DirecTV H20 (non-DVR) Official Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
Old 02-22-2006, 10:55 AM
Kenn157's Avatar
Hey everyone! Which satellite carries the HD locals? I want to check the signal strenghts. DirecTech was out the other day because the wind blew the dish off alignment. My CBS(Boston) and NBC(Boston) are freezing up. The OTA antenna I have hooked up is getting the transmission without any problems. So when I check settings and signal strenghts which satellite and what should be the signal strenght be?
Thanks everyone!
Kenn
Kenn157 is offline
jgido759's Avatar
Originally Posted by arxaw View Post
It's in Setup Info in the Menu.
I looked there last night and couldn't see it.
Is that the menu that lists the TV type, etc?
Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection
jgido759 is offline
Old 02-22-2006, 11:19 AM
writenick's Avatar
rowdy2005,
Doesn't that sony convert everything to 1366 x 768? If so, you might try 720p or 1080i (instead of native output) on the H20 and compare PQ. It might look better than native and the channel changes may be faster.
arxaw,
I have a new Panny 42px50U and I would like to have the TV control the resolution not the H20. In that case, I assume I should set the H20 to native. Am I making a mistake? Does that slow down channel reception a lot?
What would you recommend? I am having difficulty following all this new information.
Thanks in advance.
writenick is offline
Old 02-22-2006, 11:26 AM
rrrick8's Avatar
Thanks everyone!
Kenn
The 103 sat carries the MEG4 HD locals.
Rick
Charter D** Customer
"I hate words." "Words suck." "If I wanted to read, I'd go to school." Beavis & Butthead
rrrick8 is offline
Old 02-22-2006, 11:27 AM
writenick's Avatar
Originally Posted by shakyblack View Post
Hey guys I'm getting my D-TV HD setup next week I wanted to make sure I have everthing I need before They get here to install the system. D-TV wouldn't tell me which Receiver I would get but its the one that's got the $200 rebate which I'm pretty sure is the H20. Okay anyway is the new dish and the receiver all I need to get my hd channels in the Bakersfield area.
I'm in Fresno and getting H20 this weekend. I understand locals in HD will be available in May. Since Direct TV is offering 3 months of HD programming free, by the time I start paying for it, the locals will be broadcasting in HD. I'm not going to worry about an antenna for OTA for the next 3 months.
Old 02-22-2006, 11:30 AM
rrrick8's Avatar
Select; [Menu] - [Settings] - [Setup] - [Info & Test] - scroll down to "Software".
0F06 is the newest.
Rick
rrrick8 is offline
Old 02-22-2006, 11:37 AM
Kenn157's Avatar
Cool! Ok now according to my signal meter it reads as follows
1-8 5=0, 6=79, 7=25, 8=NA
9-16 13=0, 14=77, 15=33, 16=0
17-24 20=0, 21=0, 22=0, 23=0, 24=NA
25-32 25=0, 26=0, 27=NA, 28=NA, 29=0, 30=0, 31=0, 32=NA
How are those for signal strenghts?
Kenn
Kenn157 is offline
Old 02-22-2006, 11:50 AM
dsanbo's Avatar
0F06 is the newest.
[SELECT] on [Info & Test] to open the "tab", then scroll; the "Software" version is under this tab, not the first one seen, if memory serves.....but, yes....0F06 IS the latest...I understand it has been rolled out to all areas by now (2/22)....
dsanbo is offline
Old 02-22-2006, 11:52 AM
slackrl's Avatar
Thanks everyone!
Kenn
Kenn157
As stated earlier it will be the 103 Sat
the H20 reference signal strengths read lower than the older receivers.
Expect signal strenths from 69-100 with very few if not no 100's usually 70-80's is good.
Here is a link on this forum listing reported signal strengths ( Be Sure to scroll through the Listings )
H20 Signal Strenths AVS H20 Forum Page 30
You might request other H20 owners in your area post their siganal reading to help give you a better idea.
Related help . Here a link that will may be of further assistance to all, although I have not figured out every thing it shows. LynSat DirecTv Chanel to Sat Locations
RSlack
slackrl is offline
Old 02-22-2006, 11:57 AM
dsanbo's Avatar
How's are those for signal strenghts?
Kenn
If I'm not mistaken.....there's a 103/Network 14 and /15 set of readings...Which are these? Don't remember exactly what my readings are...but I know there are only a couple of xpdrs on EACH "Network" set (/14 and /15)....and the LOWEST reading I get is 45 one one (not sure which), 66 on another and the rest (6 or 7) arein the 90s to 100...... Are you sure the big "blow last Friday didn't knock out your AT-9's alignment??
dsanbo is offline
Old 02-22-2006, 12:10 PM
Steve Wright's Avatar
If I read the Lyngsat table correctly, all NY locals are on the same beam. Therefore, if CBS is coming in poorly and all the other channels are not affected, the problem should be on D*'s end. CBS would not be on a different transponder than the other networks.
Steve Wright is offline
Old 02-22-2006, 12:46 PM
jgido759's Avatar
Thank you, rrrick8 & dsanbo.
Somehow I believe that I was looking there and did not see a "Software" entry. I'll look again tonight when I get home from work.
-Drew Carey
-Unknown
My DVD Collection
jgido759 is offline
Old 02-22-2006, 01:29 PM
arxaw's Avatar
There is more than 1 "page" of information listed. When you get to Info, push the SELECT then the DOWN ARROW to scroll down to see the version number.
arxaw is offline
Old 02-22-2006, 01:34 PM
Kenn157's Avatar
These are from 103/14. I didnt include 15 because thay are all N/A. Unless 15 is supposed to have signals?!?!?!
Kenn157 is offline
Old 02-22-2006, 01:51 PM
Kenn157's Avatar
I said it did knock it out of alignment. I've had D* since 1994. I know which direction the dish points. When I came home from work it was pointing in the opposite direction.
There is no signal strenghts on 103/15. Do you have any?
Kenn157 is offline
Old 02-22-2006, 03:10 PM
rlockshin's Avatar
Originally Posted by writenick View Post
arxaw,
Thanks in advance.
yes you are. I have the 37 inch ister model of your Panny . Do NOT set to Native. I coiuld not see any difference. I set mine to 1080i and leave it there,set will decode for you
NO NATIVE!!!
rlockshin is offline
Old 02-22-2006, 03:35 PM
sadmaker's Avatar
ok, i dont know if this is normal or if my H20 is screwed. channels 104-107(i believe), the newsmix/sportsmix/kids mix channels all tune fine, but do not give me the option to switch from box to box with my remote or hit select on the channel to tune in. kind of a pain to explain, but those of you with the R10 know what im talking about. anybody else having this problem?
XBL Gamertag: RagingPhinsFan
sadmaker is offline
Old 02-22-2006, 03:44 PM
arxaw's Avatar
arxaw,
I don't think you'll see a difference on that TV with Native disabled. In fact, some channels may look better if you let the H20 convert everything to one format. Channel changes will be faster too (between some channels).
With Native OFF, look at the TV image and cycle through 720p & 1080i (using the H20 Format button on the remote). Decide which resolution looks best to you on your display. Then go back and turn off the other resolutions in the H20 menu.
arxaw is offline
Old 02-22-2006, 03:46 PM
arxaw's Avatar
IIRC, that option isn't working (yet).
arxaw is offline
Chorgey's Avatar
Are you trying to select the different boxes/channels as if it were a DVD menu, where you would choose a chapter, highlight it, click on it and it takes you there? If so, I don't believe that can be achieved on the H20 (yet)
Chorgey is offline
Old 02-22-2006, 03:51 PM
slackrl's Avatar
With the H20 you can not scroll and select to tune this channels from this windowed screen.
-To tune to the Channel you will have to enter the channel number and press select.
-To Hear the Channel you will have to press (I think ) the blue button on your remote which will switch the sound to each channel window displayed on the mix channel you are viewing.
Not in front of the TV at present will check it and correct this post provided non of the other users here correct this note....
RSlack
slackrl is offline
Old 02-22-2006, 05:11 PM
writenick's Avatar
Thanks guys for straightening me out on 720P and 1080i, no Native, etc.
Now I need help on something else.
I have a built in cabinet in the wall that houses a 27" color stream Toshiba TV (not HD), a VCR, and a SD satellite receiver. All are currently hooked up via coax.
Current hook-up (all in cabinet):
Dish in to receiver via coax
receiver out to VCR via coax
VCR out to TV via coax
My new Panny is too big for built-in so this is my thought:
Leave in cabinet:
Dish in to HD20 receiver via coax
Receiver to TV via component (to take advantage of color stream feature)
Receiver to VCR via composite (no coax out of HD20 available)
VCR to TV via composite OR VCR to TV via coax
HD20 receiver in to Panny (outside cabinet) via HDMI cable
Now, the question is, do I need to set up 480i in the Format as a selection on the remote so that signal will go to the old TV and VCR?
I am assuming by simply turning the Panny off and the old TV on 480i will be going to the old TV.
Do you see any problem recording on the VCR as normal, just by setting the timer, etc.?
Any help is appreciated. Thank you.
Old 02-22-2006, 05:12 PM
sadmaker's Avatar
well, at least its not my reciever. thanks for the quick responses, guys
sadmaker is offline
Old 02-22-2006, 06:13 PM
Lumpy's Avatar
Just got my H20 yesterday. I tried to read as much of this thread as I could so I hope I don't repeat whats already been discussed.
First my take on what HAS been said.
PQ is the best out of the three HD recievers I now have:
H20-600
HR10-250
Samsung 360
Menu's and guide are pathetic. Slow, confusing, lacking many must have features, etc.
A couple of things I didn't see in this thread
The H20 is hooked to a Viewsonic n2750w 16:9 LCD. One of my main concerns before my H20 arrived was how it would deal with letterbox SD on a 16:9 display that doesn't zoom. I hate having pillars and bars with a small image in the middle. A serious issue for my Samsung CRT RP 16:9 HDTV(which the Sammy can and has to adjust for). It's connected to the HR10-250 which has no zoom, only aspect correction(adding bars but no stretch zoom crop or whatever).
The H20 has crop which solves that for me and does it without distortion. The Sammy HDTV when set to zoom1 fills the screen but is slightly squashed vertically making everyone a little shorter and rounder.
The problem is it has the 3 formats(pillar box, stretch and crop) for all four resolutions so either you browse the endless menus and set it to crop or you cycle through the dozen choices with the format button.
Figured it out. Just had to turn native on and after finally finding it, turn off the resolution I didn't want. Now I can switch to crop with only a couple presses of the format button.
Speaking of letterbox, I've noticed I never see the LB icon in the guide or banner.
Now that crop is easy I don't care wether I know it's LB or not. I found the LB icons. It would be nice if they appeared in the guide.
Since going HD I've had to do a lot more button pushing when switching between programs with different resolutions and formats. The H20 seems to just add more button pushes.
Oh well. In spite of it's shortcomings the most important thing is PQ and it's outstanding. That makes me a happy customer. It took 2 visits and 3 installers 5 days to get me going mainly because they didn't have all the dish parts yet. I'm basically one of the first to get upgraded in my area (market 130+) which won't be eligable for mpeg4 for some time.
Lumpy is offline
Old 02-23-2006, 12:06 AM
bitemymac's Avatar
Anyone notice PQ improvement with new 0f06 firmware update?...
I'm not sure if I'm imagining things but I see less pixelation on 1080i MPEG2 broadcast. Some fast flashing scenes used to show noticeable pixel blocks, but now it's lessen. I know the firmware is claim to fix or improve local HD MPEG4 broadcast, but I didn't see much improvements on the MPEG4, though.
bitemymac is offline
Old 02-23-2006, 04:12 AM
Guitar Hero's Avatar
I got the new update, and I don't notice anything new...
Guitar Hero is offline
Old 02-23-2006, 07:49 AM
rrrick8's Avatar
You cannot "select" a channel to view from the remote. However you can select the "Audio" from each of the "thumbnails" by using the yellow button on the remote. Each time you hit it (yellow button) the audio will switch to the next channel.
Rick
rrrick8 is offline
Old 02-23-2006, 08:16 AM
arxaw's Avatar
... Now, the question is, do I need to set up 480i in the Format as a selection on the remote so that signal will go to the old TV and VCR?
IIRC, the composite & s/video jacks will output 480i automatically. But if you're using component out to a non-progressive scan, non-hd TV (Toshiba), you'll have to manually change the resolution to 480i to watch it. And since the non-hd tv is 4:3, you may have 4:3/16:9 formatting issues.
You wouldn't have to turn the Panny off, but you'd have to change the resolution to 480i if you're using component out to the toshiba.
Just remember VCR should be tuned to LINE input, not ch 3 or 4 when setting up a timed recording. And you may have formatting issues, depending on which TV (4:3 or 16:9) you're watching the recorded program on...
arxaw is offline
Old 02-23-2006, 08:29 AM
writenick's Avatar
Thanks, arxaw.
I understand everything you are saying.
I will probably use s-video to the old TV then so I don't have issues with aspect, etc.
One more question: My old set-up (SD) used coax cables to/from satellite receiver, VCR, and TV. I believe coax is better than composite or S-video for SD. Am I correct? Will I see a step down in PQ since I can't use coax out of the receiver any longer? (The new H20 has no coax out). I guess I shouldn't worry about it too much because this set-up is only for taping and watching on VCR, which is a step down in itself. I just don't want to watch this lower quality on my new Panny.
Old 02-23-2006, 09:20 AM
greywolf's Avatar
Location: Evanston IL 60202 11 mi from Chicago transmitters
Coax (RF) is the worst. Composite is better and S-video is the best of the SD connections.
Pat
While I may link to and mention products as examples, I don't recommend specific products.
greywolf is offline
