CableCards: We should NOT give up - Page 32 - AVS Forum | Home Theater Discussions And Reviews
post #931 of 953 Old 02-14-2008, 03:52 PM
phunternj's Avatar
Anybody has recent FIOS Cable Card experience?
The FIOS install in my neighborhood is imminent and I wanted some real world feedback.
phunternj is offline
post #932 of 953 Old 02-27-2008, 12:32 PM
chicolow's Avatar
I have spoke with many people who have switched to the FIOS system which uses a Motorola CableCARD and they absolutly love it. Only thing is that if your TV has the TV Guide on Screen feature it will no longer work.
chicolow is offline
post #933 of 953 Old 02-27-2008, 01:12 PM
FredB's Avatar
I have been using two bedroom TV's with CableCard. No problems. FIOS installation was back in April 2007. When watching SD channels CableCard picture quality is vastly superior to the SD box or the HD-DVR. Not much difference in HD.
FredB is offline
post #934 of 953 Old 02-27-2008, 01:17 PM
FredB's Avatar
I have Panasonic plasma with TV Guide feature, and it works just fine with Motorola CabeCard.
FredB is offline
post #935 of 953 Old 02-27-2008, 03:44 PM
optivity's Avatar
You're giving me reason to hope!
I have (2) PDPs & both are equipped with CableCARD slots but I stopped using a CableCARD because Time Warner is using SDV to add HD channels.
I also have FiOS Internet/phone service, but no FiOS TV is available in Upstate NY yet.
optivity is offline
post #936 of 953 Old 02-27-2008, 04:05 PM
FredB's Avatar
Right now, I'd say Verizon FIOS is the best deal. Excellent picture quality, more channel choice than most cable systems, highly reliable and fast internet, solid land line phone system and reasonable rates. Before, I was with Time Warner for more than 20 years in the same location (including its predecessor cable companies.) I can see the difference. I hope they will not get complacent and lower their standards in the future.
FredB is offline
post #937 of 953 Old 02-27-2008, 04:18 PM
optivity's Avatar
Verizon FiOS offered me Internet & phone service for 2 years @ $69.99 per month.
How many HD channels does your FiOS provider carry?
optivity is offline
post #938 of 953 Old 02-27-2008, 04:48 PM
bfdtv's Avatar
Verizon FiOS has ~30 HD channels, but four of those are premiums.
Verizon FiOS has said it will add 30 new HD channels for 60 total this spring, although the actual schedule is more like this:
IN(VHO10) 4/1
VA(VHO9) 4/7
VA(VHO9a) 4/14
NY(VHO5) 4/21
MA(VHO6) 5/12
RI(VHO6a) 5/12
DE(VHO8) 6/2
PA(VHO8) 6/2
NJ(VHO8) 6/2
NJ(VHO7) 6/23
MD(VHO4) 7/21
VA(VHO4) 7/21
FL(VHO2) 8/18
CA(VHO3) 9/1
TX(VHO1) 9/22
bfdtv is offline
post #939 of 953 Old 02-27-2008, 05:10 PM
Contsi's Avatar
I have CC on Panasonic (TV Guide works fine), what do you use instead of cable card for SDV?
Contsi is offline
post #940 of 953 Old 02-27-2008, 06:57 PM
bfdtv's Avatar
To receive SDV channels, you'll need either the cable company's box, or a Tivo with the upcoming USB SDV adapter.
Verizon FiOS does not use SDV so that wouldn't be an issue with that provider.
bfdtv is offline
post #941 of 953 Old 02-29-2008, 01:35 AM
dbruce's Avatar
I'm about to get my new HDTV hooked up in a week or so. I'm on IO from Cablevision in the CT area.
The HD 4200 box they supply is crap.....slow menu system and just bad overall. There DVR option is another 10 a month and isn't supposed to be that great either.
I have straight family cable and don't use any of the VOD functions. The TV I bought, Sony xbr4, does not have a cable card hookup and the QAM will only receive the non-encrypted channels. Is there an external card reader, without the Tivo subscription fees etc, that will work instead of the Cablevision supplied SA box? If I'm stuck with the SA box model 4200, can I just buy one and have Cablevision install the Cablecard into (so I get rid of the rental fees)?
I just want my channels and don't need the menu system etc (it sucks with the Cablevision box......so I'll find a way to live without it.
dbruce is offline
post #942 of 953 Old 02-29-2008, 03:33 AM
bicker1's Avatar
Sorry, but nothing currently in production.
bicker1 is offline
post #943 of 953 Old 02-29-2008, 06:31 AM
dbruce's Avatar
What about buying a 4200 or 4300 and having IO cable install the cards?
dbruce is offline
post #944 of 953 Old 02-29-2008, 06:53 AM
dbruce's Avatar
Buying the boxes is out, since they will either be stolen.....or Cablevision will tell you to jump in a lake if they aren't.
CableCARD or nothing......so I'm stuck between a rock and a hard place. I also don't have any other options, since my building doesn't allow SAT.
I hate cable.
dbruce is offline
post #945 of 953 Old 02-29-2008, 07:10 AM
ftaok's Avatar
I hate cable.
Well, if you don't want a Tivo, your only other options are a CableCard HTPC. These things are expensive, but they work.
As for Satellite, there are certain FCC "laws" that prohibit a building manager from stopping people from getting Satellite. You should look into that if you really want Satellite.
ft
ftaok is offline
post #946 of 953 Old 02-29-2008, 07:26 AM
davehancock's Avatar
Quoted: 111 Post(s)
Liked: 60
While there are such laws, they don't go far enough to enable most renters to get satellite.
Dave Hancock
davehancock is offline
post #947 of 953 Old 02-29-2008, 08:31 AM
dbruce's Avatar
ft
I'm a condo owner....and do not have an area in which I have sole use to hang a dish.
http://www.fcc.gov/mb/facts/otard.html
Bummer.....but without a balcony that is mine....I'm screwed.
The HTPC is another option. I do have a bunch of machines laying around......so I might, with enough time, be able to set something up.
dbruce is offline
post #948 of 953 Old 03-04-2008, 11:50 AM
chaz01's Avatar
Same here and in Massachusetts with a northeast facing balcony....
SIGH....
chaz01 is offline
post #949 of 953 Old 03-04-2008, 08:42 PM
dbruce's Avatar
SIGH....
I got my new Sony Bravia and hooked up the the SA4250HD. The updated version, from the one my friend has, uses a HDMI port and the menu system is decently fast. It's not as fast as the non-HD version.....but for 6 bucks a month....I can live with it.
In addition, I also hooked up the cable directly to the TV and am able to use QAM for PiP with non-encrypted channels. Good enough for now.
dbruce is offline
post #950 of 953 Old 03-23-2008, 07:29 PM
RadYOacTve's Avatar
Quoted: 40 Post(s)
I moved my Panasonic TH-42PX500U to my bedroom about a month ago and had the cable company install a cable card and it works great. No problems with the install and it took a few minutes for the channels to load. A perfect solution for my bedroom and can still get all of my pay and HD channels.
RadYOacTve is offline
post #951 of 953 Old 03-29-2008, 06:48 AM
kneostyl's Avatar
I was reading through this thread and thought i should throw out a few thoughts about working with cable cards.
Cable cards a very sensitive creatures. They will not work unless the signal being provided to them is almost flawless.
1. This includes the SIGNAL LEVEL in dB coming to them. The signal range that general cable eq works at in the field is 0 to +10dB with analog signals and 0 to -10dB with digital signals. (please note that every channels typically has a slightly different signal level; meaning while one of your HD stations may be within signal range another HD channel could be out) However with cable cards that signal range seems to be closed down meaning keep the digitals away from that -10dB mark as well as that 0dB mark. (note that cable network's levels change slightly, 1-3 dB, all the time. so that is why it is so important to squeeze that range down to, let's say -3 to -7dB on the digital side.
2. In order to get all of your wonderful HD content the QAM signal coming in must be free of errors. What we are talking about is making sure your BER and MER are at good levels and free of most errors or at least so few errors that they are correctable by FEC. (These two refer to the quality of the signal)
3. A third huge important issue is to make sure that not just the line going to your cable card device is perfect but that all your lines are free of NOISE and INGRESS. Bad fittings, poor line sheilding, RG59, tight bends, staples, old tvs or other devices that feed noie back, nicks and cuts, old splitters, radio shack amplifiers, are all things which can ruin the quality of QAM signal by getting allowing noise to mix with it.
4. Even with the perfection of the all of the above by your cable technician and of your home/business wiring there is still the idea of PROVISIONING. There aree always going to be computer/human mistakes in the balancing and provisioning of eq on your account, and unfortunatley you have no control over it. All you can do is to keep asking if your account is balanced and try to find the person at the cable or other hd provider who is the account/cable card specific guru.
5. Additional problems can include customer eq, which seems like the primary issue addressed on this thread, so i'll be breif. Firmware upgrades are important and most cable card devices now include the correct firmware. Bottom line: if you are having issues esp getting an error code, contact the manufacturer to see if you need a firmware upgrade, they dont make money by contacting you.
Ladies and gentlmen, I hope some of this has been helpful. In conclusion cable cards do provide a better quality picture allowing you to get all your fav chs(minus 2way services) but at the cost of the patience and time in setting them up.
tech out.
kneostyl is offline
post #952 of 953 Old 04-01-2008, 11:11 AM
chicolow's Avatar
I have a friend who has a Motorola M-Card installed and her FW upgraded to the latest version. All the channels were coming in even encrypted for around 15 min, and then after the Cable tech left the cable card dropped out again. I checked the CC errors diag screen and saw an error "Failed to Set DCFR 4". I pointed out this error to the cable tech who had no idea what this meant and advised me he is going to contact his Head end tech which was over a week ago. Can anyone tell me what this error means. Thanks.
chicolow is offline
post #953 of 953 Old 05-14-2008, 07:33 AM - Thread Starter
Super Moderator
markrubin's Avatar
Quoted: 1218 Post(s)
Liked: 2694
I finally did give up:
too many issues with the one way cable card and with Comcast in general: their customer service and unwillingness to resolve cablecard issues wore me down
First I turned in 4 cablecards from Sharp LCD TV's: then sold my Tivo S3 which kept losing the cablecard signal: signal levels started to vary wildly over the last year: I saw signal levels vary by 15 db from week to week probably due to road construction in my area
I canceled my Comcast TV service (still have Comcast internet with Blast) and went to DirecTV HD
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
Reply HDTV Technical
