VHF/UHF Antenna Recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-14-2004, 05:19 PM - Thread Starter
Ron Alcasid's Avatar
According to antennaweb.org I live approximately 3 miles from most of the local broadcast towers. I need to pick up VHF and UHF frequencies. Any suggestions on which antenna to get? I will be using an LG 3100A OTA set top box which is known to be very sensitive.
Ron Alcasid is offline
post #2 of 2 Old 04-14-2004, 08:43 PM
leesweet's Avatar
Ron, you might want to check in the Local HD forum for a thread for your area (and put your location in the location field in your profile, since we can't tell where you are). But at *that* range, a coat hanger should do for digital signals! The Squareshooter is one good antenna for that sort of thing (for outside), so's the Silversensor (for inside).
See www.********************* for one good AVS sponsor to get them from!
http://www.*********************/accessories.htm
-Lee (See my profile for equipment.)
leesweet is offline
Closed Thread HDTV Technical
