OVER-THE-AIR DIGITAL TELEVISION RECEPTION FAQ: New to OTA? Start here! - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 248 Old 06-28-2013, 03:10 PM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
WBFAir, I'd suggest one of These which also has the ability to record, with a USB drive. They've recently jumped up $10 but still for under $60 you'd be hard pressed to find anything decent cheaper.
If you think you'd gain anything with S-video, want a better EPG or need a VERY sensitive tuner then I'd suggest a CM-7000(I own 5) which is only available used and for inflated prices, it's AVS master thread is here.
I'd really suggest the iView(I own 2) and having the ability to record in HD(and output SD for your old TVs) is quite handy. It's impressive master AVS thread(regularly updated by Videobruce) is here.
jjeff is online now
post #242 of 248 Old 01-07-2014, 06:39 PM
guspatino's Avatar
I bought an antenna to get OTA
My TV has an digital audio output.
Will I be able to use the digital audio output to connect it to my receiver or will I only be able to listen to the TV speakers?
So far I'm only able to listen to the TV speakers.
guspatino is offline
post #243 of 248 Old 01-07-2014, 10:39 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
What digital audio out formats (DD, PCM, etc.) does your TV put out? What digital audio formats will your receiver accept?
domino92024 is offline
post #244 of 248 Old 01-07-2014, 11:49 PM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
Yes. If you have a receiver that can accept an optical cable then you can listen to discrete 5.1 audio via OTA thru the tv's ATSC tuner if your receiver can decode 5.1 when broadcast.
Otto Pylot is offline
post #245 of 248 Old 01-08-2014, 11:07 AM
holl_ands's Avatar
Quoted: 434 Post(s)
Liked: 179
Sometimes the HDTV only provides Digital Audio va a (SPDIF) RCA type Coax connector. If your AVR doesn't have Digital Audio RCA Coax input, you can get an inexpensive Coax-to-Coax Converter. In HDTV Audio Menus, there is probably a selection between PCM (Stereo) and Dolby Digital (DD5.1) output stream format.
holl_ands is offline
post #246 of 248 Old 01-08-2014, 12:24 PM
Buckeye911's Avatar
Like the others have stated, if your AVR has a matching input to your TV's digital audio output you will be able to connect and get 5.1 audio. If your receiver does not have the appropriate digital input you can still get 2.0 audio through your receiver by connecting the RCA cables (red and white) from your TV to your receiver. Almost every TV and AVR has these RCA connections.
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #247 of 248 Old 01-11-2014, 04:01 PM
guspatino's Avatar
I'm not sure.  My TV is a Panasonic TC P50s30.
My amplifier is an HK 990.
I'm able to use the digital audio cable (optical) from the PS3 to the HK 990 but no sound from the TV to the HK 990
post #248 of 248 Old 01-11-2014, 07:17 PM - Thread Starter
Super Moderator
DrDon's Avatar
Quoted: 868 Post(s)
Liked: 1726
Try inquiring in the Display area appropriate for your set.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Reply HDTV Technical
