How do I change the resolution from 1080 to 720 on my SA 8300hd? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-20-2005, 05:34 PM - Thread Starter
rohanman's Avatar
I have a Sony A10 which is best with 720p and a SA 8300hd so I would want my cable on 720, right. I cant figure out how to change it to 720 on the cable box though.
Thanks for the help.
rohanman is offline
post #2 of 5 Old 09-20-2005, 07:01 PM - Thread Starter
rohanman's Avatar
Do I just put it on Pass-through???
rohanman is offline
post #3 of 5 Old 09-20-2005, 07:07 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Change picture mode to 'Fixed' first then you can select 720p as your output resolution. Use Pass-through if you like the scaler inside the TV.
Foxbat121 is offline
post #4 of 5 Old 09-20-2005, 07:23 PM - Thread Starter
rohanman's Avatar
Do i have to do the info/guide trick to set it to 720, and if so, should i only select 720p???
rohanman is offline
post #5 of 5 Old 09-21-2005, 07:44 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
No. It is in normal settings menu. Press settings button twice for advanced settings to set picture format setting and then exit and press once for resolution setting.
Closed Thread HDTV Technical
