* locals also.
No OTA digital scan at all. Cable/analog scan, yes (for my Sony 300, which better be the same as the Hughes! :D )
* Why use Wash *and* Balt? Usually use Wash stations as closer, but Balt ABC has DD5.1, for one example.
leesweet is offline
Closed Thread HDTV Technical
