LG LST-3510A DVI/DVD/HDTV Impressions - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 1186 Old 01-04-2004, 08:21 PM
Elder-D's Avatar
No problem, it is not an intuitive setting, considering the fact that there are 3 PCM settings to confuse things. Trial & error got me where I needed to be--DTS functional.
I never even heard of the LG 3510A until I lurked at this forum. It works quite well on the 60" GWIII WE610.
Elder-D is offline
post #182 of 1186 Old 01-05-2004, 06:34 AM
cpcat's Avatar
The same happened to me. If you select "stream" it will provide DTS or DD.
Selecting "Dolby Digital" will disable DTS. It shouldn't matter whether 96 khz or 48 khz is selected as DTS will not provide sampling rates of >48khz.
If your receiver can accept signals of 96khz leave it at 96 but only uncommmonly would this come in to play (Some audio DVD's from Chesky
I think have 24/96 material).
Charles
cpcat is offline
post #183 of 1186 Old 01-05-2004, 08:16 AM
RAVEN56706's Avatar
34xbr800 and 3510a
So far very good. Great signals with the OTA Tuner
Dvd's look excellent in 1080i.
Viewed so far:
S.W.A.T
Spiderman
Pearl Harbor
Star Trek VI
2011 SUPERBOWL CHAMPIONS- New York Giants!!!
Gamertag: GENERAL CUPKAKE
RAVEN56706 is offline
post #184 of 1186 Old 01-06-2004, 08:59 AM
GarryM's Avatar
Petey,
I too have a DVI challenged TV.
I've recently purchased a DVD +R/+RW drive, and XCopy. Making a backup copy of my movie allows me to watch it at 720p or 1080i. A good compromise for now - at least until I'm able to get a new TV. I'm probably not seeing all that a DVD at 720p or 1080i can produce (Xcopy will compress to fit on one disc), but the picture looks great. I've done three movies: Gladiator, Nemo, and Fifth Element - all worked. So, I'll buy RW discs, and then just make copies of the movies I want to watch. 480P looks great also, so I don't plan on doing this for every movie. Spending an extra $100 over a OTA-only box seemed like a resonable price to "play."
BTW - you have to set the output to either 720p or 1080i. In native or variable, it defaults to 480p.
Garry
Garry
GarryM is offline
post #185 of 1186 Old 01-09-2004, 06:12 AM
bfdtv's Avatar
Reposted from DVD forum....
I finally got around to trying my LG 3510 this afternoon.
I found it very troublesome at first as I kept getting the HDCP unsupported message on my Samsung DLP (HLM upgraded), and thus I could not view my DVDs in 720p or 1080i over the DVI connection. A few minutes ago, however, I tried again and everything was working fine with DVI. Hopefully, that behavior will continue...
The picture on DVD--now that DVI is working--appears comparable to that on the D1 (better than Samsung 931).
From a usebility standpoint, I hate how one must use the front panel on the unit to change inputs and resolutions. Discrete remote codes are available for 480p, 720p, and 1080i, but they don't work in DVD mode, so one must revert back to DTV mode to change resolution. With my Samsung DLP, the 3510 forgets the last configured resolution and resets to 480p every time I turn it on. The unit always starts up in DTV mode, which can be a minor annoyance if you intend to use it primarily as a DVD player.
As far as cable and ota...
Off-air reception is excellent. I like that a signal strength meter is available at the touch of a button. I also like how the 3510 lets you label channels with logos.
The 3510 will search, find, and display OTA channels in a guide, but I have been unable to select and tune channels from this listing. Whenever I select a channel in the guide, all I get is more channel info. This behavior is unlike any set top box I have ever used. What good is a channel guide if you can't tune channels directly at the press of a button?
As far as cable, I was dismayed to find that the 3510 could not display a guide for the channels it found on Comcast Cable. It found about 15 digital channels in a search (including the HD locals and InHD channels), but it won't display them in a guide or listing -- I have to switch among them manually with +/- (or a surf button). That said, the picture on these cable channels is an improvement (noticeable, but not drastic) over that seen on the SA3100HD.
bfdtv is offline
post #186 of 1186 Old 01-09-2004, 06:57 PM
kenhdtv's Avatar
Quoted: 16 Post(s)
bf, there is rumor of a firmware patch in final testing to address DVI issues like the 480p reset issue.
