Originally Posted by
dogleg69 /forum/post/15823954
If the 2.7.15 box allows you to scan and then says USDTV service not found, that is good news -- it sounds like it is a subscription box. If it was working before, I have no idea how an FTA box jumped back to subscription unless the rollback sequence was initiated.
On the 2.7.15 box, here is what I would suggest:
- go to
www.mediafire.com/dogleg69
- navigate to the windows --> archive directory
- download the fromService293.zip file
- unzip the file and follow the instructions inside the file
- try and use a 32mb usb stick (or something smaller than a 1gb)
- after the usb is made, unplug the box, stick the usb in the back, plug back in and follow on screen instructions
- if that works, you will have an FTA with 2.9.3 version.
- now download the latest usdtvUpdate295ForWindowsFAT.zip and follow the instructions in it to upgrade to 2.9.5
Sorry you have to go through two steps, but that is the easiest way with the software is posted. Let us know if it works or if you need any other help.
