The Official AVS Antenna and Related Hardware Topic! - Page 544 - AVS | Home Theater Discussions And Reviews
post #16291 of 16298 Old 10-15-2014, 07:06 PM
rabbit73's Avatar
Quoted: 16 Post(s)
Originally Posted by yilits28 View Post
We just need to prove the results that we got from the software antenna magus, we need it for our defense in our antenna project. Impedance,VSWR,Refelction Coefficient,Total Gain and wire diameter are some of the formulas we need.
You seem to be unwilling to tell us about your antenna, so you must consider it to be proprietary information.
The only way that I know how to prove your results are:
1. Hire someone to use other antenna design software to confirm your results.
4nec2 & Other Antenna Design Modeling Software
http://www.digitalhome.ca/forum/showthread.php?t=83772
4nec2
NEC based antenna modeler and optimizer
by Arie Voors
http://www.qsl.net/4nec2/
2. Construct your antenna and have the parameters in question measured at an antenna lab, to include comparison with an existing batwing antenna from a competitor.
https://www.google.com/search?output...na+magus&btnK=
http://www.antennamagus.com/ (a South African company)
https://www.cst.com/Content/Media/CS...agus-Flyer.pdf
http://www.antennamagus.com/contact-us.php
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #16292 of 16298 Old 10-16-2014, 01:50 AM
holl_ands's Avatar
Quoted: 97 Post(s)
Liked: 78
Even SIMPLE Antenna are actually very complicated and do NOT conform to some sort of "algebraic formula(s)" for description of (Horizontal+Vertical=Total) Forward Gain vs Frequency, 3-Dimensional Gain vs Frequency (not just a 2-D Horizontal or Vertical "slice"), Complex & Real Impedance vs Frequency and (where appropriate) Front/Back & Front/Rear Ratios vs Frequency, Beamwidth and Sidelobe Null Depth. And, of course, WIDEBAND Antennas are more complicated than Narrowband Antennas.
As described here, even a SIMPLE Yagi-Uda Antenna defies a closed-form solution:
http://en.wikipedia.org/wiki/Yagi-Uda_antenna
http://www.sm.rim.or.jp/~ymushiak/sub.yua.charts.htm [Almost all Quarter-Wavelength Dimensions, Just ONE of MANY Charts]
http://www.sm.rim.or.jp/~ymushiak/sub.ire.chart.htm [Folded Dipole]
Note that a presumably "optimized" 3-Element Yagi-Uda (IF nearly ALL dimensions were Quarter-Wavelength) would have a Characteristic Impedance of 28-ohms, which does NOT match very well to the usual 50-ohm Transmitter....and 4:1 Balun does NOT help...although a CAREFULLY designed Folded Dipole Active Element CAN minimize the SWR. Fortunately, modern Optimizers search across MANY different design parameters and find the set of dimensions which provide the "best" OVERALL COMPROMISE against a set of "balanced" performance criteria ("Target Function" in nikiml's Optimizer).
Mr. Yagi and Mr. Uda (and most other Antenna Designers) actually determined SOME of these performance parameters by constructing and TESTING hundreds if not thousands of Antennas with small changes in the various Dimensions and charting the results to find the "better" set of dimensions, recognizing that there are trade-offs of Gain vs SWR vs F/B & F/R Ratios. They (and others) did this for a small number of Elements...eventually adding a large number of (usually non-optimum) EQUALLY Spaced Directors, as described in fol. National Bureau of Standards (NBS) TN-688 "Yagi Antenna Design", Oct 1976:
http://tf.nist.gov/general/pdf/451.pdf
Various Software programs for Yagi, LPDA and other Antenna types have used Look-Up-Tables based on the above performance charts to "design" GOOD, but perhaps not OPTIMIZED Dimensions (as we do using 4nec2, nikiml's Scripts and other programs). For a given set of Element Diameters, there are FIVE Variables in a simple 3-Element Yagi Antenna, and 1+ONE additional Variables if ALL additional Directors are the same Length (like 91-XG) and 1+TWO additional Variables if additional Directors are allowed to be different Lengths for even better results.
The only way to verify an existing design or to "find" GOOD...or Optimized Dimensions for a given Antenna type is to use a Simulation Model (like NEC2 Engine within 4nec2 & nikiml Optimizer). Although there are alternative techniques, the most popular is the Method of Moments (MoM) calculation algorithms embedded within NEC2 & NEC4. MoM is an exhaustive process that calculates the effect that each and every small segment in each of the wires affects the mutual impedance coupling to each and every other segment in every other wire, deriving the performance parameters from these calculations.
Fortunately, 4nec2 is FREE and "only" requires the input of a set of "Wire Statements" that define the starting and ending points in X,Y,Z Coordinates....and a few other Environment and Housekeeping statements. The nikiml Optimizer requires one more step: the Optimization Dimensions need to be expressed as SYmbol Variables, rather than numeric X,Y,Z.
My ANTENNA SIMULATIONS link below leads to over 500 4nec2 models analyzed (nearly all TV Broadband), of which about 100 used nikiml's Python Optimization Scripts, so I understand it's become a fairly daunting process to sort through and find a good "example" to start with.