Ken
kenhdtv is offline
post #187 of 1186 Old 01-12-2004, 01:03 AM
rubix's Avatar
I have the same (unanswered) questions as goddahavit.
How does the 5130's DVD quality compare to a player with the Faroudja chipset? What deinterlacer does the 5130 have anyway? Does it pass the chroma bug test?
Also, how good is the 5130 for RPTVs with DVI?
I have Toshiba 57H83 RPTV and a Denon DVD-1600 DVD player.
rubix is offline
post #188 of 1186 Old 01-12-2004, 04:54 AM
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 77
Originally posted by rubix
...I have Toshiba 57H83 RPTV and a Denon DVD-1600 DVD player.
I have done some tests comparing it to an XP30. I see no reason to switch on my TVs. I would keep the Denon unless you see something on test patterns or movies that are a problem with the 480p component inputs that could be resolved another way.
umr is offline
post #189 of 1186 Old 01-12-2004, 08:57 AM
rubix's Avatar
Alright, so the 720p and 1080i and DVI output doesn't make a difference on RPTVs really?
I guess I'll get the LST-3100A and save some money.
rubix is offline
post #190 of 1186 Old 01-12-2004, 09:24 AM
DTV TiVo Dealer's Avatar
LG has just notified me that my orders are on hold as they are in the process of upgrading all LST-3100A's and LST-3510A's with new firmware patches. The upgraded inventory will be available next week.
DTV TiVo Dealer is offline
post #191 of 1186 Old 01-12-2004, 09:39 AM
jckessler's Avatar
Any information as to what the firmware upgrade fix/improve?
jckessler is offline
post #192 of 1186 Old 01-12-2004, 09:39 AM
stephenfrancis's Avatar
Very nice! Now a few questions:
1) Will the firmware upgrade fix the Z2 HDCP communication error?
2) How will we know before we order/purchase if the firmware has been upgraded?
Regards
Steve
stephenfrancis is offline
post #193 of 1186 Old 01-13-2004, 01:56 PM
RAVEN56706's Avatar
I just got off the phone with a CSR rep at LG, she knows nothing of this update.
Who at LG notified you?
post #194 of 1186 Old 01-13-2004, 03:39 PM
nealy39's Avatar
I spoke to LG's Customer Service yesterday and some lady told me the same thing. Unfortunately, she sounded like she didn't know anything about anything period. She told me that they have never had any complaints about that unit. I prodeeded to pick mine up at UPS anyway. Hopefully they will provide a way for users to perform the upgrade eventually.
nealy39 is offline
post #195 of 1186 Old 01-13-2004, 04:27 PM
KornerKlub's Avatar
CSR reps will always be that way. Why would they be kept in the loop until a update is ready? They are not. If they were, they would get the same people calling over and over asking when the update is ready. CSR reps would not really be notified until the update is released.
KornerKlub is offline
post #196 of 1186 Old 01-13-2004, 04:49 PM
I can not revel my sources. Only kidding, I know from engineering management, the LG/Zenith STB product manager and my LG/Zenith sales manager. The upgraded products should ship later this week.
Two of my orders are held up and when they are released I'll be well stocked for the first time since these boxes became available.
I do not know all of the upgrades, but one is the auto DVI reset issue.
post #197 of 1186 Old 01-13-2004, 05:17 PM
Mac The Knife's Avatar
Liked: 24
Well, I think the receiver in my 3510 partially died.
I can only get about half the channels I used to get. I've unplugged and rescanned. I've tried different antennas. I've called the broadcasters. No go.
Does anyone have any other advice before I box this sucker up and send it in?
Mac The Knife is offline
post #198 of 1186 Old 01-14-2004, 10:19 AM
RAVEN56706's Avatar
did anyone find out if it was true or not?
post #199 of 1186 Old 01-14-2004, 04:31 PM
KornerKlub's Avatar
It is true.
post #200 of 1186 Old 01-14-2004, 05:13 PM
Quoted: 1634 Post(s)
Liked: 695
Check with others in your area. It doesn't make any sense that you would only get some of the stations.
By the way, you mentioned that you changed antennas. What exactly did you do?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
post #201 of 1186 Old 01-14-2004, 07:52 PM
Mike191's Avatar
Quoted: 18 Post(s)
So is this also part of the current firmware update that LG just finished? Is the 3510a also out of stock so anything received should be the new firmware?
