Desired Signal level (dBm) for OTA Dig TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-19-2006, 09:40 AM - Thread Starter
etzeppy's Avatar
I'm trying to find out the optimium signal level range in dBm for reliable Dig TV. I have access to an RF spectrum analyzer but I'm not sure what I'm looking for. I'm not far from my local stations in Dallas (10-15 miles) so I'm trying limp along with an attic antenna but I'm having a little trouble, mostly with FOX. Most of the FM stations are on the same antenna farm. Any need for an FM trap?
I would like to use the spec analyzer to figure out if I have my antenna oriented correctly and if it's possible to get enough signal with my current setup or if I'm even getting too much signal. I've done several searches but can seem to find the min and max signal levels for optimum performance.
Keith
etzeppy is offline
post #2 of 11 Old 05-19-2006, 10:45 AM
HDTVFanAtic's Avatar
From the Code of Federal Regulation Title 47, FCC Rules and Regulations Part 73.622 which states:
(e) DTV Service Areas. (1) The service area of a DTV station is the
geographic area within the station's noise-limited F(50,90) contour
where its signal strength is predicted to exceed the noise-limited
service level. The noise-limited contour is the area in which the
predicted F(50,90) field strength of the station's signal, in dB above 1
microvolt per meter (dBu) as determined using the method in section
73.625(b) exceeds the following levels (these are the levels at which
reception of DTV service is limited by noise):
dBu
Channels 2-6................................................. 28
Channels 7-13................................................ 36
Channels 14-69............................................... 41
HDTVFanAtic is offline
post #3 of 11 Old 05-19-2006, 11:42 AM - Thread Starter
etzeppy's Avatar
That at least helps me know what the FCC says the level should be. 41 db at 599MHz, center of channel FOX 4.1 (Ch 35 in Dallas), translates to -89.5dBm. However, I have no idea if that is really the min power I would be looking for at the input of a typical dig TV receiver. Based on past experience with the FCC, that 41 dBu contour value could be based on the input of a nominal antenna, input of the receiver, or just about anything else.
etzeppy is offline
post #4 of 11 Old 05-19-2006, 11:51 AM
The FCC has a standard (as defined in 73.625(b) ) for measurement for signal that the stations use for determining their contours.
After that point, everything else will be influenced by the gain of the antenna, the length of cable and cable type not to mention each Receiver will also have different specs for its tuner section.
And just because most of the FM stations are out in the Cedar Hill Tower Farm with the TV stations, that does not mean you need an FM trap.
post #5 of 11 Old 05-20-2006, 05:05 AM
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
The minimum signal level for terrestrial (antenna pointed at the horizon) receivers is:
thermal noise floor + noise figure + required S/N ratio
The thermal noise floor is:
p=ktb
p = noise power
k = Boltzmann's constant (1.3807x10E-23)
t = antenna temperature (290K = 17C)
b = bandwidth (6 MHz)
p = 1.3807x10E-23 * 290 * 6000000
noise power in dBm (10 log p + 30) = -106.2
If you use a 3 dB preamp at the antenna, then your receiver noise figure will be essentially 3 dB. The required signal to noise ratio is around 16 db. So the minimum signal level is -87.2 dBm.
To convert from dBu to dBm, the equation for a 75 ohm antenna is:
P(dBm) = E (dBµV/m) + Gr(dBi) - 20log F(MHz) - 75.46
where Gr is the gain of the receiving antenna.
The DTV station is on channel 35 (599 MHz) and the typical antenna gain is 14 dBi. At the 41 dBu contour, the received power will be 41 + 14 - 55.54 - 75.46 = -76 dBm. With our -87.2 dBm receiver, the signal will be 11.2 dB above the minimum signal required.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
post #6 of 11 Old 05-20-2006, 05:16 AM
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
p=ktb
p = noise power
Ron
post #7 of 11 Old 05-20-2006, 07:39 AM - Thread Starter
etzeppy's Avatar
p=ktb
p = noise power
Ron
Thank you Ron! I've seen this type of calculation for land mobile radio but just couldn't find it referenced to 75 ohm and TV equipment. You're the man!
etzeppy is offline
post #8 of 11 Old 05-20-2006, 07:49 AM - Thread Starter
etzeppy's Avatar
Ron,
As a follow-up, I'm measuring levels in the range of -60 dBm to -45 dBm for the local TV carriers. I'm also seeing FM and a few other signals at -20 dBm and higher. At what level would you expect to exceed the dynamic range of the receiver and start generating intermod or causing receiver desense?
etzeppy is offline
post #9 of 11 Old 05-20-2006, 10:26 AM
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
Originally Posted by etzeppy
Ron,
The ATSC receiver performance guideline states -83 dBm to -8 dBm.
http://www.atsc.org/standards/practices/a_74_rfs.pdf
-83 dBm is the noise floor a receiver with a 7 dB noise figure. -8 dBm is where preamps start to overload. Just guessing, but I'd say most receivers will overload long before -8 dBm.
Unless you're trying to receive a weak channel 6, an FM trap is almost always a good idea. Other huge signals are often in the paging band around 150 MHz.
Ron
post #10 of 11 Old 05-20-2006, 12:02 PM - Thread Starter
etzeppy's Avatar
Thanks for all of the info Ron. This has been an amazing experience. I disconnected my directional VHF/UHF and replaced it with a set top VHF rabbit ear & UHF loop combo unit (no amp). I also added an FM trap and variable 20 dB pad. I have everything tunned in at around -65 dBm with no unwanted signals higher than about -40 dBm.
I was about to purchase an outdoor antenna and put myself through a ton of hassle, for nothing. Too much signal; what a concept.
etzeppy is offline
post #11 of 11 Old 05-20-2006, 12:45 PM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
FYI, for those who get their hands on a spectrum analyzer but aren't all that familiar with one, bandwidth correction must be factored into the signal strength level indicated in the screen.
I've used a few AVCOM spectrum analyzers that had selectable bandwidths of 3Mz and 300Kz. If you are using the 3Mz setting, you need to add 3dB to what you see on the screen. If you are using the 300Kz setting, you need to add 13dB. When evaluating antenna reception quality, I always use the finer resolution because it doesn't mask over notches in the antennas reception spectrum.
Somewhere way back in the Local Antenna Reception thread, I think hol_lands posted a list of the tested input thresholds of five different, fairly late model tuners at different frequencies. As I recall, the minimum input of those receivers and channels tested was in the range of about -79dBm to -82 or 83dBm.
I, too, would be very surprised if a tuner could function properly with an input signal level of, or anywhere near -8dBm.
AntAltMike is offline
Closed Thread HDTV Technical
