The Official AVS Antenna and Related Hardware Topic! - Page 485 - AVS Forum | Home Theater Discussions And Reviews
 46Likes
post #14521 of 16588 Old 02-27-2012, 06:21 AM
arxaw's Avatar
I think the antenna needs to be moved around to find a better reception spot. Reception indoors is all about location. An outside wall or window away from any possibly interfering electronic devices, facing South would be best. You can probably add up to 50' of RG6 coax with no problems. It is a slow trial and error process, but eventually, you'll probably find a reliable spot for the antenna. Moving it as little as a foot at a time can make a huge difference. Slightly different elevations can make a huge difference, too.
If WGCT channel 8 is of no interest to you, all your other channels are in the UHF band, and the VHF dipole rods can likely be collapsed or even unscrewed from the antenna, without impacting reception. Extending them likely won't help with your UHF reception. UHF does not need a large antenna - one of several advantages of that band. And the loop on your antenna is actually larger than most other similar looking indoor antennas.
arxaw is offline
post #14522 of 16588 Old 02-28-2012, 02:36 PM
hocobo23's Avatar
So I just moved to a townhome. Upon inspection I noticed Coax connections in every bedroom and the main floor and basement. I also noticed that there was a seperate line of dual coax that I assumed was coming from a Satalite. I checked outside and sure enough there was a dish on the roof. I went in the attic and there is also a large OTA antenna in the attic (6'x4'). I didnt want to pay for Dish, so I attempted to connect my TV (Sony KDL55EX710) to the regular Coax connection and i got low quality SDTV in widescreen with solid chanel #'s (2,4,5,7 etc.), in the past when I have done HDTV OTA they have been chanels with numbers like 2.1,5.1,7.3 etc.
I then hooked up a small bowtie antenna and got HDTV channels (1080, with digital chanel #s) although with poor reception (i didnt get all the local chanels...). So then I tried taking my bowtie antenna into the attic and unhooked the large OTA antenna and hooked up my small bowtie to the coax that was running to the OTA antenna. I still got low quality SDTV chanels with solid chanel #s!!!!
My question is this: Why am I getting these low quality SDTV chanels when I use the coax hookups on the wall, even when I disconnect what should be the source (large OTA antenna) and hook up my bowtie/ EVEN WHEN i am getting HDTV when i run my antenna straight to my TV????????? Thanks in advance!
hocobo23 is offline
post #14523 of 16588 Old 02-28-2012, 03:56 PM
arxaw's Avatar
The attic antenna should get your local digital OTA channels (with sub-channel numbers like 2-1, 5-1, etc.
It sounds like the coax you connected to the TV is going to some other source, or you're not doing a proper channel scan. Make sure you have selected Antenna channels in the channel setup menu, not Cable. Then run autoscan or "Add digital Channels."
arxaw is offline
post #14524 of 16588 Old 02-28-2012, 04:35 PM
Ennui's Avatar
To verify the coax connections and routing, I would short one end and use an ohm meter or continuity tester to sort them out.
99.5% Dark Matter
Ennui is offline
post #14525 of 16588 Old 02-28-2012, 05:00 PM
holl_ands's Avatar
Quoted: 453 Post(s)
Liked: 187
Since there are NO Analog channels on the air, they must be coming
from either an old SAT system or Cable. Trace & identify ALL cables.
holl_ands is online now
post #14526 of 16588 Old 02-29-2012, 06:18 AM
ProjectSHO89's Avatar
Quoted: 234 Post(s)
Liked: 114
You need to sort out the spaghetti-mess of cabling. It appears that the cables don't do where you think they do. You're also getting analog cable from a cable hookup, so check the outside cable connection to see if it's connected and the cable company is still feeding it with a "basic" service.
ProjectSHO89 is online now
post #14527 of 16588 Old 02-29-2012, 07:37 AM
A J
A J's Avatar
Quoted: 124 Post(s)
Liked: 34
Originally Posted by holl_ands View Post
Since there are NO Analog channels on the air...
There may not be any at that location, but there are several low power analog stations in the Charlotte area. Every time I re-scan I have to then delete all of those snowy analog channels. I wish my TV had only a digital tuner, like my CM-7000PAL DVR has, so analog stations would be ignored by the TV, too.
A J is offline
post #14528 of 16588 Old 02-29-2012, 07:42 AM
BCF68's Avatar
All analog LPs will be shut down by Sept 2015.
BCF68 is offline
post #14529 of 16588 Old 02-29-2012, 08:18 AM
arxaw's Avatar
... I wish my TV had only a digital tuner, like my CM-7000PAL DVR has, so analog stations would be ignored by the TV, too.
A lot of TV tuners now have "digital-only" scan, often referred to as "Add digital channels" or something similar. In addition to only scanning for digital, this option usually adds channels to the list of those found in the initial scan. A great feature for antenna freaks.
Many Sony TVs have this, as do Sanyo.
arxaw is offline
post #14530 of 16588 Old 03-01-2012, 02:49 PM
hocobo23's Avatar
I ran a scan using "add digital chanels" from my tv. The really odd thing is how i get the digital chanels from my small antena when hooked directly from my tv, but not when i take the small antena to the attic. I am guessing that whoever lived here before bypassed that attic antenna and ran the coax to the SAT, any ideas how i verify this???
hocobo23 is offline
post #14531 of 16588 Old 03-01-2012, 04:52 PM
arxaw's Avatar
Physically trace out the coax lines to see where they run. Or follow Ennui's instructions above, using an ohm meter or continuity tester.
arxaw is offline
post #14532 of 16588 Old 03-01-2012, 05:43 PM
mp11's Avatar
I'm interested in getting a CM 3671 antenna, but everywhere I look the gain info isn't there. Anyone know what the gain numbers might be? Thanks.
mp11 is offline
post #14533 of 16588 Old 03-01-2012, 06:47 PM
arxaw's Avatar
I would check with ChannelMaster. http://www.channelmaster.com
Where in South LA are you located?
arxaw is offline
post #14534 of 16588 Old 03-01-2012, 07:46 PM
mp11's Avatar
Channelmaster site tells all you want to know about the 3671 except gain. Very strange.
I'm about 40 minutes northwest of Lafayette.
mp11 is offline
post #14535 of 16588 Old 03-01-2012, 08:02 PM
300ohm's Avatar
Modeled gain charts for the CM3671B are here :
http://www.hdtvprimer.com/ANTENNAS/comparing.html
300ohm is offline
post #14536 of 16588 Old 03-01-2012, 08:18 PM
arxaw's Avatar
What station are you trying to receive that would require an all-channel antenna?
arxaw is offline
post #14537 of 16588 Old 03-02-2012, 01:34 AM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
VHF-LO 5.6 db / VHF-Hi 10.9 db / UHF 10 db
Channel Master's UHF numbers look weak for such a large antenna, although it did well using Ken Nist's modeling.
As arxaw asked, what low band channel are you looking for? I don't see anything interesting near you below VHF 7.
Digital Rules is offline
post #14538 of 16588 Old 03-02-2012, 02:03 AM
holl_ands's Avatar
Quoted: 453 Post(s)
Liked: 187
Stark Electronic still has Gain Charts for old C-M antennas:
http://www.starkelectronic.com/cmg2.htm
post #14539 of 16588 Old 03-02-2012, 04:40 AM
AntAltMike's Avatar
Quoted: 130 Post(s)
Liked: 62
... and make sure that the coax going to the TV is screwed on tight! Last night, I went out on a service call at a condominium where I had previously installed a superb multi-market headend that mixes 18 transmitters from Washington, DC, Falls Church and Goldvein, Virginia, and Baltimore and Annapolis Maryland. The complaint was that the resident was not getting WRC 4.1 and was instead getting "Comcast" on channel 4, but only in the morning.
Wel, since WRC 4.1 used to be on analog 4 but is now on UHF 48, there was no direct connection between the missing digital channel and the phantom analog one. This customer's condo is less than one mile from the 4.1, channel 48 transmitter and the direct UHF 48 leaking into the push-on F fitting on the back of their TV was phase canceling the desired processed UHF 48 from the master antenna system, and the phantom analog 4 was probably because a neighbor in a nearby unit was using the channel 4 RF output on his cable box or VCR, and that neighbor's own push connector jumper was enabling his cable box output to be weakly broadcast. I solved the problem for this customer by just giving her the little piece of coax that was attached to my test meter. I won't even bother to find out who is leaking analog 4 in the building because it is now of no concern to me.
AntAltMike is offline
post #14540 of 16588 Old 03-02-2012, 09:16 AM
mp11's Avatar
This antenna's main purpose will be for DXing. No particular channel for continuous viewing.
A large part of my DXing will be Mexico and Central America and hopefully farther south...all low band VHF. And the numbers do look a bit weak. That's why I'm getting comparisons with this Antennacraft 1850 which is slightly larger, and VHF-lo shows as 6.2 db. But another concern is quality. Does the 1850 have the same quality as the CM 3671? Any suggestions are appreciated.
Thanks for those charts Holl_ands
mp11 is offline
post #14541 of 16588 Old 03-02-2012, 09:25 AM
arxaw's Avatar
Ah, makes sense, now.
arxaw is offline
post #14542 of 16588 Old 03-02-2012, 10:40 AM
bcg123's Avatar
I posted this already elsewhere in the forum, but I was advised to post it here, so sorry for the double-post.
I am new to Houston, and my husband and I bought a new HDTV two weeks ago. We want to get OTA programming since we mostly just watch a few sitcoms and Netflix, no sports. The only channels we care about are the main network channels plus PBS (so, ABC, CBS, FOX, NBC, and PBS).
The problem is, it's looking impossible to get OTA. I began with an inexpensive rabbit ears-style antenna (RCA Basic Indoor Antenna). Initially, that got NBC, PBS (sometimes), and FOX, but not CBS or ABC. We watched one night of TV on NBC, but during the first minute of the last show, it began cutting out badly (it had been basically perfect previously), so we turned it off. Since then, we can barely get ANYTHING (usually channel 38 and sometimes 20 and others above channel 38), despite trying multiple positions (although we are limited now by a short-ish cord--maybe 3-4 feet?). So, I bought a fancy $75 antenna at an electronics store: it was a flat, multidirectional, amplified indoor antenna, and it was no better, so I returned it (I now know that the amplified bit was a problem, and given the location of Houston's antenna farm, the multidirectional probably wasn't helpful). The cord wasn't long enough for either of the antennas to be actually on the windowsill, but the positions pointing directly out the window didn't seem to be any better (about a foot away from the window, although also pretty low, since the only space was on top of the coffee table).
There are lots of things going against our set-up, I know: the only window in our living room (where the TV is) faces north, and so does our balcony. We are living in a second (top) floor apartment in zip code 77027 (about 13 miles from the antenna farm), and Greenway Plaza is just a few blocks to the south of us, so that's probably in the way, too (the signals are pretty much all southwest of us).
So, my question is, is there anything better I can try without an outdoor antenna? Although some people have satellite dishes in my complex, they are pretty much all attached to balconies, not the roof, and I don't think an antenna would help in that case (since my balcony faces north and it would actually be attached at a lower point than the indoor antenna is located). I am in an end unit, so from one end of my balcony, I have about 5 feet to the corner; if I had an antenna that could stretch that far (or reach the corner), then it might get some signal to the south (but still, Greenway Plaza is in the way). I've seen a lot of people recommend the following antennas, but I'm not sure if any of these are likely to help in my situation:
Terk Technology HDTVi VHF/UHF HDTV Indoor Antenna
Terk HDTVa Indoor Amplified High-Definition Antenna
RCA ANT751R Outdoor Antenna
Winegard HD7696P Off-Air HDTV Antenna (rec. by hdtvantennalabs.com)
Any advice? Thanks!
bcg123 is offline
post #14543 of 16588 Old 03-02-2012, 11:15 AM
Konrad2's Avatar
Why not seperates? (3 antennas: VHF-LO + VHF-HI + UHF)
Higher performance and easier to filter out interference from
non-TV frequencies.
