Samsung DTB-H260F ATSC tuner - Page 122 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #3631 of 3657 Old 01-09-2013, 11:40 AM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
Power supply capacitors, if you search this thread you'll read several posts referring to bad power supply caps. It can be a DIY project if your familiar with soldering but I think someone in this thread(or maybe the CM7000 CECB thread) posted he can do the job for a reasonable rate.
At one point Samsung was fixing this problem under a type of extended warranty(or maybe giving people credits) but I believe thats long gone.
The days of CE products lasting a decade or more, for the most part seem to be gone frown.gif If products make it through or even double the warranty mfgs. seem satisfied mad.gif
jjeff is offline
post #3632 of 3657 Old 01-09-2013, 12:48 PM
scott967's Avatar
In my case the LED wouldn't do more than flicker for an instance. If the LED is turning on it may not be a cap issue. I've had to reboot mine from time to time, but never had a re-boot fail to recover. But on mine I would get the "no signal" popup, not just a black screen.
But this thing is like a space heater so I don't leave it on 24/7.
scott s.
scott967 is offline
post #3633 of 3657 Old 09-08-2013, 09:17 AM
Brian Hampton's Avatar
Quoted: 583 Post(s)
Liked: 311
Discovered GE universal remotes work with the h260f.
Code 8112 (I think,.., can verify if needed.)
Brian Hampton is offline
post #3634 of 3657 Old 12-05-2013, 02:05 PM
chinusa's Avatar
So I got a DTB-H260F from fleebay, the seller claims it's in great working condition, except it doesn't have a remote control. As you probably know, without the remote, the STB is just a metal box. So I bought a brand new remote control model MF59-00291B, exactly the same as the original one, but the box will not respond to the remote. It looks like someone else on Amazon reported the same problem: http://www.amazon.com/Samsung-SAMSUNG-MF59-00291B-REMOTE-CONTROL/product-reviews/B003090PIU/ref=dp_top_cm_cr_acr_txt?showViewpoints=1
I wonder if we missed something. Is there a way to program the box or the remote control to make them work with each other?mad.gifmad.gif
chinusa is offline
post #3635 of 3657 Old 12-05-2013, 11:53 PM
L David Matheny's Avatar
Liked: 33
I don't know of any way to program or pair the remote, and the only remote control troubleshooting advice in the manual (available from Samsung) seems to be "Make sure you have fresh batteries installed". Verify that your remote is model number MF59-00291B (listed on the front under the buttons on the only one I've seen).
Oops! I see you do supposedly have the right model, so I don't know what's wrong.
L David Matheny is offline
post #3636 of 3657 Old 12-06-2013, 02:08 PM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
Point the remote at a digital camera and push a button, you should see a glow from the end of the remote in your camera's display. If you see nothing you have a bad remote(or batteries) if you see something  either you have the wrong remote or something else is bad, receiver on the Samsung?? It would be helpful in troubleshooting if you or a friend had another remote or Samsung.
ota.dt.man likes this.
jjeff is offline
post #3637 of 3657 Old 12-06-2013, 03:26 PM
scott967's Avatar
I use a Logitech Harmony remote on mine. It's in the Logitech database so no need to learn from an existing remote.
scott s.
scott967 is offline
post #3638 of 3657 Old 12-18-2013, 08:49 AM
6volt's Avatar
Quoted: 60 Post(s)
I just found a local sale for a DTB-H260F and was wondering just how inferior the tuner is by today's standards.
I have a CM 7000 coupon STB and wonder if the Samsung would bring in as many channels?
I have an old Samsung direct view tube HDTV (DVI input) whose tuner is really weak compared to the CM.
THE QUESTION: would this DTB-H260F be worth having or do I really need to buy a newer tuner (with HDD of course!)
BTW they are asking $80 and I'm think $35 to $50
Oh, and with my CM, I am just barely able to get all my local channels with a CM4228 on my porch running through a Titan 2 CM7777. The TV tuner gets maybe 1/2 the stations the CM gets.
6volt is offline
post #3639 of 3657 Old 12-18-2013, 01:03 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
The Samsung tuner box is an older model and will now have a weaker tuner. For a stronger tuner, consider the PHD-208 HDTV tuner from ePVision. Nice basic tuner box with good tuner. But that Samsung box does have a nice interface and was good back in its day. But probably not as good a tuner as the CM-7000 converter box which was one of the better tuner boxes, but SD only.
tylerSC is offline
post #3640 of 3657 Old 12-18-2013, 05:33 PM
6volt's Avatar
Quoted: 60 Post(s)
Forgot to mention, if it had Firewire Transport Stream output - I'd buy it in a heart beat.
I did find info about this unit saying it was a 5th generation ATSC tuner.
Then some people saying each manufacturer has its own "generation" series - in other words one manu's 5th could equal another's 4th, etc.
I found lots of reference to 6th gen, and some 7th gen, but no 8th gen.
But under 7th generation, I found a DVICO (FusionHDTV7 RT Gold) HDTV Tuner Card which are discussed around 2011 and are now cheap. Would turn one of my many old XP PC's into a nifty DVR.
They appear to have an IC tuner instead of a can. (perhaps the metric at this point in time is to simply not get a can tuner? Like any IC tuner is better than a can?
But actually that may not be true. It could be that the IC is cheaper, smaller, and maybe uses less power which now-a-days marketing has determined will have an effect on pricing - not performance.
So who knows.
These days Convenience trumps Performance such as MP3 over CD and Smart Phone/Tablet over Desktop.
Frankly, when everyone has their cable or DSL for TV, why would any manufacturer worry about the 10% of the already small OTC market share that has reception problems.
6volt is offline
post #3641 of 3657 Old 12-20-2013, 10:46 AM
holl_ands's Avatar
Quoted: 529 Post(s)
Liked: 230
Here's the summary I provided back in 2006:
http://www.avsforum.com/t/728392/samsung-dtb-h260f-atsc-tuner/180#post_8868013
which cited fol. ATI test results submitted to FCC as part of a "How to determine ATSC coverage range" issue:
http://apps.fcc.gov/ecfs/document/view?id=6517693762
Alps TDQ Tuner specs claim -84 dBm Sensitivity.
There ARE tuners out there with 2 dB better Sensitivity in non-fading, no multipath conditions.....per the tuner manufacturer SPECS....unfortunately it's next to impossible to find out WHICH boxes use which Tuners and ATSC Decoder Chips [except for CECB's....see my CECB FEATURES link at bottom of this post].
The MOST IMPORTANT performance criteria is how many of the 50 "ON-AIR ENSEMBLES" (aka RF Captures) each ATSC Decoder Chip could successfully process. The ATI Xillion 260H in the DTB-H260F appears to be the same (ATI 5th) Generation chip that could decode 34 out of 50.....and Samsung "Gemini" prototype (unknown mfr), tested in Aug05 could decode 38 out of 50.
CECB's (Coupon Eligible Converter Boxes) were the FIRST and ONLY tuners that had to actually MEET specific specifications per test report submitted to NTIA/FCC (specs derived from ATSC A/74 non-mandatory "Guidelines"...which do NOT always specify pass/fail limits):
http://www.ntia.doc.gov/legacy/dtvcoupon/DTVmanufacturers.pdf
Consequently CECB's (using so-called 6th Gen ATSC Chips) ran circles around everything manufactured prior to 2007....and should be representative of nearly any tuner built in 2008 or later due to the very narrow range for additional improvement. See fol. NAB Test Report. [Unfortunately, NO NAMES.]:
http://www.nabfastroad.org/NABSTVDigitalConverterBoxEvaluation/DigitalConverter.asp [Appendix, pg 4 and 7.]
Sensitivity for ALL CECB boxes was -86 dBm (+/- 1 dB)....nearly ALL the SAME....and about 2 dB better than DTB-H260F.
Of the (only!!!) 7 CECB boxes tested, the worst could decode 37 out of 50 and the best could decode 41 out of 50.
Later "7th Gen" (or whatever) ATSC Decoder Chips (usually built into one big Super-Chip) have PROBABLY chipped away at the remaining Ensemble Tests....although perhaps five of them will NEVER be decodeable, since they were off-the-air RF Captures made at the worst-of-the-worst locations during early ATSC On-Air tests in Brazil and the USA.
Prior to 2007, the number of Ensembles that could be decoded was MUCH LESS, showing two groups....TEN that could decode 35 to 38 out of 50 Ensembles with only 1 or 2 Errors....and the other 19 (3rd & 4th Gen) that could only decode a measly 8-15 out of 50 Ensembles (incl. my old Adaptive Antenna capable Sylvania 6900DTE HD-STB with ATI NXT2004 ATSC Decoder):
http://transition.fcc.gov/oet/info/documents/reports/TR-05-1017-ATSC-reception-testing.pdf [See Field Captures, sec 6]
This illustrates that the MOST IMPORTANT advancement was NOT a 1 or 2 dB improvement in Sensitivity....but an improvement in Signal Processing.
The "5th Gen" chips were the first to provide a DOUBLE-LENGTH Equalizer which would center the initial signal in the equalizer, enabling the equalizer to lock onto a delayed multipath signal and wouldn't hickup when an EARLIER flat-fading signal came out of a fade....all earlier Equalizers would initialize the initial signal very close to the beginning of the Equalizer. [A typical problem in urban canyon environment.] See fol. for Zenith specs for their various Generation Chips:
http://www.digitalhome.ca/forum/showthread.php?p=1355458
So, what is the bottom line: Samsung DTB-H260F is "5th Gen" and will run circles around earlier Gen boxes...and is ALMOST as good as a 6th (or 7th or 8th) Gen Tuner. Since you probably don't have to deal with the "worst case" multipath conditions found in the worst-of-the-worst Ensemble RF Captures, you probably won't notice which tuners process a few more Ensembles than the other....and would be hard pressed to notice whether your box has 2 dB lower Sensitivity than some Unicorn Tuner that defies identifying which HDTV's or Tuners it might be found in.
It's better to reassess the Antenna and APPROPRIATE choice of Preamp to Maximize the Spurious Free Dynamic Range (Search forum for my "SFDR" posts)....and IF it doesn't reduce Sensitivity due to Overload, a Preamp can "typically" improve the Sensitivity by 10 dB for Mast or Attic mounted Antennas, and ALSO can improve Sensitivity for a simple Indoor Antenna since a Preamp should provide a better SWR match than a Super-Het Tuner (with a tuned input filter)....and also reduces the Sensitivity Loss due to the Tuner's internal Noise Figure.
holl_ands is online now
post #3642 of 3657 Old 01-06-2014, 01:49 AM
Jedi Master's Avatar
Quoted: 12 Post(s)
Liked: 31
My Samsung DTB-H260F just turned 5 years old last month. It still works great and I've had no trouble with it. It is my main tuner hooked up to my main HDTV. I love using it to watch football all weekend.
Broadcast TV - a vital national public resource
Jedi Master is offline
post #3643 of 3657 Old 01-06-2014, 11:41 AM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
I have 2 of them and they still work great. And I can use the same remote with a Samsung TV. Nice menu interface. And the tuner sensitivity as Hollands suggests may be almost as good as some of the newer boxes such as ePVision and others.
tylerSC is offline
post #3644 of 3657 Old 01-06-2014, 05:32 PM
Scooper's Avatar
Mine is still running. I'm using it as a Clear QAM tuner for for TWC.
One dislike about it - it doesnot autoswitch formats based on SD aspect or HD / widescreen aspect.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3645 of 3657 Old 01-06-2014, 06:21 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
I hooked mine back up today after reading this thread and it gets great reception of the distant Charlotte, NC stations which are 75 miles away. 8 to 10 bars depending upon the channel. And the pic quality is great on a Panasonic plasma ST60. The Samsung box adds the program info the Panasonic does not have. I think I will keep it hooked up, but I added a splitter to also use the Panasonic tuner at times.
tylerSC is offline
post #3646 of 3657 Old 03-03-2014, 05:15 PM
ota.dt.man's Avatar
Hi Tyler,
Wow, I'm very glad to have checked this thread and found this post since you're also using a DTB-H260F with a Pana. 60-series plasma.
I agree. We're currently using a nearly 6-yr. old DTB-H260F on a recently purchase ZT60. The reception and PQ are excellent. I'm not surprised by holl_ands expert analysis given our experience. CR also praised the DTB-H260F.
The electronic program guide (EPG) is exceptionally convenient. It's hard to believe Panasonic didn't include this handy feature. Even our CM-7000 converter box included EPG.
Additionally, the DTB-H260F features remote-controlled variable analog audio outputs. The Viera plasmas only provide an optical digital fixed audio output, which isn't plug-and-play compatible with legacy analog sound systems.
Q. When watching the DTB-H260F on your ST60 how are you routing the audio?
  • Analog audio out
  • Dolby Digital optical
  • HDMI
Q. Is there a way to adjust the lip-sync function when using a Viera plasma with a DTB-H260F & a legacy analog sound system?
Please see: Viera Audio out, Or Viera + Samsung DTB-H260F to 2.0 sound system?
Just say "no" to a never-ending subscription TV bill that increases faster than the rate of inflation.
ota.dt.man is offline
post #3647 of 3657 Old 03-04-2014, 01:34 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
The Panasonic plasmas are excellent displays but lack a good channel guide and program info. So adding the Samsung 260 tuner box was indeed a good solution. Great picture and good reception. But I also use a splitter so I can also use the Panasonic tuner which is very sensitive. But the Samsung box does get all the major channels, including from 75 miles. But I am sorry to hear Panasonic is halting plasma production as the ST60 is an awesome display.
tylerSC is offline
post #3648 of 3657 Old 03-04-2014, 02:56 PM
MJA28's Avatar
Even if mine still alive(bad caps twice)Thanks to Comcast I can't use it anymore. They encrypted all the basic channels
Sent from my Nexus 5 using Tapatalk
MJA28 is offline
post #3649 of 3657 Old 03-04-2014, 06:03 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
There is a newer Samsung box which works with digital cable. Sold at Walmart. Most cable systems are now encrypting the local channels, so there is no more clear qam available. But the 260 box still works great for an OTA antenna reception.
tylerSC is offline
post #3650 of 3657 Old 07-29-2015, 07:03 AM
ota.dt.man's Avatar
Our Samsung DTB-H260F was purchased in 2008. We have an extra MF59-00291B remote control (his & hers). Reception, audio, & video quality are all still excellent. Once in a blue moon, it needs to be rebooted - like most electronics w/ a microprocessor.
Current issues:
1. One remote doesn't appear to work at all despite new batteries.
2. The other remote works. However, it now appears to need more intentional aiming and perhaps depressing the buttons for a longer period of time to send a command.
3. New original remotes are no longer available. However, replacement remote are available but at twice the price as the original!
Per "smokinjoe52":
"My theory is that the power supply was getting noisy, and impacting the operation of the IR sensor. After replacing the caps, the remote sensor works MUCH better. I would be interested to know if anybody else has noticed this."
http://www.badcaps.net/forum/showpost.php?p=222989&postcount=86
http://www.badcaps.net/forum/showthread.php?t=7804&page=5
Has anyone else had this issue? We'd welcome any solutions, thoughts or ideas. Thanks!
post #3651 of 3657 Old 07-29-2015, 10:56 AM
ota.dt.man's Avatar
Searching this thread I found this helpful post:
Using fresh batteries and a cell phone camera:
- Remote #1 doesn't produce any light in the camera's display.
- Remote #2 does produce light in the camera's display. However, while pressing a button, there's a delay before there is light output.
Since both remotes are nearly the same age, #1 appears to be dead, and #2 is slow to glow, I'm guessing remote #2 may not be operational for too much longer. Given these results, the DTB-H260F tuner appears to not be the issue.
Does anyone repair or recondition these original Samsung remotes? Thanks!
post #3652 of 3657 Old 07-29-2015, 01:46 PM
toby10's Avatar
Quoted: 34 Post(s)
Liked: 25
Might try anyone with solder experience, have them open the remote and look for bad solder joints. Often, in other IR remotes (dunno about this one) the IR "eye" can become a loose solder connection, usually from being dropped. Worth a shot.
toby10 is offline
post #3653 of 3657 Old 07-29-2015, 08:25 PM
ota.dt.man's Avatar
Question Disassembly Tips?
Soldering I can do, no problem. However, it's not obvious how the remote is disassembled. There are no visible screws even with the batteries removed. Do the two halves snap together? Are they glued? Sometimes, when one tries to pry plastic assemblies apart it doesn't end well!
Planned Obsolescence defined:
We wouldn't want to make it simple or user-serviceable!
post #3654 of 3657 Old 07-30-2015, 02:37 AM
toby10's Avatar
Quoted: 34 Post(s)
Liked: 25
Yeah, no idea how (if) the remote can be opened. But if it is non-functioning anyway what do you have to lose if you break it?
toby10 is offline
post #3655 of 3657 Old 07-30-2015, 06:01 AM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
I haven't taken apart a 260 remote but some remotes can be a real bear to disassemble and some just snap apart.
To start I'd try with a couple medium to smaller flat blade screw drivers, try sticking them between the gap where the top and bottom of the remote comes together(the sides of the remote). Try twisting them or looking to see if there is a place to push that might release something. Lots of time doing this may gouge the side of the remote but as was said, if it's not working now anyway you have little to lose.
Basically all remotes should come together, I've never seen one glued...... although at times I could have sworn that while trying to take it apart. Just make sure there are no hidden screws behind the batteries or in the battery compartment, if not pry away.
The last remote I worked on I had almost given up, swearing it was going to break. In desperation I gave it to my daughter who pried on it a little and used her fingernails and walla, it opened! IOW if after working on it for a while you aren't getting anywhere, maybe try and fine someone else to see if they might look at it for a while.
Good luck!
Once apart just remove the rubber membrane that makes up the buttons and check for gunk or broken solder joints, generally snapping it back together goes pretty easy.
jjeff is offline
post #3656 of 3657 Old 07-31-2015, 07:14 AM
ota.dt.man's Avatar
jjeff,
Thanks for your suggestions! I used a 1" wide putty knife and was able to pry it open without any damage.
It appears the date of manufacture was 2006.10.04. I found the following #s on the PCB:
I didn't find any obvious gunk or broken solder joints even with a magnifying glass and a high-intensity light. The LED IR emitter (LD1) appears to be rigidly attached.
- Is it likely that the IR emitter is dead an in need of replacement?
- Should I wipe the pushbutton side of the PCB with something like alcohol before reassembly?
post #3657 of 3657 Old 07-31-2015, 07:47 AM
ota.dt.man's Avatar
Update: I just reassembled the remote. It easily snapped back together just as you said. I then tested it and now it works! And there's zero lag or delay! I have no idea why or for how much longer. But we'll certainly enjoy having one less frustration in life. Thanks again!
Reply HDTV Technical
