TWC HD and cable line filter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-14-2003, 06:54 PM - Thread Starter
ksmyth's Avatar
I have a neighbor that has a nice HT setup with a TWC HD box. Unfortunately he has a buzz that comes out of his speakers. The company that set his system up put some filter in the cable line which fixed the audio noise but caused the HD channels to pixilate or all together fail. I haven't dealt with cable for years but told him I could come here and find someone that might know what type of line filter he would need between his feeder line and his cable box. Is this a common problem? What kind of filter can he use that will fix the buzz yet let HD through?
thanks in advance...
ksmyth is offline
Closed Thread HDTV Technical