Konrad2 is offline
post #14544 of 16588 Old 03-02-2012, 11:19 AM
tylerSC's Avatar
Quoted: 737 Post(s)
Liked: 168
He may want to consider a Winegard 8200 as well as the CM3671.
tylerSC is offline
post #14545 of 16588 Old 03-02-2012, 11:22 AM
arxaw's Avatar
bcg123,
Please enter your address at http://www.tvfool.com/index.php?opti...pper&Itemid=29
Post a link to the results page back in this thread.
There are no magic antennas that will make up for poor indoor location, but perhaps we can suggest something to at least try.
arxaw is offline
post #14546 of 16588 Old 03-02-2012, 11:37 AM
mp11's Avatar
non-TV frequencies.
I know that separate antennas are better, but more costly and more windload(stacked). Although I can see that possibility down the road.
mp11 is offline
post #14547 of 16588 Old 03-02-2012, 11:37 AM
pamajestic's Avatar
non-TV frequencies.
Agree, plus you could easily stack the VHF-HI and UHF for even more gain.
pamajestic is offline
post #14548 of 16588 Old 03-02-2012, 02:59 PM
bcg123's Avatar
bcg123 is offline
post #14549 of 16588 Old 03-02-2012, 03:45 PM
arxaw's Avatar
Originally Posted by bcg123 View Post
My TVFool report is at:
http://www.tvfool.com/?option=com_wr...0b86d8bee756e7
Well, you definitely don't need an amplified antenna, because signals are very strong at your location, and the amp would likely overload. If you have no outdoor options, what you need is trial and error and a lot of patience to find an indoor reception hot spot. The most likely spot would be near a South-facing wall or window. If you still have the rabbit ear/loop antenna, that's all you need, although the RCA one is not very good. This similar looking one from RS (model 15-1874) nearly always works better than the RCA. The loop is bigger and the cable is larger gauge.
To find a reception hot spot, connect a longer piece of RG6 coax to it (no more than ~50' longer), using a barrel splice, also available at RS.
If your building has metal siding, metal roof, stucco, or foil-backed insulation, you will very likely need to put the antenna in or near a window.
If you can do outdoor or attic, the RCA ANT751 (made by Winegard) would be a very good choice at your location.
arxaw is offline
post #14550 of 16588 Old 03-03-2012, 11:26 AM
bcg123's Avatar
I don't have a long coax yet, but I tried this: I moved my TV into the bedroom, plugged in the current antenna, and set the current antenna on my bedroom windowsill. That window is south-facing, and I tried to tilt the antenna a little southwest, too (since the antenna farm is southwest of me). It worked better and I got 50-odd channels (mostly in the 20s and above), but, of the four I care about (2.1-NBC, 11.1-CBS, 13.1-ABC, 26-FOX), the only one I got was 26 (FOX). So, no NBC, CBS, or ABC. I'm a little surprised, but I have a few theories about why it's still so bad:
1) My antenna's bad, and I need a better one. Solution: get a better antenna. Any suggestions? Any thoughts on whether just a different model, same design is fine, or whether a different design might be helpful? (I know you recommended the Radio Shack Basic Antenna--should I start there, or is my situation bad enough that a better, non-amplified antenna is necessary?)
2) Tall office buildings are blocking the signal (I'm a few blocks north of a bunch of them). Solution: I'm not really sure. Any ideas?
I'm planning to get the coax cable anyway, and just test it, both on the balcony and in the bedroom, but given my earlier experiment, I'm not hopeful, at least not without doing something else different (maybe a better antenna?).
Unfortunately, I don't have an attic, and I can't put anything on my roof. I do have an outdoor balcony, but it's facing away from the antenna farm. So I'm not sure this is an improvement over having it indoors.
bcg123 is offline
Reply HDTV Technical
Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd
