HDCP compliant DVI cables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-10-2004, 11:34 AM - Thread Starter
jamny's Avatar
While doing some research on DVI-HDCP, I found this website that had DVI cables that said they are "HDCP compliant"
Is there such a thing? Is this something to consider when hooking up a player with HDCP?
Here's the site:
link
jamny is offline
post #2 of 5 Old 12-10-2004, 12:24 PM
Mort's Avatar
I doubt one could be made that wasn't....and still pass data.
Mort
Mort is offline
post #3 of 5 Old 12-10-2004, 12:29 PM
greywolf's Avatar
Location: Evanston IL 60202 11 mi from Chicago transmitters
I guess it's not really false but then all DVI/HDMI cables could be called HDCP compliant. In the same way, all antennas are HDTV antennas. Marketing has been talking to engineering again.
Pat
While I may link to and mention products as examples, I don't recommend specific products.
greywolf is offline
post #4 of 5 Old 12-11-2004, 02:05 PM
amillians's Avatar
Well, there were (are?) certain classes of DVI fiber cables (e.g., all fiber, with the breakoff connectors, early models) that couldn't handle a bidirectional DDC conversation, which effectively meant no HDCP support. Still, these represent(ed) a *very* small and niche segment of the overall DVI cable market, so marketing a DVI as HDCP compliant does smack of overkill to some extent.
Alex doesn't live here anymore
amillians is offline
post #5 of 5 Old 12-11-2004, 02:36 PM - Thread Starter
jamny's Avatar
Thank-you.
That's what I suspected. I just didn't want to buy the wrong stuff.
jamny is offline
Closed Thread HDTV Technical