Mike
Mike191 is offline
post #202 of 1186 Old 01-15-2004, 12:21 AM
Liked: 24
The 3510 is normally connected to a roof mounted YAGI, but I also have a plain indoor antenna (VHF rabbit ears and UHF loop).
When I first setup the 3510, I used the indoor and the 3510 found all the local HD channels, so I decided it was senitive enough to work for me. I then switched it to the roof-mount antenna and rescanned, with identical results.
Reception was fine for about two weeks, but last Sunday I couldn't receive a couple of stations. That's when I disconnected the power and rescanned and then swithed back to the indoor antenna and rescanned and generally just tried everything I could think of.
On Monday, I started calling all the broadcasters to confirm that they were up and that they didn't change their power output or their PSIP data or any other changes to their signals.
I also got my first HDCP message yesterday, even though it is connected to an HS20 DVI port which is set to Video GBR.
Today, I've gained back one station, picked up a station in Tolleson (which I never used to get because it is in a different direction than South Mountain) and I lost another station that has always had good signal strength. This 3510 is just acting flaky as hell.
post #203 of 1186 Old 01-15-2004, 04:33 AM
Liked: 695
Mac The Knife
Just a distant 3rd party observation, you need to find someone local that has a HD OTA system to compare notes to. The people at the stations that you're talking to may never admit what's going on or maybe don't even know what's going on. Some reception may be just boardline such that weather may impact it. My PBS reception is remarkably good at times, then for no obvious reasons, goes crazy, fluctuates and just disappears. The station would not admit to this, but someone I met through AVS forum that lives a few miles from here, confirmed this behavior.
As to your HS20 giving the HTPC message, I'm assuming that you've used it before and didn't get this message. Some DVDs, (Disney comes to mind) has an extra layer of copy protection that might give you this message when other DVDs don't. If you've got the Avia DVD, try it. If I recall correctly, they don't use any copy protection on it as to take away from picture quality. If you still get the HDCP message, then I'd say you've got a problem that needs fixing.
Let us know what's happening.
JimP is online now
post #204 of 1186 Old 01-15-2004, 07:18 AM
GarryM's Avatar
Mac the Knife
I too live in the Phoenix area (Tempe - Rural/Warner), and lost Channels 3 and 5. I got 5 back, but not 3. I've rescanned several times. It can find 3 during the scan, but then gives a "no signal" when tuning it in. This happened in the last week or so.
So I too am stumped. I don't watch much content on 3, but having 5 (CBS) mysteriously go out and come back is not very comforting. I have not tried to power down the unit. I do have access to a 3100A and a very old Samsung unit, so this weekend I will be seeing what stations they can/cannot tune as a comparison. If the both have the same problem as the 3510A, then I'm likely going to suspect that something is up with the transmitters on South Mountain.
Cheers!
Garry
GarryM is offline
post #205 of 1186 Old 01-15-2004, 08:09 AM
RAVEN56706's Avatar
Originally posted by KornerKlub
It is true.
i just called again.... and they know nothing...... not a clue about the firmware patch
post #206 of 1186 Old 01-15-2004, 10:45 AM
dozens's Avatar
Call 877-993-6484 and keep calling until to Lauren answers, she is the only one with clue about the firmware update. Tell her your problem (auto reset, hdcp, etc) and get a case# so the next time you speak to someone without a clue then can reference your call.
I just called and luckily spoke with Lauren. She said she was going to talk to engineering and give me a call back around 5pm.
dozens is offline
post #207 of 1186 Old 01-15-2004, 12:30 PM
RAVEN56706's Avatar
i have a 3510a but are they sending out a cd with the firmware update
post #208 of 1186 Old 01-15-2004, 04:14 PM
KornerKlub's Avatar
Uh.... the update will not be on a CD.
post #209 of 1186 Old 01-15-2004, 04:36 PM
dozens's Avatar
I was led to believe from LG that the update would be on CD/DVD. Popping in a CD/DVD is the easiest way for the customer to update his own player.
dozens is offline
post #210 of 1186 Old 01-15-2004, 04:53 PM
Liked: 695
also makes it very hackable. lol
JimP is online now
Reply HDTV Technical
Lg Lst 3510a Hdtv Receiver Hi Format Dvd Player
