The Official AVS Antenna and Related Hardware Topic! - Page 482 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #14431 of 16523 Old 02-08-2012, 05:05 PM
Ken.F's Avatar
Quoted: 1372 Post(s)
Liked: 1160
Originally Posted by arxaw View Post
A better choice for you may be the Winegard HD7000R, which is similar to the ANT751, but is tuned for all 3 TV bands.
Thanks. Since the HD7000R is 100" wide I can't put it in the attic. I'm going to try the ANT571 first. If that doesn't work I'll try the HD-7000R outdoors when the weather gets better.
Ken.F is offline
post #14432 of 16523 Old 02-08-2012, 07:26 PM
holl_ands's Avatar
Quoted: 380 Post(s)
Liked: 158
You didn't say which DIY 4-Bay design you used.
M4 Super-4-Bay Bowties have very good Hi-VHF Gain, F/B & F/R Ratios,
however the way too small 4-Bay antennas such as DB-4 and the
notorious U-Tube Defect have not only poor UHF performance, but
what little Hi-VHF Gain it can muster is pointed towards the REAR:
http://imageevent.com/holl_ands/mult...ayrefl/db4refl
It is also important to note that ALL of these UHF 4-Bay antennas
have excessive SWR trying to operate in the Hi-VHF Band. Inserting
a short length of coax (e.g. 18-24 inches) could "shift" a NULL on the
end of the coax to another frequency. But the digital decision process
may still be degraded due to the Error Vector Magnitude (EVM) effect
[search forum & Google for more info).
holl_ands is offline
post #14433 of 16523 Old 02-09-2012, 02:52 AM
Ken.F's Avatar
Liked: 1160
It's the "notorious U-Tube Defect" design.
Ken.F is offline
post #14434 of 16523 Old 02-09-2012, 08:22 AM
Dave Loudin's Avatar
Build plans and kits for the M-4 bow-tie array are here: http://m4antenna.eastmasonvilleweather.com/index.html. By what shows in your TVFool report, you could rebuild your bowtie array for better results.
Dave Loudin is offline
post #14435 of 16523 Old 02-09-2012, 09:54 AM
meschaefer's Avatar
Originally Posted by meschaefer View Post
Hi folks,
I have been doing a lot of research, but it appears that this is a can be a very big and technical topic. So I thought I should just ask for some help. I am looking to set an Antenna up on my roof. I live in fairly urban environment and there are some buildings around me that are taller than mine, but that being said it also appears from my tvfool report that I have some fairly strong signals. My initial thought is to just go big and tall, but that may be overkill and unnecessary. Initially this will be going to one TV, with a run of about 60 foot of RG6, mostly depending where on the roof the antenna goes. Any thoughts on an antenna choice would be greatly appreciated.
http://www.tvfool.com/?option=com_wr...0b8690fde8ba36
I just wanted to report back, that I went with the RCA ANT751 as recommended. I put it up on top of my roof and fabricated a 10 foot extension for the mast (Which gets it up about 40 foot in the air and over the apartment building right next to me) and aimed it at 254° magnetic compass direction. Did a scan, and pulled in approx 65 channels. (Granted most are crap) I am pulling in all of my network channels at full strength with a great picture. Best Superbowl picture I ever had.
Thanks for your help.
Matt
meschaefer is offline
post #14436 of 16523 Old 02-09-2012, 11:01 AM
holl_ands's Avatar
Quoted: 380 Post(s)
Liked: 158
If it has a Reflector, my comments above apply....
However, with NO Reflector, U-Tube Defect provides 3.2 dBi, Bi-Directional Gain for Hi-VHF,
although the SWR is Excessive (just like UHF):
http://imageevent.com/holl_ands/multibay/4bay/utube
post #14437 of 16523 Old 02-09-2012, 01:07 PM
Ken.F's Avatar
Liked: 1160
I've played around with a piece of foam board covered with aluminum foil as a reflector. The reflector blocks channel 9 from the north. If I add the reflector and space it about 5 inches back I can sometimes get 12 but it makes 6 less stable. With the reflector spaced about 1-1/2 inches back I get 6 reliably but I lose 12.
I picked up the ANT751 today. I'll put it up tonight if I have time.
Ken.F is offline
post #14438 of 16523 Old 02-09-2012, 01:24 PM
Ken.F's Avatar
Liked: 1160
Thanks for the suggestion. I already have that page bookmarked. I thought some day I might try building one of those or a Gray-Hoverman. Then I saw jschweda19 mention the ANT751 being on sale for about what it would cost me to build another antenna.
Ken.F is offline
post #14439 of 16523 Old 02-09-2012, 03:06 PM
arxaw's Avatar
Matt
Matt, glad the ANT751 worked for you. Thanks for posting back with your results.
It's true that many of the OTA channels are "crap," but so are many cable channels. And amazingly, people actually pay money for that crap. At least OTA is free (after you pay for the equipment).
arxaw is offline
post #14440 of 16523 Old 02-09-2012, 03:30 PM
Hey, Ken.F, if you want to consider G-H's further, be sure to bookmark this site. Design parameters were run through an optimizer to get around 14dBi gain in the UHF band and 9dBi in the hi-VHF band.
post #14441 of 16523 Old 02-09-2012, 03:41 PM
Ken.F's Avatar
Liked: 1160
I put the ANT751 up. When I can get a helper to come over I'll be able to aim it better. I pointed it in the same general direction the 4-bay was facing and it seems to be working well. I still get WBPH on 9 from the north even though the antenna is pointed south. I have some tall pine trees to the south-east so maybe it's bouncing the signal off the trees?
12 is better now but I don't know how solid that one will be. Time will tell. Right before swapping the antennas I was getting it at 14-18 on the signal meter. The picture starts to break up at about 16 so this was a good time to swap antennas. The ANT751 is pulling it in at 20-22 with a stable picture. 6 is good at 34 - 36. All the UHF channels are a little stronger now as well. I didn't find any new channels but I wasn't expecting to. Thanks to everyone for the advice.
TV Fool Report
Ken.F is offline
post #14442 of 16523 Old 02-09-2012, 03:50 PM
arxaw's Avatar
Ken.F,
Glad the ANT751 worked for you, including lowband VHF channel 6. Thanks for posting back.
Channel 9 is fairly strong at your location. The antenna is just picking it up from the back side of the antenna.
If your numbers are SNR, you usually consistently need ~16 or higher to maintain a lock. More than that won't make the picture quality any better, but higher numbers do give you more insurance against changes due to weather and atmospheric conditions.
arxaw is offline
post #14443 of 16523 Old 02-11-2012, 11:34 AM
cjl7701's Avatar
Very true.
I think the 751 will work fine for your locals. Do post back with your results, so others may learn from your experience.
RECEIVED MY ANT 751 YESTERDAY, TRIED TV WITH THE FLAT AMPLIFIED ANTENNA I HAD FOR A COMPARISON BEFORE HOOKING UP THE ANT751. WAS PULLING 5 CHANNELS WITH THE OLD ONE, WAS SNOWING A LITTLE OUTSIDE( IF THAT MAKES A DIFFERENCE). HAD 11 CHANNELS WHEN I HAD HOOKED IT UP A WEEK AGO.
HOOKED UP THE ANT751 IN THE ATTIC, POINTED IT IN A GUESTIMATE 250-260 DEGREES , CAME DOWN AND DID A SCAN, PICKED UP 25 CHANNELS, INCLUDEING WTNH 8.1, WHICH IS APPROX 45 MILES AWAY, ACCORDING TO THE CHART. I'M VERY HAPPY, i HAVEN'T FINE TUNED ANYTHING OR TRIED ROTATING IT AT ALL. I WAS GOING TO INITIALLY PUT IT OUTSIDE WHEN I GOT IT, THE SNOW STOPPED THAT THIS MORNING,
THANKS FOR ALL THE ADVICE ARXAW AND CT DISH, HOPE THIS HELPS SOME OTHERS OUT THERE. I MAY BUY ANOTHER AND AIM IT IN ANOTHER DIRECTION, AND PUT IT ON A AB SWITCH DOWN THE ROAD, BUT FOR NOW I WILL SIT BACK AND ENJOY WHAT I HAVE, THANKS AGAIN FOR THE HELP. GLAD THERE IS A FORUM LIKE THIS FOR THOSE OF US THAT ARE TRYING TO LEARN.
cjl7701 is offline
post #14444 of 16523 Old 02-11-2012, 04:16 PM
arxaw's Avatar
Glad it worked for you. If you're getting the stations you wanted, I would just leave the antenna in the attic, out of the weather. The antenna, coax and connectors will hold up a lot better out of the weather.
arxaw is offline
post #14445 of 16523 Old 02-11-2012, 05:14 PM
clicq's Avatar
This is a really interesting thread! I was hoping to get some suggestions on antennas. My TVfool analysis results:
http://www.tvfool.com/?option=com_wr...0b86e8f26ce8ec
I'm currently living in an apartment complex, which means I don't really have any means to mount an outdoor antenna . On the plus side, the area is mostly flat; I'm just far away from most of the transmitters.
In the TVfool report above, I'm really only interested in getting the major networks, down to NBC (7). I saw a couple people had posted success with making a DIY antenna; would they be appropriate for my situation?
clicq is offline
post #14446 of 16523 Old 02-11-2012, 05:55 PM
difuse's Avatar
Quoted: 76 Post(s)
The terrain isn't very hard on reception where you are. Have you tried any type of antenna, yet? You might be surprised at how well a simple indoor antenna might do.
difuse is offline
post #14447 of 16523 Old 02-11-2012, 06:49 PM
300ohm's Avatar
Yeah, if you have east facing window or east exterior wall with no metal, the GH0n will work well for you. Much better than the U-tube defect.
http://clients.teksavvy.com/~nickm/g..._5V9_10u0.html
300ohm is offline
post #14448 of 16523 Old 02-11-2012, 08:00 PM - Thread Starter
Ken H's Avatar
Administrative Question:
Is this topic used much for OTA reception hardware besides antennas? Meaning preamps, splitters, combiners, cable, baluns/transformers, mounting hardware, etc?
I ask because in pruning the 'stuck' topics, there was one titled "Antennas, rotators, boosters/preamps... for wide-band VHF/UHF", found here: http://www.avsforum.com/avs-vb/showthread.php?t=546066
It went unused for 6 months, so I closed it, but still left it in the stuck 'Links' topic, because there is a ton of reference material.
I'm considering reopening it and renaming it for all non-antenna reception hardware.
Or should I leave it closed and re-title this topic to add all OTA reception hardware?
Or other?
Thanks in advance for your input.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #14449 of 16523 Old 02-11-2012, 08:05 PM
arxaw's Avatar
I always thought the two threads were redundant and could easily be combined into one.
arxaw is offline
post #14450 of 16523 Old 02-11-2012, 08:52 PM
clicq's Avatar
I have not; I guess that's the first thing I should try. I'll grab a basic one from Walmart/Target tomorrow and see how it does.
Sadly I'm in the middle of the building, with only a north facing window .
clicq is offline
post #14451 of 16523 Old 02-11-2012, 09:29 PM
jtbell's Avatar
Same here. The now-locked thread does have a lot of useful information in it, so it would be worth keeping a link to it somewhere for reference. I think it would be confusing to have separate threads for antennas and for antenna-related hardware.
jtbell is offline
post #14452 of 16523 Old 02-11-2012, 09:49 PM - Thread Starter
Ken H's Avatar
Ok, two votes for merging, thanks for the feedback.
