DVI/HDMI Output is blocked - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-15-2006, 05:45 PM - Thread Starter
dgaylor's Avatar
Hi, I am new to HD and also to this site. I have an Explorer 8300HD that I am using the HDMI output on, going into a Samsung Ht-Q80 DVD home theatre. I am then trying to use the single HDMI output from this ht-q80 going into my sony klvs32a10 tv. I am getting a 'DVI/HDMI Output is blocked' message. If I pass the Explorer 8300HD directly to the TV using HDMI I don't get this problem. My problem is that my tv only has one HDMI input and that is why I bought this little home theatre system, hoping that I could just pass the signal throught it to the tv. Is there any way around this issue? I know that I could use component cables but I would rather stick to the HDMI. Thanks in advance.
dgaylor is offline
post #2 of 4 Old 05-15-2006, 08:09 PM
mjones73's Avatar
Typical issue with an AV receiver and STB not getting along, some searching here should turn up some past posts on the same issues. Basically the AV receiver is supposed to be acting as an HDMI repeater and the STB isn't getting along with it, I believe it would require SA fixing the firmware on the STB.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #3 of 4 Old 05-15-2006, 08:18 PM
homerx's Avatar
Mostlikely the amplifer is not passing the HDCP to the TV. So the tv sees it as un-protected.
Anyway yes you can use commponet. But it will not be as good.
You could also get an HDMI switch. I think they make 2 and 4 way switchs but they sell for over 100 bucks
homerx is offline
post #4 of 4 Old 05-16-2006, 04:57 AM
adb
adb's Avatar
Try component, many have found that hey cannot tell much difference if any.
adb is offline
Closed Thread HDTV Technical
