Wrapping wire around antenna improves reception? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-01-2006, 07:01 PM - Thread Starter
wures7's Avatar
I can't get about 4 HD channels from my outdoor antenna. Is it possible that if I tightly wrap copper wire around my antenna, it would improve reception and possibly pick channels that I cannot before? What do you guys think?
wures7 is offline
post #2 of 7 Old 01-01-2006, 07:05 PM
richard korsgren's Avatar
I believe there are other ways to improve the reception of those 4 HD stations. As to wrapping wire around antenna, never heard of such a thing. Give it a try if you'd like. Give us more detail on where the transmitters are in relation to your home. And some other details.
richard korsgren is offline
post #3 of 7 Old 01-01-2006, 07:06 PM
TerryB's Avatar
If Dagwood hanging from the mast can make an improvement, wire couldn't hurt. On the other hand, I doubt it will improve it enough to risk any roof work solely for the purpose.
TerryB
TerryB is offline
post #4 of 7 Old 01-01-2006, 07:17 PM - Thread Starter
wures7's Avatar
I live in the LA area and the 4 channels that I cannot get are less than 10 miles from me according to antennaweb. In fact, every channel is less than 10 miles and I pick up most of them just fine. I cannot pick up FOX and CBS. NBC and ABC comes in weak. It's been raining here the past two days and I notice that reception is a little better on NBC and ABC. I think it has something to do with my antenna getting wet from the rain and it seems to help it pick up signals a little better.
wures7 is offline
post #5 of 7 Old 01-01-2006, 07:26 PM
wures: How is the line of sight from home to transmitters? Are all transmitters ( from stations) in same area and about the same direction (in degrees) from your home? If line of sight is good, then a simple directional digital antenna should do the trick. You can pick up the minor stations but not the major CBS, NBC, and ABC, correct? And you are sure your digital antenna is aimed at the transmitters?.Do you have a dedicated line from antenna head to tv? Are you getting HD?
post #6 of 7 Old 01-01-2006, 07:37 PM - Thread Starter
wures7's Avatar
My outdoor antenna is blocked by two floor building that is next to the house I'm in now. Even with line of sight blocked, I still can get most of the major networks except the 2 I listed and the other 2 which are weak. I'm also able to pick up subchannels that I've never seen before. Weather channel on channel 4 is an example. I can pick up KCET HD and KOCE beautifully so I don't know why I can't get FOX or CBS.
Yes, it is a dedicated line. The antenna is directly connected to my OTA receiver. Yes, I'm getting HD.
wures7 is offline
post #7 of 7 Old 01-01-2006, 10:28 PM
greywolf's Avatar
Location: Evanston IL 60202 11 mi from Chicago transmitters
Try aiming in a different direction if there are tall buildings around you. You are close enough that you might get a decent signal reflecting off another building that has a direct line of sight to both you and the transmitters.
Pat
While I may link to and mention products as examples, I don't recommend specific products.
greywolf is offline
Closed Thread HDTV Technical
