The Master Samsung 360 topic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2208 Old 02-10-2004, 05:28 AM - Thread Starter
patrickpiteo's Avatar
Quoted: 30 Post(s)
Liked: 32
I am only getting channel information on some (not all) OTA channels. Any idea with this one. Some have information such as CBS and couple NBC and ABC do not. I live in New York. I just recently had the 160 swapped out for this 360. Any ideas....
UPDATE THERE IS A FIX:
- Hold menu and right arrow
- Choose commands, default settings
- Re-detect dish
- Go to local networks in the menu and enter zip
- In the list of cities displayed select the right one and push select
patrickpiteo is offline
post #2 of 2208 Old 02-10-2004, 07:42 AM
Tonedeaf's Avatar
Did you plug in your Zip code in the setup menu? This will also get you guide info for your locals OTA.
Hope this helps.
Tonedeaf is offline
post #3 of 2208 Old 02-10-2004, 08:02 AM - Thread Starter
Quoted: 30 Post(s)
Liked: 32
Hope this helps.
Yea tried both ways: zip code and also digital channel scan. I just spoke to a Samsung tech. He said give it 48 hours. If I still have the problem to call back. The box is so new and they are just getting people calling about various enhancements (bugs). He said this might be one.. LOL
post #4 of 2208 Old 02-10-2004, 08:12 AM
freeness's Avatar
Did you set up the dish settings yet? I had the smae problen on my 160 when I tried to do the OTA before the D* set up.
Andy
freeness is offline
post #5 of 2208 Old 02-10-2004, 08:21 AM
vvrok's Avatar
Yeah, I think this is the issue. I also received TS360 last Friday and installed it with my OTA antenna in the attic without waiting for DirecTV guys to install the new dish. I just could not resist . So, I am watching OTA HD-locals right now (without the dish) and I also don't have programming info.
vvrok is offline
post #6 of 2208 Old 02-10-2004, 08:37 AM
DMOODY's Avatar
I called D* today to replace my TS 160.....What do you think my chances are to receive the TS 360...Tks,Don
DMOODY is offline
post #7 of 2208 Old 02-10-2004, 08:42 AM - Thread Starter
Quoted: 30 Post(s)
Liked: 32
Originally posted by freeness
Did you set up the dish settings yet? I had the same problem on my 160 when I tried to do the OTA before the D* set up.
Andy
D* all set up. All channel information is present for all D* channels and some OTA digital HD channels. About half have no information. Real weird...
post #8 of 2208 Old 02-10-2004, 08:42 AM
chrome's Avatar
what did they say when you got off the phone with them?
chrome is offline
post #9 of 2208 Old 02-10-2004, 08:46 AM - Thread Starter
Quoted: 30 Post(s)
Liked: 32
I had my 160 replaced with the 360 just yesterday..
post #10 of 2208 Old 02-10-2004, 08:48 AM
BK EH's Avatar
While I can't speak directly to your problem now, if you only use the unit w/ OTA and no dish, you will only get guide info from those stations that send PSIP info OTA. In Dallas, for example, only the ABC local does that.
Try doing a hard reset (unplug) and then do a complete digital channel scan again and see what happens.
...BK
BK EH is offline
post #11 of 2208 Old 02-10-2004, 08:48 AM
BGLeduc's Avatar
Quoted: 1524 Post(s)
Liked: 1376
When you guys are seeing channels w/o information, are you saying the channels are in the guide, but that the program data simply says DTV program, or something like that?
My 160 was set up a week or so back, and thats what I am seeing for certain OTA digital locals as well. The major stations (Fox, NBC, PBS, ABC, CBS) have correct data, but the WB and UPN do not.
I didn't think this was a bug, and assumed that it was a fault with the guide data provided to D*TV.
FWIW, my box is set-up for digital OTA nd D*TV is enabled.
BGL
#JB17
BGLeduc is offline
post #12 of 2208 Old 02-10-2004, 09:29 AM - Thread Starter
Quoted: 30 Post(s)
Liked: 32
My 160 was set up a week or so back, and thats what I am seeing for certain OTA digital locals as well. The major stations (Fox, NBC, PBC, ABC, CBS) have correct data, but teh WB and UPN do not.
BGL
On the 160 I had I had all the local OTA digital information. After the swap out I am only missing some, not all OTA digital HD major local stations (NBC, ABC) is missing channel information. It does say the name of the station in the guide that is correct. I thought you get the guide from D*. Even the OTA stuff. AM I right or wrong on that assumption?
post #13 of 2208 Old 02-10-2004, 09:31 AM - Thread Starter
Quoted: 30 Post(s)
Liked: 32
DId the reset and zip code and rescan thing.. same. I use the receiver for D* and OTA digital HD programming.
post #14 of 2208 Old 02-10-2004, 09:47 AM
DMOODY's Avatar
Chrome,They said they didn't know they were sending out the 360...as far they knew..they were still sending out the Hughes and the Sammy 160...This came from Level 2 support person...
DMOODY is offline
post #15 of 2208 Old 02-10-2004, 10:04 AM
Tonedeaf's Avatar
DMOODY,
what issues were you having with the 160? I am having just the lock-ups and a few audio drops.
I was thinking of calling them to replace mine but not sure if they would for just that.
Tonedeaf is offline
post #16 of 2208 Old 02-10-2004, 10:04 AM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
Id say your chances are VERY GOOD. Called on my 160 Friday, 360 showed up today.
barhoram is offline
post #17 of 2208 Old 02-10-2004, 10:12 AM
Tonedeaf's Avatar
Another question. How is the replacement handled? Do you have to pay shipping at all. Sending the 160 back?
Tonedeaf is offline
post #18 of 2208 Old 02-10-2004, 10:31 AM
DMOODY's Avatar
I called the Retention Dept at 1-800-600-8977 and told them my unit was locking up all the time...so I told them I wanted a new unit since it was in their 90 day warr. period....They said no problem and connected me to Level 2 support to get my unit replaced...should have new unit by friday...They pay for the shipping both ways....Hope this Helps
DMOODY is offline
post #19 of 2208 Old 02-10-2004, 10:44 AM
chrome's Avatar
i am so tempted to call but knowing my luck i will get back the E-86
chrome is offline
post #20 of 2208 Old 02-10-2004, 11:06 AM
BK EH's Avatar
Yes, when using a dish, you get the PSIP info for OTA's via DTV.
I am afraid it's a mystery to me now. Do you still have your 160? Plug it in and see what it gets... you will have to use the 360's card if you deactivated the 160. There could be a coincidence working here and the PSIP info from DTV is bad for the past couple of days.
...BK
BK EH is offline
post #21 of 2208 Old 02-10-2004, 11:39 AM
dacarter's Avatar
Got my 360 replacement for the 160 today. I don't think anyone is receiving an E86 are they?
dacarter is offline
post #22 of 2208 Old 02-10-2004, 12:28 PM
DMOODY's Avatar
Chrome,they only send out the new Hughes or Samsung....you will not get the E86
DMOODY is offline
post #23 of 2208 Old 02-10-2004, 12:33 PM - Thread Starter
Quoted: 30 Post(s)
Liked: 32
Yea I might give that a try, but I really hate hooking the 160 back up. I might have to to see what is going on.
post #24 of 2208 Old 02-10-2004, 12:39 PM
chrome's Avatar
working on them to send me a 360
i hope they dont send me the new hughes
chrome is offline
post #25 of 2208 Old 02-10-2004, 12:49 PM
chrome's Avatar
got off the phone and i am getting a replacement
i asked for the 360 and i hope to see it this thursday
if not then i am sending it back and i will live with the 160
chrome is offline
post #26 of 2208 Old 02-10-2004, 01:35 PM
blackmax2k1's Avatar
Are you guys getting these replaced because you have the Directv protection plan that's $7.99?
blackmax2k1 is offline
post #27 of 2208 Old 02-10-2004, 02:22 PM
Tonedeaf's Avatar
Getting my 160 replaced. D* told me that it would take 7-10 days. Is this just a CYA thing or did they tell those that are getting/already received the same thing?
Hopefully I get the 360 and not the HTL-HD.
BlackMax - don't have the protection plan.
Tonedeaf is offline
post #28 of 2208 Old 02-10-2004, 02:28 PM
How long have you had it?
post #29 of 2208 Old 02-10-2004, 02:31 PM
Tonedeaf's Avatar
I have had it for about 3 weeks.
Tonedeaf is offline
post #30 of 2208 Old 02-10-2004, 03:42 PM
chrome's Avatar
I also have had it for three weeks, hopefully they will replace it with a 360 but i am hearing that its having issues with ota?
chrome is offline
Reply HDTV Technical