Ken H is offline
post #14453 of 16523 Old 02-12-2012, 06:22 AM
arxaw's Avatar
Perhaps a title of: Over The Air Antennas and Related Hardware (?)
arxaw is offline
post #14454 of 16523 Old 02-12-2012, 06:30 AM
arxaw's Avatar
If you have a RadioShack, this specific model (15-1874) antenna often works much better than other antennas that look almost identical. http://www.radioshack.com/product/in...ductId=2103077
You can return it if it doesn't work.
Since you don't have any windows facing the ideal direction, indoor reception may be doable, but may also require patience and a lot of trial and error until you find a reception hot spot, free of interference. Connect a longer piece of coax to the antenna, with a barrel splice. Try different spots in the room, if necessary. High, low, near different walls and possibly in another room. Near a window may be best, but is not always the case with unpredictable indoor reception. You will need to rescan or select "add digital channels" from the TV's channel setup menu, after each time you move the antenna around. If your TV has a signal strength meter, bring that up on the screen to help find a good spot to set the antenna.
arxaw is offline
post #14455 of 16523 Old 02-12-2012, 07:15 AM
johnson_design's Avatar
Glad I found this thread. Decided to cut cable and save over $100 a month. On a whim I built a antenna (this one) without a reflector. I can pull in all of the major networks plus, ION is spotty.
From TV Fool it looks like I'm in the middle of two banks of towers, the antenna is pointing toward the majors, the ION tower is the opposite direction. My questions. Would adding a reflector help or would a second antenna pointed the other way work (can you combined the two, if so how). These will eventually be installed in a third floor attic space.
Finally because of the length of cable run, over 60 feet, I've added an amplifier to the line (this one) I didn't really notice much of a change in reception. Do these really help.
Thanks. Sorry for all the questions.
johnson_design is offline
post #14456 of 16523 Old 02-12-2012, 08:01 AM
Sorry about that. I added one to my post.
post #14457 of 16523 Old 02-12-2012, 08:14 AM
arxaw's Avatar
Adding a reflector will make the antenna more directional, which may help with problem channels (in the direction it's aimed), at the expense of channels the antenna is not aimed directly at. A preamp should not help with the channels in green, and may actually degrade signal quality, due to overload (if it ain't broke...).
Do you currently get any channels to the West?
arxaw is offline
post #14458 of 16523 Old 02-12-2012, 08:27 AM
The only one to the west I receive is 30.1, it comes in great. 47.1 rarely comes in and usually only for a few seconds.
post #14459 of 16523 Old 02-12-2012, 09:43 AM
arxaw's Avatar
According to your TVFool, WRAY Ch 30-1 is to the East of you.
You could build another antenna to get some channels from another direction. But it would likely work better by using two coax lines and an A/B switch to change antennas. You would also need to make sure your TV can add channels after the initial channel scan, without wiping out the channels if initially found. A few brands/models models do not have that feature.
Before building another antenna, I would add a screen to the existing antenna, then aim in the opposite direction and rescan, to see what extra channels it might get, before going to the trouble of building one.
arxaw is offline
post #14460 of 16523 Old 02-12-2012, 09:55 AM
Calaveras's Avatar
Quoted: 999 Post(s)
Liked: 232
TV Fool shows ION as a 2 edge path which means it's more likely to have multipath issues. A more directional antenna would be helpful if that's the case.
You cannot combine two antennas on the same band. They'll interfere with each other. It's like purposely introducing multipath. Use an A/B switch for two antennas. With expensive filters it is possible to pick off one channel from an antenna and add it into another but I've never heard of anyone doing that at home.
They help a lot under the right circumstances. 60' feet of cable is not a very long run. The purpose of a preamp is to overcome cable loss and maybe a splitter. If you install a preamp and nothing improves, that's telling you that your signals are already strong enough or you have multipath issues.
With the number of stations you have with Noise Margins above 50 dB, I wouldn't use a preamp because it's likely to get overloaded.
Chuck
Calaveras is offline
Reply HDTV Technical
Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd
