The Official AVS Antenna and Related Hardware Topic! - Page 491 - AVS Forum | Home Theater Discussions And Reviews
 51Likes
post #14701 of 16629 Old 04-06-2012, 11:22 AM
tylerSC's Avatar
Quoted: 751 Post(s)
Liked: 171
The Clearstream 1 makes a very good indoor antenna, not only for UHF, but in my case, VHF as well. I get strong signals for UHF channels at 75 miles. And even the Clearstream 2 can be used indoors as well. And for fringe reception, the CS4 is very good, especially if a more compact size is needed instead of a DB8 or 4228.
tylerSC is offline
post #14702 of 16629 Old 04-06-2012, 01:24 PM
Dave Loudin's Avatar
I'll add that the Antennas Direct C5 can be an excellent solution for suburban to in-city locations where there are a lot of strong UHFs and a couple of VHFs that require moderate gain to receive. At UHF, the C5 is a pseudo-omni with negative gain. However, when you've got multiple signals with predicted noise margins of 40+, you don't need gain!
Dave Loudin is offline
post #14703 of 16629 Old 04-07-2012, 12:16 AM
Larry Kenney's Avatar
Quoted: 498 Post(s)
Liked: 78
A neighbor put up two Clearstream antennas that he found for sale on Craig's List... a C2 and C5 combination... and he's very pleased with the results. He is receiving all stations within 35 miles of here and they're coming in from several different directions from NW, West, South, Southeast and East.
Larry
SF
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is offline
post #14704 of 16629 Old 04-08-2012, 01:47 PM
ota.dt.man's Avatar
Originally Posted by holl_ands View Post
The best approach is to use a combination of either #1 (Tru-Spec 3GHz) or #2 (Holland GRB-AR) for protection against large (but very rare) surge voltage events and a solid state devices (Holland SA-1F) to drain off static electricity on a daily basis.
Since mast-mounted preamps can be damaged by surges, which of the recommended devices in holl_ands quote should be installed before the preamp?
Thank you
Broadcast TV - a vital national public resource
Just say "no" to a never-ending subscription TV bill that increases faster than the rate of inflation.
ota.dt.man is offline
post #14705 of 16629 Old 04-08-2012, 05:27 PM
300ohm's Avatar
Those are normally used after the preamp, before the coax goes into the house. Ive never seen one used before the preamp, but I suppose if the mast is thick and grounded, it could be done.
Keep in mind, with a direct lightning hit, the preamp would be toast anyway.
Re: Enclosure for balun.
In retrospec, the plastic easter egg shell may only last a couple years outdoors. (although some plastic things that don't need to be UV resistant are surprisingly UV resistant)
A more permanent enclosure would be to use one of the grey plastic electrical boxes, sealed at the top with weep holes at the bottom.
300ohm is offline
post #14706 of 16629 Old 04-09-2012, 09:11 AM
Calaveras's Avatar
Quoted: 1146 Post(s)
Liked: 260
Thank you
Maybe not so much. Modern preamps have built-in surge protection circuitry.
Winegard: "Specialized circuitry featuring fast recovery diode that protects against lightning-caused pulses. "
Tinlee: "Static discharge provided"
Channel Master: "Full lightning and surge protection"
A couple years ago I had a nearby lightning strike that took out the anemometer on my Davis weather station and two ports on a wired router but my preamps were unaffected.
Of course a direct lightning strike will take out the preamps and maybe even the antennas.
Two out of three of the holl_ands links are broken.
Chuck
Calaveras is online now
post #14707 of 16629 Old 04-09-2012, 09:23 AM
Calaveras's Avatar
Liked: 260
I've found that 2 liter soda bottles (#1 plastic) are essentially UV proof. I used one to cover up a 1.7 GHz dish feed from water because it was almost RF transparent and it turned out to be UV proof as well. No degradation after 5 years of sun exposure. I would think that the green colored bottles would make good UV filters although I have no way to measure the spectral transmission of them. I'm currently using 3 of them to cover up antenna feeds that don't like getting wet. They are easily cut to fit whatever is necessary.
