The Official AVS Antenna and Related Hardware Topic! - Page 343 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #10261 of 16687 Old 03-22-2009, 05:48 PM
systems2000's Avatar
Take a look at the last link below. Then follow the link to "Erecting A TV Antenna."
systems2000 is offline
post #10262 of 16687 Old 03-22-2009, 10:05 PM
300ohm's Avatar
I did notice that the rotor is stamped with 1 rpm.
Yeah, Ive never seen an ad for a rotor faster than 1 rpm. Speed demons they are not, heh.
300ohm is offline
post #10263 of 16687 Old 03-23-2009, 04:48 AM
ngarrang's Avatar
Do you really want a rotor whipping an LP antenna around quickly? Maybe a DB, they seem fairly durable. One of my DB2's has proven to be 3-yr old resistant.
ngarrang is offline
post #10264 of 16687 Old 03-23-2009, 06:52 AM
300ohm's Avatar
Personally I do, because waiting 20 or 30 seconds can seen like an eternity, heh. Thats why I like the two antennas, two downleads into an A-B switch solution so much.
300ohm is offline
post #10265 of 16687 Old 03-23-2009, 08:18 AM
MikeBiker's Avatar
Quoted: 12 Post(s)
I can understand that rotors designed for the large 2-69 band antennas would need to move the antenna slowly, but the UHF only and 7-51 antennas are significantly smaller and could be moved at higher speeds. A 3 RPM rotor could certainly work well with the small antennas are take only 10 seconds to do an 180 degree turn.
MikeBiker is offline
post #10266 of 16687 Old 03-23-2009, 03:19 PM
cat lady's Avatar
Originally Posted by Falcon_77 View Post
What do the TV Fool plots look like in each location?
I would avoid high-gain pre-amps, such as the CM7777 in any area that has signals in the green on TV Fool, unless you don't need to point the antenna in the direction of those stations.
TV transmitters at 15-20 miles are rather close, especially if you have LOS.
Do you need Low-VHF? Most areas do not need Low-VHF for DTV and that might save you some headaches. A 7-51 antenna is less cumbersome as well.
Thanks guys. After studying links provided, I think that the problem in both of the problem cases was due to short delay multi-path. This would be confirmed by the move of my co-workers dad's antenna to another location, thus accomplishing the desired reception of the local and distant signals. We have lots of trees around here, and in both cases, there were trees prosent, and in the Beaumont case, the land next to my friend's house is heavily wooded. I call it the hundred acre woods. So that is what I need to look for before installing antennas.
Thank you so much for pointing me in the right direction.
cat lady is offline
post #10267 of 16687 Old 03-24-2009, 05:33 AM
ngarrang's Avatar
For grins, I was using one of the many on-line tools for calculating the lengths for a LP/Yagi capable of 20db gain for channel 2.
The boom length came out to 127 feet. I lost count of the number of directors.
ngarrang is offline
post #10268 of 16687 Old 03-24-2009, 09:22 AM
PCTools's Avatar
I would like to stack two of those...
PCTools is offline
post #10269 of 16687 Old 03-24-2009, 09:37 AM
ngarrang's Avatar
You have a station 150 miles away you want to receive?
My yard is slightly longer than 127 feet. Let's see...I could top my backyard tree and plant this monster antenna on there. Where to set the guide wires, though, to stop it from becoming a twisted spear of God?
ngarrang is offline
post #10270 of 16687 Old 03-24-2009, 10:50 AM
300ohm's Avatar
Probably not. He just wants to annoy the neighbors.
300ohm is offline
post #10271 of 16687 Old 03-24-2009, 10:52 AM
gjvrieze's Avatar
2 of these at 150ft AGL, would be FANTASTIC!
KD0MOF
All opinions expressed (unless otherwise noted) are the poster's only and NOT that of the poster's employers.
gjvrieze is offline
post #10272 of 16687 Old 03-24-2009, 12:43 PM
300ohm's Avatar
You could string a net between the two antennas, and catch bats at night.
300ohm is offline
post #10273 of 16687 Old 03-24-2009, 03:53 PM
Tower Guy's Avatar
4 antennas with 15 db each would do the same thing and be more manageable.
Tower Guy is offline
post #10274 of 16687 Old 03-24-2009, 04:26 PM
dr1394's Avatar
Quoted: 130 Post(s)
Liked: 65
Even at 15 dB, that would still be a big antenna. However, such things exist. Here's a 50 MHz antenna with 14 dBd gain on a 69 foot boom.
http://www.m2inc.com/products/6m/6m11jkv.html
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is offline
post #10275 of 16687 Old 03-24-2009, 05:16 PM
300ohm's Avatar
Code:
SPECIFICATIONS
Model
 6M11JKV
Frequency range 49.9-50.5 MHz
Usuable Frequency Range 49.6 TO 50.75 MHz
Gain over a Dipole 14 dBd
Front to back, Typical >21 dB
Beamwidth degrees E=28° / H=39°
FIRST SIDELOBE -18 dB
STACKING (HORIZ POL) 38' W, 36' H
Feed impedance
 50 OHM
VSWR
 1.2:1
Input Connector
 'N' Female
Balun Half Wave 4:1, supplied
Power Handling
 1500 WATTS
Element Type 3/4" Tube W 7/8" Center Sleeve
Boom length and diameter 69' / 2" / 2", 2-1/2" & 3" X 36" CNTR
Wind Area / Survival 10.7 SQ. FT. / 100 MPH
Weight / ShipWt.
 83 LBS. / 95 LBS, Truck or air
Heh, heh. And thats only 1 of 4, heh. And thats 14dbd, 16.15 dbi for each one. Figure another 2.5 dbi stacking two, then 5 dbi stacking all four for about 21.15 dbi.
300ohm is offline
post #10276 of 16687 Old 03-24-2009, 09:07 PM
The Hound's Avatar
69' long damn!
The Hound is offline
post #10277 of 16687 Old 03-25-2009, 07:33 AM
300ohm's Avatar
69' long damn!
Also at 50mhz, the stacking distance is large too. So maybe figure it needs to be 69 ft high for all four. Then of course it wont work well close to the ground, so youll need a good 100 ft tower to mount it on too, heh.
If youre going to go that insane, you might as well have a 60 meter in diameter parabola dish built, heh.
300ohm is offline
post #10278 of 16687 Old 03-25-2009, 09:17 AM
Tower Guy's Avatar
There is an aspect of the problem that is easily overlooked when comparing antenna gains and heights. Antennas on channel 2 interact with the ground to steer the main beam upwards. Tvfool doesn't include that factor in their data. Tvfool does assume that there is more signal when the antenna is raised, but that is based on statistics and not the specifics of a particular antenna's interaction with the ground.
If the ground in front of the antenna is flat and you would like to get the main beam aimed exactly at the transmitter antenna, extra tower height adds significantly. At reasonable antenna heights it's 1 db per each 5' of tower height. If the ground in front of the antenna slopes downward, there is an optimum height where the ground interaction adds approximately 6 db to the gain of the antenna.
Therefore, a single 14 db gain antenna at the optimum height with downward sloping ground in front of the antenna would actually have 20 db gain.
post #10279 of 16687 Old 03-25-2009, 12:40 PM
300ohm's Avatar
Im out of luck on that, its flat as a pancake around here, heh. I wonder if that guy with the four stacked 69 ft yagis lives in the Texas hill country ?
300ohm is offline
post #10280 of 16687 Old 03-25-2009, 04:03 PM
holl_ands's Avatar
Quoted: 473 Post(s)
Liked: 194
Ken Nist updated the 8-Bay Modification webpage, testing an alternative feedline
for the CM-4228HD, as well as a 1/4-wavelength balun:
http://www.hdtvprimer.com/ANTENNAS/TemporaryPage.html
holl_ands is offline
post #10281 of 16687 Old 03-25-2009, 04:05 PM
dr1394's Avatar
Quoted: 130 Post(s)
Liked: 65
Here's some pics (including some rope yagis):
http://www.bigskyspaces.com/w7gj/6mEMEstns.htm
Ron
dr1394 is offline
post #10282 of 16687 Old 03-25-2009, 04:55 PM
Tower Guy's Avatar
This is in Hempstead, TX
http://www.50mhz.org/6m/album02/IMG_0255
post #10283 of 16687 Old 03-25-2009, 08:03 PM
300ohm's Avatar
I hate to be under some of those when the wind is blowing strong, jeez. Also I noticed some are mounted near power lines. Nothing like living dangerously, heh.
Hmm, I believe the hill country may start a little to the west of there. I remember driving from New Braunfels ( a little north of San Antonio) to north of Austin at night and I ran into some pretty darn decent hills, heh. I also remember running over an armadillo. (from what Ive been told, I didnt hurt the little critter, heh)
300ohm is offline
post #10284 of 16687 Old 03-26-2009, 03:16 PM
oldsyd's Avatar
After reading this thread, I'm almost too ashamed to post this, but after finding rabbit ears are insufficient to pick up my one DTV channel (KWWL NBC 7) I am going to attempt to make a folded dipole for this one channel.
Problem is, nobody in town carries 300 ohm twin lead wire, even the local independent radio supply store and Radio Shack.
This will be for indoor use, and I don't have the ability to access the attic antennas (sep. VHF/UHF Yagi) from the room I want to use this in.
Where do you recommend ordering twin lead from? I'll probably also get a new balun and combiner for it also.
It's depressing nobody manufactures a descent indoor VHF-HI antenna considering the demand for one.
Jay
PS - According to my calculations, I'll be cutting it to 31.68 inches long.
oldsyd is offline
post #10285 of 16687 Old 03-26-2009, 05:57 PM
300ohm's Avatar
Make your own from copper wire. Enter your info here at K7MEMs site for the design measurements : http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=15313
300ohm is offline
post #10286 of 16687 Old 03-26-2009, 07:47 PM
cpcat's Avatar
Lowe's carried twin lead the last I checked.
cpcat is offline
post #10287 of 16687 Old 03-26-2009, 09:44 PM
NTNgod's Avatar
There are Menards stores in Iowa, I think. They carry the super-cheapo super-thin indoor Magnavox-branded stuff for like $2 for 50 feet (so you're not exactly getting grade-A stuff, but for $2....)
NTNgod is offline
post #10288 of 16687 Old 03-26-2009, 09:49 PM
dr1394's Avatar
Quoted: 130 Post(s)
Liked: 65
For the perfectionists out there, here's a link to some transmit quality 300 ohm twin-lead:
http://www.dxengineering.com/products.asp?ID=170
Ron
dr1394 is offline
post #10289 of 16687 Old 03-26-2009, 10:55 PM
oldsyd's Avatar
Thanks everyone for the wide array of options!
oldsyd is offline
post #10290 of 16687 Old 03-27-2009, 06:10 AM
300ohm's Avatar
Whew, about 30 cents a ft, but it is strong 18 gauge stuff.
Not my Lowes anymore. What it seems they do when their stock gets low, is put it on clearance for a weekend, and then dont stock it anymore.
300ohm is offline
Reply HDTV Technical
Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd
