Dish Network VIP622 Receiver Questions... - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 342 Old 01-10-2009, 10:04 AM
gatorman's Avatar
Originally Posted by jeffdb27 View Post
I set a manual timer on my Dish vip622 to try to record only part of a news program. The manual timer is for a local (ota) channel and is set from 10:06pm to 10:15pm monday through friday. It should record 9 minutes each weekday. But instead, it always records the entire 35 minute program (no early start or late ending).
Is this a known bug? Has anyone else seen this behavior?
Jeff
Someone in the Dish 622 support forum at DBStalk.com should be able to help.
gatorman is offline
post #332 of 342 Old 01-10-2009, 10:17 AM
Walter L.'s Avatar
Jeff
Interesting. I'll try later and let you know.
Walter
Walter L. is offline
post #333 of 342 Old 10-21-2009, 01:29 PM
the_phew's Avatar
Recently, I noticed a strange problem when playing back recorded content from the 622 DVR. There is pixelation whenever images are rapidly changing (changing camera angles, fast action, switching from programming to commercials, etc).
-The pixelation is not in the source material, since 'Live' TV does not exhibit the problem.
-All recorded content, whether it is from the satellite or OTA tuner, exhibits the problem.
It's not my projector or AVR or anything, because no other source has the problem, only DVR content.
Has anyone else had this problem?
the_phew is offline
post #334 of 342 Old 10-21-2009, 03:05 PM
Chiahead's Avatar
I have not noticed the problem, but I will keep an eye out.
Michael
PSN: Chiahead
Chiahead's Man Cave - Indexed
Loganed on 8/29/2008
Chiahead is offline
post #335 of 342 Old 10-22-2009, 08:28 AM
gatorman's Avatar
You should have gotten new software within the past few weeks. Try a hard reset and see if that clears up the problem.
gatorman is offline
post #336 of 342 Old 10-22-2009, 12:55 PM
Chiahead's Avatar
I didn't notice last night. But I got a new machine about a month ago. The power supply in the old one died, and I needed a replacement.
Michael
PSN: Chiahead
Chiahead is offline
post #337 of 342 Old 02-06-2013, 08:45 AM
Smithdoor's Avatar
FYI on the 622
Try pluging a antenna to back of the 622 back in 2005 I did this work great now I could record 3 shows at one time. If the dish was out still was local channels with it smile.gifsmile.gif
Today I have gone to Antenna only no dish 62 channel as I found out biggrin.gifbiggrin.gifbiggrin.gif
FYI dish will not tell you this works just try one day happy days
Dave
Smithdoor is offline
post #338 of 342 Old 05-01-2013, 06:19 PM
lukesfather's Avatar
Can the VIP 622 pass 1080p or am I stuck wirh 1080i?
lukesfather is offline
post #339 of 342 Old 05-01-2013, 06:48 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
Since there are no 1080p channels there is no need for 1080p output. Your tv will convert 1080i to 1080p.
primetimeguy is offline
post #340 of 342 Old 05-01-2013, 07:00 PM
holl_ands's Avatar
Quoted: 437 Post(s)
Liked: 180
Dish reportedly only offers 1080p for Video-On-Demand to MPEG4 capable Receivers.
Here's a TEST you can do to check your system:
http://www.dbstalk.com/topic/141737-vip622722-1080p-compatibility
holl_ands is offline
post #341 of 342 Old 05-01-2013, 07:10 PM
jeffdb27's Avatar
I upgraded to the Hopper a while ago, but i think there is 1 VOD channel on the 622/722 recievers. So yes, your vip622 can output 1080p. But other than that one "channel", no.
jeffdb27 is offline
post #342 of 342 Old 06-26-2013, 10:19 AM
Mike H DISH's Avatar
With the VIP 622/722 HD DVR receivers, if they have Broadband connection they will have more access to the VOD content. You will be able to have selections from; New Releases and Special Offers with the ability to view in 1080p.
Mike H DISH is offline
Reply HDTV Technical