I would recommend UHF HOURGLASS-LOOP as a good SIMPLE 4nec2 and Optimization example, using only THREE SYmbol Variables: Height, Width and Source Gap (aka Length of Balun+Center Wires):
http://imageevent.com/holl_ands/dipoles/uhfbowties
If appropriate, look at UHF SOLID TRIANGLE BOWTIE as a good 4nec2 and Optimization example using Triangular structures to simulate a SOLID sheet of metal, using only THREE SYmbol Variables: Bow Length, Tine Separation and Feedpoint Separation:
http://imageevent.com/holl_ands/loops/uhfhourglassloop
holl_ands is offline
post #16293 of 16298 Old 10-16-2014, 04:13 PM
holl_ands's Avatar
Quoted: 97 Post(s)
Liked: 78
Looking through my 4nec2 files, I finally found 300ohm's BATWING 4nec2 files from way back in late 2009...which I got around to analyzing in late 2010....and now in 2014, I finished them up and uploaded to my imageevent webpage: [At the time I probably intended to try to improve the (too small) Screen Grid version, but never got A-Round-TUIT.]
http://imageevent.com/holl_ands/dipo...reflscreengrid
a) UHF Batwing - No Reflector:
UHF Raw Gain = 4.6 to 5.6 to 5.1 dBi and SWR (300-ohms) under 2.1
Raw Gain is FLAT to within +/- 0.5 dB with Excellent SWR.
b) UHF Batwing + 16-in H x 12-in W Screen Grid Reflector at 5-in:
UHF Raw Gain = 8.9 to 9.2 to 7.3 dBi, F/B & F/R Ratio Min = 12.4 dB and SWR (300-ohms) under 2.8.
Raw Gain drops off about 2 dB on higher frequencies with minimally acceptable SWR.
F/B & F/R Ratios should improve with somewhat larger Reflector and 1-in vice 2-in Spacings between Horizontal Wires.
BATWING, NO REFLECTOR (1 large square = 1.25 inches):
BATWING, 16-in H x 12-in W SCREEN GRID REFLECTOR:
post #16294 of 16298 Old 10-19-2014, 09:26 AM
SFischer1's Avatar
Quoted: 128 Post(s)
Liked: 30
Angry [HDTV-in-SFbay] Interference when DTV sets off
San Francisco, CA - OTA
https://groups.yahoo.com/neo/groups/...messages/30401
SHF
SFischer1 is online now
post #16295 of 16298 Old 11-03-2014, 09:24 AM
Stettin's Avatar
Adding info as requested
http://www.tvfool.com/?option=com_wr...d243d8dc5795e9
I currently have a Mohu Leaf attached to a HDHomerun in a second story bedroom window. I'm connecting the HD Homerun via a powerline ethernet connection. I get most channels except FOX perfectly. FOX will randomly break up to the point I have to resort to Hulu or other sources for my shows. I really need to get the antenna out of the bedroom as it is now a nursery. If the Mohu somehow doesn't get better signal, or is worse, I'll be buying a new "real" attic antenna.
My living room is on the other side of the house. It has a vaulted ceiling and garage & attic on the other side. I'd like to move the Mohu to the attic for height and run coax down the wall and out to my entertainment center where i'll directly attach to my HD Homerun.
1) Could being in an enclosed attic reduce my reception more than being in a window? I'm assuming I can hang the leaf higher in the attic than I can in my 2nd floor bedroom window.
2) What Ohm rating cable should I use? I've seen 50 and 75. I'm considering using a pre-crimped Male-to-Male and tack on a coupler. Should I just go with a Male-to-Female if I go pre-crimped?
3) If I go with a regular antenna, do I need to do any grounding if it will stay in the attic? could it require a different Ohm rated cable than the Mohu?
Location of antenna: Attic
HTPC: N/A - using HD Homerun (Antenna input, Ethernet output)
Length and type of coax. (Hopefully RG-6): Probably 50Ft RG6
House: In a bit of a dip, wouldn't say valley
Facing which direction? House south facing
Nearby buildings. Other houses, large trees everywhere
Nearby towers: FM radio station 1/2 mile away
The channel I'm having issues with is Fox -- 26.6 miles away
Stettin is offline
post #16296 of 16298 Old 11-03-2014, 10:19 AM
ctdish's Avatar
Quoted: 28 Post(s)
First do yourself and everyone else a favor and read this NOTE: Put YOUR LOCATION in the TITLE of ALL antenna threads & TVFOOL info in 1st post
Then post your location and TVFool results.
To answer your questions: 1 yes, 2 75 and need more info, 3 No 75 ohm cable is the standard for TV transmission lines.
John
ctdish is offline
post #16297 of 16298 Old 11-03-2014, 01:29 PM
Stettin's Avatar
John
Sorry for not posting location information, but didn't think it was relevant to my post as it was just about running cables. I'm really close to all but one tower, so figure if moving the Mohu doesn't work, I'll just get a higher end antenna after it. It has to move no matter what, so figured I'd just try out the new location before I make a purchase. I did update my original post though.
I already have a coax coupler so I can plug the Mohu end into the new RG6 cable. Would that reduce the signal in any significant way? If so, I can try to get a cable with a male and female end (as long as it isn't much more expenseive).
Stettin is offline
post #16298 of 16298 Unread Today, 11:47 PM
Gooppoiner's Avatar
Location: 2908 Simons Hollow Road Mahanoy City, PA 17948
Liked: 0
Antennacraft HDVIEW360 R Mini-State R Antenna System RF Remote/Direction Memory is latest technology of TV antenna known to me so far. I really did my reasearch before I bought this product .Its best TV antenna I ever had
Gooppoiner is online now
Reply HDTV Technical
Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd
