Samsung DTB-H260F ATSC tuner - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 3657 Old 09-25-2006, 05:46 PM - Thread Starter
jtbell's Avatar
Samsung showed their new ATSC tuner, the replacement for the SIR-T451, at CEDIA:
http://www.engadgethd.com/2006/09/14...ver-dtb-h260f/
I wonder if it uses a fifth-generation chipset? And if it does QAM (cable) beyond channel 125, the limitation that the SIR-T451 had?
jtbell is offline
post #2 of 3657 Old 10-04-2006, 03:30 PM
radicand's Avatar
Does anyone know the timing on this tuner? I thought I had read October somewhere, but I can't find the reference (or the tuner )
radicand is offline
post #3 of 3657 Old 10-05-2006, 10:31 AM
R Johnson's Avatar
Quoted: 43 Post(s)
Liked: 30
I was in NYC at the big Samsung store in the Time Warner Center on 9/30. Asked two sales reps about this model. Neither knew anything about it.
R Johnson is online now
post #4 of 3657 Old 10-05-2006, 01:53 PM
100/40's Avatar
E mail reply from Samsung about this unit follows:
Thank you for contacting Samsung technical email support. We appreciate your business, and hope to assist you in any way that we can.
This model is indeed planned to have a built-in digital tuner to receive HDTV signals from the air. The release date is not official yet, but estimates have it at early 2007. This is subject to change of course, but that is the plan as of now. Hope this helps.
100/40 is offline
post #5 of 3657 Old 10-05-2006, 03:46 PM
TommyK's Avatar
Originally Posted by 100/40 View Post
...estimates have it at early 2007.
Bummer... some earlier reports had it being available later this month. I had my hopes up a bit that I'd be able to experiment with one soon and possibly solve a particular reception issue I'm having.
TommyK is offline
post #6 of 3657 Old 10-05-2006, 03:55 PM
TommyK's Avatar
By Robert Heron
Samsung's booth at CEDIA was a showcase of impressive video products, but two new yet rather unassuming items caught my attention. The DTB-H260F Digital HDTV Receiver ($179 MSRP) is a pint-sized set-top terrestrial digital tuner (ATSC) that also supports unencrypted QAM (digital cable) reception. The DTB-H260F includes a comfortable remote control and features HDMI, component, and composite video outputs as well as an optical digital audio output. If your current TV lacks a digital tuner for over-the-air reception, the DTB-H260F may be an upgrade worth considering. The DTB-H260F will be available late October.
TommyK is offline
post #7 of 3657 Old 10-06-2006, 11:24 PM
samdiesel's Avatar
samdiesel is offline
post #8 of 3657 Old 10-10-2006, 11:36 AM
100/40's Avatar
This unit is now on the Samsung site
http://www.samsung.com/Products/Digi...Specifications
100/40 is offline
post #9 of 3657 Old 10-10-2006, 07:55 PM
gadzby's Avatar
Here's another sample from Samsung, just received today:
"Thank you for contacting Samsung e-mail support,
Preliminary information indicates that the DTB-H260F should be available late October and should have an MSRP of $179.00.
As always, preliminary information is subject to change. No information is final until the product is actually released."
gadzby is offline
post #10 of 3657 Old 10-11-2006, 10:50 AM
100/40's Avatar
Am I missing something? I see no mention of QAM at the Samsung website description. The CEDIA show description mentioned QAM.
100/40 is offline
post #11 of 3657 Old 10-12-2006, 12:30 PM
gadzby's Avatar
From the DTB-H260F manual on Samsung's website, newly posted today:
Specifications
General Specifications
Broadcasting standard: DTV (ATSC)
Demodulation Method: 8-VSB, QAM (free channel only)
Can't wait to get one and give it a test drive. I'm hoping it uses the 5th generation chipset from LG.
gadzby is offline
post #12 of 3657 Old 10-12-2006, 12:39 PM
rpertusio's Avatar
I would imagine that it would use Samsung's Gemini chipset.
- Ryan Pertusio
AutumnWave Technical Support
OnAir Solution North America
rpertusio is offline
post #13 of 3657 Old 10-20-2006, 12:02 PM
bettylewben's Avatar
Called Samsung today about where I could buy the DTB-H260F tuner. The guy on the phone said it should be available sometime this month(October 06) and I could buy one at either Circuit City or Best Buy.
bettylewben is offline
post #14 of 3657 Old 10-20-2006, 12:28 PM
MitsuHelp's Avatar
Did a quick spec look at their site and this model does not show that it has firewire. Anyone know of a good STB that has firewire?
MitsuHelp is offline
post #15 of 3657 Old 10-20-2006, 04:24 PM
Davinleeds's Avatar
See sticky thread HDTV STB Synopsis at the begining of Reception hardware. STB with fw listed.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #16 of 3657 Old 10-20-2006, 04:32 PM
Davinleeds's Avatar
Specifications
Pete at HDTV Expert will be reviewing this tuner and he mentioned in an email to me it has the LG 5th.
post #17 of 3657 Old 10-20-2006, 05:15 PM
Davinleeds's Avatar
It's there: //hdtvexpert.com/pages_b/h260f.html
post #18 of 3657 Old 10-20-2006, 05:39 PM - Thread Starter
jtbell's Avatar
I'm out in a fringe area, and some of the "local" digital stations have significant co-channel interference from analog stations in other cities. I wonder if anyone will test this box in this kind of situation before I have a chance to get my hands on one.
jtbell is offline
post #19 of 3657 Old 10-20-2006, 06:58 PM
Davinleeds's Avatar
Unknown quality for me but for info:digitalconnection.com/products/video/mdr200.asp
post #20 of 3657 Old 10-21-2006, 01:13 AM
KenL's Avatar
I can't resist trying this tuner since I have several important stations on the edge. But what bothers me about Peter Putman's *scientific* tests it sounds like he did that comparison with the 4200A looped out of the sammy? In other words likely padded down 3.5dB. I've done that looping occasionally and it is often the difference between lock or not (from both under or overload) depending on which tuner is first in the chain. I know my LG's don't boost the loop out. The only meaningful comparison would use as close to the identical signal as possible, which would mean A/B not loop.
It still may be close in that configuration, just because the LG is so easy to overload. But most any tuner may lose lock on a marginal signal padded -3.5dB.
KenL is offline
post #21 of 3657 Old 10-21-2006, 09:27 AM
gadzby's Avatar
Good news - thanks for posting that info. I live in an area with good signal strength but lots of multipath, so I'm looking forward to swapping out my old 2nd gen (?) receiver.
gadzby is offline
post #22 of 3657 Old 10-21-2006, 09:30 AM
gadzby's Avatar
I'm receiving conflicting messages. I called BB up yesterday, and the sales associate told me they were getting out of the business of selling standalone HD tuners. Hence, they would not carry the new Samsung. Go figure.
Hopefully Samsung is correct - I'd be surprised if BB doesn't sell this new unit.
gadzby is offline
post #23 of 3657 Old 10-21-2006, 09:33 AM
biker19's Avatar
Quoted: 23 Post(s)
When the masses of OTA only households start buying them in 09, BB will certainly be in the DTV tuner business.
biker19 is offline
post #24 of 3657 Old 10-21-2006, 02:49 PM
JoeMoon's Avatar
My local BB (St. Louis) had a DTB-H260F this morning. I'm hooking it up now.
JoeMoon is offline
post #25 of 3657 Old 10-21-2006, 03:34 PM
Davinleeds's Avatar
If I read the article correctly, it was the other way around. But as he mentions, you need good reception to begin with, then it will handle the multipath. Bummer for my situation.
post #26 of 3657 Old 10-21-2006, 03:56 PM
spanky28's Avatar
What was the price? BestBuy online doesn't have it listed yet.
spanky28 is offline
post #27 of 3657 Old 10-21-2006, 03:59 PM
Davinleeds's Avatar
Does it meet your expectations?
post #28 of 3657 Old 10-21-2006, 05:06 PM
KenL's Avatar
That's also the way I first read it. Perhaps there was an edit to the review by the time I posted. Now it reads:
I connected the STB-H260F to my rotating roof antenna, looping the signal from the receiver’s ANT OUT terminal to a 4th-generation LG LST-4200A DTV set-top, then on again to my lab spectrum analyzer.
The multipath performance of the 5th-generation LG is well known (if that's what we have here -- I still haven't spotted anything official on that) but if he tested configured as a loop, it likely exaggerates the 4th-gen LG failures, and as such the all but useless chart does little to showcase comparative multipath performance, because all else wasn't close to equal.
But you can be sure I'll test this one myself.
KenL is offline
post #29 of 3657 Old 10-21-2006, 06:18 PM
pekkle's Avatar
I called all the STL area BBs and none of them had it. Did you get it from the Brentwood store? The guy there mentioned that he randomly got a Samsung unit in stock this week but it had been sold.
pekkle is offline
post #30 of 3657 Old 10-21-2006, 06:58 PM
Michael F.'s Avatar
My BB said they don't carry them at all!
How is yours working?
Details
Mike
Michael F. is offline
Reply HDTV Technical