Chuck
post #14708 of 16629 Old 04-09-2012, 09:28 AM
arxaw's Avatar
Originally Posted by Calaveras View Post
...Of course a direct lightning strike will take out the preamps and maybe even the antennas...
True. And even nearby hits can take out a preamp. The lightning can hit a tree or other nearby object, get into the ground system and fry the preamp or other equipment via that path. You never know what lightning is going to do!
arxaw is offline
post #14709 of 16629 Old 04-09-2012, 12:01 PM
ota.dt.man's Avatar
Chuck
Links repaired.
post #14710 of 16629 Old 04-09-2012, 03:32 PM
OTAhead's Avatar
Quoted: 12 Post(s)
Chuck
I live in southeast texas. Very hot summers and lots of rain (ok, ok, we did have a dought last year...), but my point is, we usually have 4-5 months of temps well above 90° (the majority above 95° and several days above 100°) along with lots and lots of rain during the year.
My solution to the mix of rain and heat is to stuff the f connector with a good quality dielectric grease to keep the moisture out and then cover the antenna balun with a rubber boot and then wrap the heck out of it with electrical tape which serves not only as an added protection for moisture but also protects the balun from direct sunlight. I also do the same thing for any connections on preamps. The dielectric grease is instrmental to keeping moisture out of the connection.
All I will say is that this has worked well for me. My last installation at my house has been in place since 2007 after I lost my previous rig to Hurricane Ike. Still going strong...
You never know where the LIMIT is until you EXCEED it... Dianne B. "Let's try that again... without the oops." (Will Smith and Jeff Goldblum in "Independence Day")
OTAhead is offline
post #14711 of 16629 Old 04-10-2012, 06:36 AM
Mister B's Avatar
Quoted: 17 Post(s)
Originally Posted by Mister B View Post
I recently purchased a Tivo Premiere with a one year commitment and discovered too late that it is known to have a rather poor OTA tuner.
My TV fool chart is http://www.tvfool.com/?option=com_wr...0b86526f12dec2
Originally Posted by arxaw View Post
You're correct about the Tivo tuners. Not very good with multipath.
Originally Posted by tylerSC View Post
The TiVo tuner is not as sensitive as most built in TV tuners, as I have compared to my Samsung using same antenna set up.
I purchased a "still new in box" previous model "Tivo HD" model # TCD652160 on-line. It arrived yesterday and the difference was amazing. I know one can not compare signal strength meters between models, but it was as much as 15 points higher on the Tivo HD model as the Premiere. Most importantly SNR's that had constantly fluctuated between 20 and 30 were quietly holding at 30 or 31. Absolutly no problems with picture break-up or drop-outs.
It is a shame to have to go to so much trouble and purchase a previous model to solve this problem, but it will work for me. I am primarily a "time-shifter" and I believe this unit will serve my needs nicely.
Mister B is offline
post #14712 of 16629 Old 04-10-2012, 06:00 PM
mp11's Avatar
You are correct. The last Tivo with a good OTA tumer was the TivoHD. I've had mine for 3 years now, and it performs very well. Even for TV DXing.
mp11 is offline
post #14713 of 16629 Old 04-11-2012, 07:56 AM
nathanks's Avatar
Looking for a nice antenna to pick up ABC, NBC, FOX, CBS in my area and distribute to 4 tvs. Here is a link to my results. I've never played with antennas at all so I am walking into this completely blind. I need all the help I can get.
I would prefer to have a small antenna that I could mount in the attic if possible. Any help you can offer is GREATLY appreciated.
URL is :
www . tvfool . com/?option=com_wrapper&Itemid=29&q=id%3d3616f0d649ec27
nathanks is offline
post #14714 of 16629 Old 04-11-2012, 08:27 AM
arxaw's Avatar
http://www.tvfool.com/?option=com_wr...3616f0d649ec27
Attic results are difficult to predict, due to building materials that can affect reception.
arxaw is offline
post #14715 of 16629 Old 04-11-2012, 10:24 AM
300ohm's Avatar
Ideally, you need a bidirectional wide beam uhf/vhf-hi antenna. There are no commercial antennas of that type. However, you can build your own.
This GH0n3 should suit your needs:
http://clients.teksavvy.com/~nickm/g..._8V5_12u1.html
Point it South West.
300ohm is offline
post #14716 of 16629 Old 04-11-2012, 10:35 AM
ADTech's Avatar
Quoted: 123 Post(s)
Liked: 65
Our V10 is pretty close to that. Our C2v with the reflector removed certainly is. Both are relatively short-medium under this scenario range.
Almost any panel antenna can have its reflector removed to make the UHF reception bidirectional. Adding a simple VHF dipole will make a simple VHF bi-directional antenna.
Tech support for Antennas Direct
ADTech is offline
post #14717 of 16629 Old 04-11-2012, 11:19 AM
ota.dt.man's Avatar
Chuck
Links repaired & model #s added:
post #14718 of 16629 Old 04-11-2012, 11:29 AM
ota.dt.man's Avatar
Understood. If one were to add surge protection before the preamp, which of holl_ands recommended device(s) would be best suited for this location? Agreed, with a direct hit, all bets are off.
Sounds great - Thank you.
post #14719 of 16629 Old 04-11-2012, 11:42 AM
ota.dt.man's Avatar
Chuck
Agreed, the major preamp brands do offer some degree of surge protection. But they do not provide detailed descriptions with specs for the surge protection.
Also, there are a few brands of ultra-low nosie amps (ULNA) that have little or no surge protection in order to achieve ultra low-noise levels.
post #14720 of 16629 Old 04-11-2012, 02:57 PM
holl_ands's Avatar
Quoted: 458 Post(s)
Liked: 190
Re Over-voltage Surge Protection:
I fixed the two missing links in my original Oct 2006 post:
http://www.avsforum.com/avs-vb/showthread.php?p=8591196
they are replaced by:
http://www.nottltd.com/lightning.html [NOTE STATIC DISSIPATION DEVICES.]
http://en.wikipedia.org/wiki/Varistor
http://www.teal.com/newsletter/AppsNote11.pdf
I also added the following, additional overview:
http://www.lightningman.com.au/surge_technologies.html
The protected voltage range is very high for most of these devices, providing minimal
benefit on the input of a Preamp. The only device with a fairly low protected voltage
range is the Holland SA-1F SiDACtor...and similar devices...but NOT MOV's since they
slowly degrade over time.
It might help to ALSO ensure that there is a LEAKAGE path from the antenna's
active element(s) to the nearest ground (e.g. mast, coax shield or ground wire).
This could be as simple as 10 K-ohm, 1W resistor(s) connected to balun feedpoint(s),
with a short wire to a nearby ground point. This will drain away static electricity....
Nearby Static Dissipation Devices (see new link above) might also be of interest....
holl_ands is online now
post #14721 of 16629 Old 04-11-2012, 06:45 PM
Calaveras's Avatar
Liked: 260
Maybe we need a little perspective on this. No manufacturer is going to put expensive multiple levels of surge protection into a device that sells in the range of $40. Even expensive preamps are mostly under $100. Some protection is better than none. I'm sure some preamps get zapped every year but most people will never have that experience. If the cost to insure is high compared to the value of what is being insured, then don't insure.
I've gone to a lot of trouble to get the lowest system noise figure possible and I'm not going to add devices that degrade that even 1 dB. I'll replace the preamps if they get zapped.
Chuck
post #14722 of 16629 Old 04-14-2012, 02:10 PM
See The Light's Avatar
Quoted: 48 Post(s)
Liked: 62
Clear Cast Indoor Antenna ? ?
The other day, there was a full page add in the Dallas Morning News for the Clear Cast indoor antenna. $47.00.
Does anyone have one ?
Are they any good ? ?
The add seemed to prey upon the gullible in that the add emphasized 935 free shows a year. And they gave a list of zip codes that were eligible ----- OTA digital TV is available to most zip codes anyway !!!
The add is selling itself as a "magic box" that you you use instead of cable or satellite to get all these "free channels".
But really, all it is, is an antenna. For $47....
So is it any better or worse than anything else out there ???
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
post #14723 of 16629 Old 04-14-2012, 04:14 PM
300ohm's Avatar
You mean this one ?
http://stopthecap.com/2011/12/19/hyp...bills-forever/
http://cameradigitalprinter.com/clea...al-x1-antenna/
Heh, yeah, SHOWS, not channels. So if you get 30 digital channels, and each channel has say 20 shows over a 24 hour period, that's 600 shows per day. So figure half the shows get cancelled in mid-season, so 900 or so shows a year isn't a terrible estimate.
Full page ads do cost a lot of money though.
Since there are no gain specs posted I can find, that says a lot.
300ohm is offline
post #14724 of 16629 Old 04-14-2012, 06:07 PM
tylerSC's Avatar
Quoted: 751 Post(s)
Liked: 171
That's a lot of marketing hype for a basic bow tie antenna placed inside a thin layer of plastic that can be hung from a window. The basic Radioshack version should work just as well. And the best performing flat panel antenna reportedly is the Mohu Leaf, which can also be hung from a window for about the same price as the Clear Cast.
tylerSC is offline
post #14725 of 16629 Old 04-14-2012, 06:58 PM
retiredengineer's Avatar
Quoted: 35 Post(s)
Liked: 24
I remember the same marketing hype back in the analog TV days where it was claimed the wiring in your house could be used to give you crystal clear ghost free TV reception. Just plug this device into the power outlet and hook it up to your TV. Inside was just a small capacitor soldered inside.
BTW a very recent review says the amplified Mohu Leaf is even better.
retiredengineer is offline
post #14726 of 16629 Old 04-15-2012, 07:32 AM
Calaveras's Avatar
Liked: 260
I think I saw that magic antenna in the fairytale land portion of Once Upon a Time.
post #14727 of 16629 Old 04-15-2012, 09:35 AM
dattier's Avatar
Quoted: 133 Post(s)
Liked: 57
I saw the ad in Parade today.  It lists out, state by state, every two-digit zip code prefix whose residents qualified for the offer.  Of course, it includes all fifty states and DC, and every two-digit zip code prefix in use in that state.  Yet they expect readers to be so gullible that when they find their state and the first two digits of their zip they'll consider themselves lucky to be eligible for an unbelievable opportunity.
dattier is offline
post #14728 of 16629 Old 04-15-2012, 09:37 AM
ota.dt.man's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=381623
http://www.nottltd.com/article.html [NOTE STATIC DISSIPATION DEVICES.]
Thanks for all the links. They should keep me busy. (Note this one link: http://www.nottltd.com/article.html doesn't work.)
Thanks also for the Holland SA-1F and 10 K-ohm, 1W resistor recommendations. Sounds like a plan!
post #14729 of 16629 Old 04-15-2012, 09:52 AM
ota.dt.man's Avatar
Chuck
I'm not suggesting manufacturers of cost-effective preamps add "expensive multiple levels of surge protection."
- Agreed.
My original post was for only those who may wish to add more protection to their current preamp - perhaps due to frequent lightning in their area.
post #14730 of 16629 Old 04-15-2012, 01:32 PM
holl_ands's Avatar
Quoted: 458 Post(s)
Liked: 190
THIS web-link IS currently active: http://www.nottltd.com/lightning.html
I also fixed the link to my original 5Oct2006 post:
Reply HDTV Technical
Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd
